Old 01-18-2008, 08:13 AM   #1 (permalink)
Is this safe?
i have a buddie with a 2000 f-250 and he told me that he puts 2 stroke motor oil in his fuel to make it blow thicker and darker smoke... does anyone if this will work and if it's safe for my 96 f-350?
adam09 is offline
Old 01-18-2008, 08:57 AM   #2 (permalink)
Why would you want to do that?
97 PSD f250 4x4. 06 common rail conversion in the process.
<span style="color: red">cummins conversions by Rockin S performance </span>
AlanB is offline
Old 01-18-2008, 11:12 AM   #3 (permalink)
I add a Qt of 2-stroke oil to each tank when I fill up. It doesn't make it smoke anymore than normal but within 5 miles of adding it my idle smooths out and the engine runs quieter.
STROKER
96 F-350 Crew cab, Long bed, 4X4, ZF5-
Gauges (EGT, Boost, Trans), TW chip, 3in Downpipe, 17* HPOP, electric fuel system, DIY stage 1s, ZF 5 conversion, ceramic clutch, CCV mod, 285/75/16
On Order: 6.0 VGT turbo, AEM air filter, 4in exhaust
73LSTROKER is offline
Old 01-18-2008, 11:12 AM   #4 (permalink)
MarkEkberg's Avatar
My Photos: (13)
2 stroke will not make smoke like that.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 01-18-2008, 04:18 PM   #5 (permalink)
hheynow's Avatar
I believe those who blend in 2 cycle oil make sure it's ash less.
1997 F-350 PSD RC LB 4WD E4OD - Plant Drive SVO kit
1984 Mercedes Euro 300D NA - Custom two-tank SVO
Using WVO and biodiesel since May 2006
hheynow is offline
Old 01-18-2008, 07:32 PM   #6 (permalink)
Banned
it don't make it smoke no more than it would with out it.
i have a 8oz bottle that i fill twice for each tank or about 1 oz pre gallon.i buy the 2 stroke boat oil from wally world by the gallon
tubzz is offline
Old 01-19-2008, 06:03 AM   #7 (permalink)
STROKER
So... The tank that is almost empty already has the oil added from the last fill up & is quiet & smooth. Now you add more oil & in 5 miles it gets quieter & smoother. By now it must be you have to look at the tach to tell if it is running since it is so quiet & smooth.
I'm thinking it's all in your head & the oil doesn't do anything that the average person can notice.
In 379,000 miles I haven't needed or added any additives to my truck & it runs just fine. Still has the original fuel pump & injectors
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline
Old 01-19-2008, 06:30 AM   #8 (permalink)
diesel97's Avatar
Try it you will like it.
2005 E-350 SRW CUTAWAY,6.0 DIESEL AUTO,ALLOYS 10FT KNAPHIEDE KUV BODY.SILVER POWER EVERYTHING.
97 F-350 XLT 4X4 7.3 PSD,99K AUTO ,REG CAB,GREEN,NOT STOCK
96 F-250 XLT 4X4 7.3 PSD 220K AUTO REG CAB,BLACK,BONE STOCK EXCEPT FOR A NEW CAR SCENT AIR FRESHENER.
http://community.webshots.com/user/Dzlpwr
#28
diesel97 is offline
Old 01-19-2008, 07:12 PM   #9 (permalink)
NO, if I run strait ULSD for several tanks and then use the oil I DO NOTICE A DIFFERENCE. My truck has a lope when it idles (old injectors) very noticeable the truck rocks and shakes. If I am running 2-stroke the truck runs a lot better. You may want see a doctor for your sensory deficit if you can't tell when your truck it running rite.
Old 01-20-2008, 04:38 PM   #10 (permalink)
I was fueling up the other day and some dude next to me told me to add 1 qrt of engine or tranny fluid to about 35 gal of fuel. he told me it would be better than any other fuel additives. I personaly dont trust him
1996 F-350,CC,LB, Rebuilt Tranny,Billet Trq conv,shift kit, AFE Stage 2 intake, 3' dp, 4''Diamondeye exh with flow through muffler, 35"BFG's,no lift,new engine wiring harness,new fuel heater(dealer fixed due to a short before I found this site,knowing what I know now I would have just unplugged it),new glow plugs at about 145,000 mi,balljoints,bearings,rotors,all new steering linkage,GPR,powersteering pump,steering wheel bearings,IDM mod,rebuilt turbo and gutted EBPV and pedestal,just over 175,000 mi,
Big Jeremy is offline
Old 01-22-2008, 07:52 PM   #11 (permalink)
whenever I change my fuel filter I refill the bowl with tranny fluid, dunno if it matters, Ive just been told it has the same flashpoint as diesel, and I dont have any diesel in my shop, dont like the idea of starting the truck with the bowl empty.
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, H2E FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (SD DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre/post turbo pyro), E4OD auto, 4.10LS, TC LU w/ ind light, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97's Photos
Big_Dan97 is offline
Old 01-24-2008, 07:36 PM   #12 (permalink)
brencoracing09's Avatar
Send a message via AIM to brencoracing09
so how much 2 stroke oil should i put in my tank to make it run smoother because i have crap injectors also and it shakes all 2 hell and is louder then normal i think
95 psd,cc,dually,long box,294k,xlt,diy open element intake,unplugged fuel bowl heater....damn that fuse 22,complete trans & tc overhaul as of 291k (first rebuild of stock trans ever)
brencoracing09 is offline
Similar Threads
Does this look safe? Sorno Towing and Hauling 11 04-26-2007 06:40 PM
Is it safe to do this? rubberducky 6.0L Power Stroke Engine and Drivetrain 13 10-11-2006 08:26 PM
Is it safe? malkiman 7.3L Power Stroke Engine and Drivetrain 1 04-25-2005 07:23 PM
So is this safe? VegasSuperDuty Upgrades and Aftermarket - 6.0L Engine 4 11-11-2004 09:36 PM
Are we safe? Roger O. Blevins News, Comments, and Suggestions 6 09-12-2000 08:08 PM
