I haven't heard that one Cary, just the Bronco rear tank which loses the spare tire if course. I think it's around 38 gals though.
96 F-350 4x4 CC LB, International block and heads from Mcandless IH in Denver, <span style="color: red">Baby Swamps </span>, Luk Cerametallic Clutch, 5" straight exhaust,5 speed ZF, 4.10's, Evolution programmer, Banks brake, non-EBPV IH turbopedestal, AFE Magnum force, CA reg. kit, 12,000 lb. Milemarker on reciever mount, 215amp ambulance alt., 33" muds on factory aluminum, Class 5 bumper hitch, hidden gooseneck, pillar gauges, fosgate amp, 12" sub.
Colorado National Gaurd.
"Firearms stand next in importance to the constitution itself. They are the American people's liberty, teeth and keystone under independece. When Firearms go, all go's. We need them every hour!"
President GEORGE WASHINGTON
Has anyone looked at installing a SD 38 gal tank in a OBS [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Cary
LOL, I was just thinking about that yesterday while I was filling up our SD. As I was filling up, I looked underneath and I don’t see why it wouldn't fit but I didn't take any measurements so I can't say for sure. I think the plastic would be a lot easier to work with also.
JIM
When my rear tank rusted through I replaced it withthe bronco tank. When my front tank rusts through I will replace with a SD tank.
Hell right with my tanks I can hold a little over 110 gals. With a SD tank that will jump to almost 130 usable gals.
When I do that I will be able to fill up with non tax, drive to MT vacation, fill up with non tax, and drive home. heh heh heh
Isnt the front tank plastic? [img]/ubbthreads/images/graemlins/shrug.gif[/img] So if you wait for it to rust out you might be there for awhile. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Jeremiah
1996 crew cab 4x4 black psd BDP 250cc hyrbids BDP fuel system Stealthhinator dual ipr hpop
H2E TDP tuning 515hp 1158tq
99.5 psd reg cab 2wd
334hp 740tq
rdrcm #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke Truck and misc pics
Jeremiah
Nope mine clangs when you hit it. The SD ones are plastic.
What would you need a gas tank for [img]/ubbthreads/images/graemlins/grin.gif[/img]??
I believe the original front tank is metal, the aftermarket ones are probably plastic.
