Old 03-24-2008, 06:43 AM   #1 (permalink)
gnxtc2's Avatar
RSK tire size
What size tires/rims are you guys running with a RSK w/ SD springs? If you have pics, post away.
Reason I'm asking, my 265/75-16 tires are worn but I'm gathering parts for my RSK w/ SD springs. I need tires and want to buy the correct size.
Any recommendations of tire size? I do tow so economy is a plus (No, I'm not putting the pizza cutters back on the truck).
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, US GEAR downpipe, Bilstein 5150s, Front add-a-leaf w/urethane bushings, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, Shimmed fuel regulator, 4" Exhaust-Straight piped,FORD AIC, Custom triple A-pillar gauge holder,B&M Supercooler, gutted EBPV, B&M Transpan, ART Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, 149K
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 03-24-2008, 11:25 AM   #2 (permalink)
With 3.55 gears tires size should stay close to what you have, I'd go to 4.10 and 35" but thats me
I have pics of 35" and also 37" on my Webshots..link below.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 03-24-2008, 12:25 PM   #3 (permalink)
4rcFed's Avatar
My Photos: (6)
For a few years, I have been running 285/75/16s. But that is on stock suspension.
I have just done the Dana 60 swap, and soon to add the RSK and SD springs. I already have some 315/70/17s mounted and ready to go. Yeah, I might be running into a gearing / too big of tire / fuel economy issue, but we'll see I guess. I'll get some pics as soon as I swap out the springs.
1997 F-250 HD, XLT, PSD, Ext. Cab, Off-Road pkg., 3.55's, E4OD, 4wd, Dana 60 swap, 3" Sky RSK, Lund visor, 151,000 miles, triple Auto Meter gauges, Tymar intake, Tymar DP, Straight piped, 5" Miter Stacks, Tuning by DP Tuner, 315/70/17's.
Without data, it is just another opinion!!
4rcFed is offline
Old 03-24-2008, 11:59 PM   #4 (permalink)
Rtxcoon's Avatar
stock springs with a sky rsk....I run 35" procomp AT's on a 17x8 wheel
the rub some on full turn, but I can live with it...really wish I had some 4:10's though....
1997 F350 CC 4x4 Auto
a little over 400 at the rear wheels
thanks to Wildman, Bean, Cass, Luke and Visa
www.northtexaspowerstrokes.com
Truck Pictures
Truck Movies
Rtxcoon is offline
Old 03-25-2008, 12:25 AM   #5 (permalink)
35's really hurt my fuel mileage, went from 20+ mpg to 14-16
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
bosefes is offline
Old 03-25-2008, 06:16 AM   #6 (permalink)
4rcFed's Avatar
My Photos: (6)
With the 3" RSK up front, do you only have the 4" blocks in the rear to level it out?
4rcFed is offline
Old 03-25-2008, 09:45 AM   #7 (permalink)
Yes it sould be perfect..mine was.
Cary
2006 Yamaha FJR1300
caryt is offline
Old 03-25-2008, 08:21 PM   #8 (permalink)
DIESELDUTTON's Avatar
Same here, I went as far as to put my 265's back on, that lasted a week . The 35's are back on . The fit and look is perfect
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 03-26-2008, 01:33 AM   #9 (permalink)
I also have the the 16x8s with 35s. I have not seen the MPG drop that much. I like the look and ride of the 35s (pics in the webshots link below). They do rub the leafs a little on tight turns.
1996 F350 XLT CC LB 4x4 120K, E40D
Tymar Intake, Magnaflow 4" SS Exaust, Edge Evo, FPR Shim, SKY RSK w/SD vcodes, Bilsteins, Velvet Ride Shackles
TRUCK PICS
2004 Outlander Max 400HO (mine)
2004 Rally 200 (hers)
2004 Grizzly 80 (sons)
fitzgood is offline
Old 03-26-2008, 08:32 PM   #10 (permalink)
I agree Frank, I can't bring myself to go back to 255's or 285's. It just doesn't look right, sure wish there was more selection of 35x10.50 tires out there except Swampers
bosefes is offline
Old 03-26-2008, 11:15 PM   #11 (permalink)
I have a homemade RSK kit, Dana 60 w/SD springs. F350 4" blocks in the rear with factory overloads so mine is a little higher than some in the rear. My truck is almost level, when I forst got it together the front was a little higher but now its level to maybe 1/2 " down in front. I was on stock rims and 285/75, I just put on some 315/75 Maxxis Bighorn mud tires (I love them !) and some 16x10 allloy rims and I get a slight rub on the inner fender if the suspension is in compression and I turn. If I had put the axle a little more forward (It sits about 1/2" or so back) I dont think I would have any rubbing issues. I am going to lift the front 1/2" by putting the stock F350 spacer back. The SD springs didnt have it so I left it out. But the stock F350 springs did have it. I will post some pics tomorrow.
95 PSD crew cab LWB 5 speed KP D60. Converted to 4wd from 2wd (wow, what a job!). Custom RSK with SD springs. 290k miles and running strong. SMFW conversion, 3" DP, 1.0 A/R exhaust housing on rebuilt turbo.
skeen550 is offline
Old 03-27-2008, 06:59 PM   #12 (permalink)
Stock Stroke's Avatar
I run a donohoe leveling kit with stock spring in the front of mine that gave me 2.5 inches up front and i fit 35 Mud Terrains in the back i run a 3.5 inch angled block with a 1.5 aluminum block underneath, it sits about an inch higher in the rear, if super duty spring ride better up front im deff. gonna be putting some in
97 F350 XLT, PSD, SC, SRW, 4x4, 3.55, Racer X E4OD, Racer X TC, Mag-Hytec pan, Transgo Tugger, Diesel Site external filter, K&N FIPK, MBRP 409 Exhaust, Diesel Site HX Mod, TW 6-position, Dfuser 18K, Powermaster Starter, DR 2.5 Leveling Kit, Warn Premiums, Powerslots, 35x12.50 BFG Mud Terrains
Stock Stroke is offline
