welp everythings been but i think my HPOP just went out or something. truck is running rough, you can pull the covers and left side is spitting oil like it should pull the injector harness and it stumbles. right side is not spitting ouil like it should at all and when ya pull the injector harness nuthing happens. think im gonna order me another HPOP but just wanted to here ya'lls thoughts on this prob.
Sounds like it might be electrical. If the IDM finds a fault in the injector wiring on one side of the engine it will shut that side down. Even replacing the entire engine wiring harness will be cheaper than a new HPOP.
The first thing to check would be the plugs at the valve-cover gasket. First off, there should be no burnt pins. Secondly, use an ohm meter to check each pin as follows.
-the end pins (glow-plug) should read about 1/2 to 3 ohms to ground.
-the center three pins (injector solenoids) should read open-circuit to ground, and about 10-20 (I think) ohms from the center pin to each of the two adjacent pins.
It might also help to find someone with a scanner that can read the codes from the IDM. That might help narrow down the fault.
-RD
1997 F350 CC DRW E4OD POS webshots
I agree that it is electrical on that side of engine. As stated under valve cover harness or connectors are good bet as your problem. Pull off oil filler and smell the valve cover for burnt wire.
Jim Sult / Excavator (we dig it) Trying to fix it? KISS IT"KEEP IT SIMPLE STUPID"
Avatar- my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Stock for now Auto trans, BabySwamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 173000 miles
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, Tymar intake, 112000 miles
well there is one burnt at the front right valve cover. been like that for a couple years now. i did pull the codes i forgot to add them. it gave me a fualt on the cam position senser. even if you reset the codes and then pull that harness to the front right 2 injectors it's still makeing it run rough. where ya'll suggest for the cheapest place to buy a harness. Powerstrokeshop.com.
__________________ active duty US Coast Guard SEMPER PARATUS "Always Ready"
You should be aware that glow plugs cause these wire to melt and if your g plugs are in there for a while you should consider doing all g plugs,under valve cover harness's and valve cover gaskets plus any outside valve cover connectors that are burnt.
the glow plugs where replaced about 2 years ago and hadn't had any plobs out of them. but that pin that is burnt is on the outside harness connector. i swaped the gaskets and it still done the same thing even with a different gasket. sin't checked the Ohms yet got dark outside and the shop has a tractor in it. o ya the pin the is burnt is the very first pin at the front of the motor right front. don't know if it s a injector pin or g-plug
picking up some new connetors and pins this afternoon from international, if it still does the same thing after replace the connectors then what should be the next step. just trying to stay one step ahead. i also had a fualt on the CPS ya'll think that might be a prob too.
Valve Cover Harness Repair Kits (contains 4 hard shells w/seals, w/o terminals)
(Ford) F7TZ-14489-BA (94-96)
(Ford) F7TZ-14489-AA (97)
(International) 1830829C91 removal tool and Shells w/o pins
(International) 1661875C1 Pins
(International) 2501055C1 Pins with 6" wire
Valve Cover Pigtails with plug and wires, OBS
(Performance Specialties) 99288
Valve cover harness replacement terminals:
Industry P/N 103935; Winzer Distributing (1-800-527-4126) selection number D52
Valve Cover Harness "Wedge" repair (not sure of years it fits or what it looks like)
(Ford) 2c3z-14a163-ab
Valve Cover Gasket (94-97)
(Ford) F4TZ-6584-A
(International) 1818350C2
Valve Cover Harness, under valve cover
(Ford) F4TZ-9D930-K (94-97)
(International) 1815923C92 (94-97)
well changed the harness connectors and pins plus changed the VC gaskets and still nuthing anyone go any other suggestions. still showing no other codes
if you are still having trouble with oil not spitting out then I would check the injectors on that side as you might have a loose poppet screw
Just remove the 4 screws on top of injector and pull off solenoid. The screw in center should be tight. If loose the injector is not working.
