Old 05-21-2007, 01:56 PM   #1 (permalink)
S D gas pedal for OBS
Anyone install a Super Duty (for 7.3) in an OBS?---Thanks
95 F350 SC-8ft. box, PSD-190,000, 4x2, 5sp,Baby Swamps, BD downpipe, Summit racing 4 " bullet muffler-exit ahead of rear tire, ATS air to air-a mistake?,MAP sensor press reg mod, K&N, Bully Dog 4 pos.Flipchip, pillar gauges ,3.55s- shimmed FRR =65., HPX, Swamped, South Bend SMFW and clutch,LUK PP.,Gutted EPV, AIC-thanks Patrick,DIY mod IDM, white face gauges-PYRO IN DOWNPIPE
DESTROY AMERICA-JOIN AN ENVIROMENTAL GROUP
oldtimer is offline
Old 05-21-2007, 02:10 PM   #2 (permalink)
DrSpeed's Avatar
My Photos: (12)
Re: S D gas pedal for OBS
What's the advantage?
I have mine available if you want to experiment. Let me know...cover shipping and a couple of bucks, and we'll call it good.
send me an email.
2002 F250 SuperCab Longbed CUMMINS 6Spd True Blue
Bellingham, WA
40" Toyo MT's, KMC XD Rockstar 20x12, 12" Lift, Donahoe Racing Signiture Resevoirs, PSC Hydraulic Assist with X-Over Steering, Dynatrac Superduty Combo Kit, Velvet ride Shackles, 4.11 Yukon Gears, Dana 80 Swap with ARB Locker, SSBC V10 8 Piston Caliper Brakes, SBC DD Pulling Clutch, Custom 5" Turbo Back Straight Pipe, Autometer Ultra Lites, Line X, Warn Hubs, AMP Research Power Steps, Retrax Tonneau, Blitz TT, Kenwood System w/JL12W6, 6000K HIDs, Flames by KC Customs, Road Armor Bumpers Front and Rear with PIAAs and Hellas.
MOTOR SWAP COMPLETE!
2003 Cummins ISBe Common Rail - ARP Studs, VGT Twin setup, ATS 3-piece, Smarty Programmer, Edge EZ, F1 Diesel Flux 2 Sticks and Cam, Floor It Diesel Stage 2 CP3.
My Truck Pics -
http://www.truckblog.com/drspeed - Writer and Photographer
DrSpeed is offline
Old 05-21-2007, 02:16 PM   #3 (permalink)
tjbeggs's Avatar
the advantage would the SD pedal assembly is less than half the price of the OBS assembly!
1997 F-350 CC LB 4x4 Auto, AD's, Chip, IC, 4Wh. Disk Brakes, and other stuff
Truck Pics
tjbeggs is offline
Old 05-21-2007, 02:33 PM   #4 (permalink)
I have read on here somewhere that the SD potentiometer will fit the OBS pedal with a little work? This only leaves the Idle valadation switch which I swear looks exactly like a Cummins Jake brake switch except the plug.....
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 05-21-2007, 02:47 PM   #5 (permalink)
DrSpeed's Avatar
My Photos: (12)
I thought there might be some power gains...
hmm...well, it's here if anyone wants to experiment.
DrSpeed is offline
Old 05-21-2007, 04:21 PM   #6 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78
Shouldn't be any different with power, they both work on 5v reference and look for if your at idle or not.
Maybe if the SD pedal doesn't have the tab for the IVS that some have to bend, I know mine needs it, but when I tried to do it I was afraid I was going to take it too far or break it [img]/ubbthreads/images/graemlins/phoney.gif[/img]
-Michael
Dieselfever78 is offline
Old 05-21-2007, 07:49 PM   #7 (permalink)
Tom S's Avatar
My Photos: (20)
I believe these are out in the aftermarket now as well or at least parts for them. I saw it on one of the big parts chain web sites.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Tymar intake, Cowl Hood, 4" Stainless Magnaflow/Aeroturbine exhaust
14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Tom S is offline
Old 05-26-2007, 10:46 AM   #8 (permalink)
DrSpeed's Avatar
My Photos: (12)
$50, does anyone want to try it?
DrSpeed is offline
Old 05-26-2007, 11:08 AM   #9 (permalink)
My Photos: (13)
My understanding is the connector was changed.
To use the SD you have to change the connector on your harness.
Don't expect power gains. Not going to happen. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 05-28-2007, 01:05 AM   #10 (permalink)
The only thing I can think of as far as "power gains" would be something similar to the power pedal mod. From what I gather on that mod our pedals may not always reach the max voltage which is what the mod resolves (I believe)... so if there is any kind of "gain" I'd guess maybe the SD pedal in an OBS application may produce the full potential output as what is seen in the power pedal mod? If that makes sense?
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
ryanPSD is offline
Old 05-28-2007, 02:15 PM   #11 (permalink)
What is the "power pedal mod"? I just replaced my accelerator pedal assembly about 3 weeks ago due to a bad IVS. It sure seems to have a ton more power now than before. Maybe with the old pedal assembly, it wasn't reaching full output? Any ideas?
96 F350 reg. cab SRW 4x4, original owner. 5 spd. manual with a South Bend Clutch solid flywheel and Con-O clutch kit, clutch petal mod., Truetrac differentials, front and rear, 4.10 gears. Tymar intake, gutted EBPV, 3" downpipe, 4" exhaust, BDP stage 1 injectors, DIY IDM mod, 4 pos chip, Banks technicooler intercooler, shimmed FPR. 324k miles and still rattling.
96F3504X4 is offline
