I've been looking at SD spring codes for a while now and think I have finally figured things out. Just want to summarize here to make sure I got it.
Front Springs -
Should be either V, W or X codes depending on how much lift you want. These can be found on 1999-2007 F250 and F350.
Rear Springs -
Should be either B or F codes. B codes can be found on 1999-2004 F250 and F350. F codes can be found on 2006-2007 F250 and F350. Not sure what the 2005s had.
Is this correct? Anyone know the part numbers for these if I were to get them from Ford? I see the Excursion guys down below are modding their rear Bs and Fs. Would this be required for the trucks?
Thanks,
Shawn
__________________ 96 Roll-A-Long F-350 4x4 Crew: 110,000 miles, built E4OD, 1.0 housing, and 3"x4" down pipe.
You got it! Modding the rear springs on a SD truck is a option for a small weight capacity and lift.
Installing SD springs on a OBS will make it ride as good as a SD does!
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
Cary
How much of a lift does the Super Duty rear springs add? I have a 3" RSK I'm putting on my 97 350 and was wondering if I could get away with doing the rear Super Duty springs to level it off instead of blocks.
Rob
'97 F350 CC XLT 4X4,4.10 LS,E4OD,228,000 miles, 285/75/16 Yokohama Geolander A/T Plus II's.
Tymar Intake, Gutted EBPV, 3x4 Tymar Downpipe & 4" straight Pipe exit in front of rear tire.3 gauge piller pod with Autometer gauges.
What is the different in the V, W & X codes? I cannot remember
Basically the amount of lift you will get. I think the X will give you +1.5" - 2" over the V. Do a search though as there is a lot of info here.
I thought the 3" RSK with SD springs on the OBS F350 would make the truck level. Meaning you wouldn't have to raise or lower the rear. I thought only the OBS F250 had to have the rear raised to sit level when doing the RSK. I may be wrong though. Anyone else?
Shawn
Rob
Nope. Going to need a 4.5" - 5" block if you are going to use "F" codes. Or stack a 1" block on top of the factory F350 block.
Did the Fs raise or lower the ride height in the rear? By how much
I can't give you a direct answer on this. I did the "F" codes the same time as I did the 3" RSK w/ "V" codes. I had a stock F350 3.5" block and had to stack a 1" block to give it a slight rake. The SD springs were all new and they will settle over time.
Originally Posted by AZStang
Do you know what effect Bs would have on rear ride height?
