hello, how hard would it be to swap out a 96 regular cab f-250 bench seat for 96 f-250 40/20/40....I've wanted to do this for a while and I found a set for $200...Thanks
will seats out of a super duty work in an OBS without much or any modification?
They'll fit, but none of the mounting points are the same. It's worth it though. The SD seats are way better than the broken down old bench seat I used to have.
The SD are very nice...MUCH more supportive...HOWEVER, one thing I never heard about before putting mine in...They sit quite a bit higher than the stock seats....I am 6' tall and I fit fine, BUT if you are much taller you are going to have your head very near the ceiling.
My truck originally had bench seats front and rear It now has 93-95 lightning 40/20/40 buckets!!! No modifications they bolted right in even in the rear!!!
Later,
DEVLYN
1996 F-350, CC, Dually, 2wd, torreador red, tinted windows, rollpan w/hidden hitch, Cervini's fully functional ram air cowl hood, Diamond cut headlights/parking lights, billet grill, 93-95 lightning front bumper/ valance, lightning buckets and center seat in front, lightning buckets and subwoofer enclosure mounted in between, 2 10" diamond audio subs, Sony Amp, pioneer head unit, Eagle Alloy series 129/130 wheels, Bilstien shocks, triple pillar pod w/ stewart-warner boost, EGT, and Trans temp, Tymar intake, Tymar HPX, BD 45h.p. chip, Fumoto drain valve, fuel heater mod, Stancor GPR,Coolant Filter, Tymar 3x4" DP, 4" back turned out before rear wheels with Stainless 4"x5" slant tip
Mods to come: I have these just need to install: banks wheel, 203 degree thermostat
Later,
DEVLYN
oH yeah ..great idea and they look great.
Ill hunt me up a few sets
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
Later,
DEVLYN
Holy crap, those seats look so good in there!!!! I'm so jealous. where the heck did you find those seats?
__________________ TheRubberDuck
1995 F350 Crew Cab 4x4 dually
Stage 2 DIY inj
RSB 140v IDM
Tymar Intake
DP Tuner 2 pos. chip w/custom switch
FPR Shim 70psi
3"dp to 4" straight piped to 5" Stacks
Hot Pedal
I miss you No.3
I paid a little over 7,000.00 for a set. But my Lightning is pretty
Originally Posted by CSXPAID
Expect to pay big money for the seats!!!!
Later,
DEVLYN
95 F350 cc, 4x4, 5sp with a short shift kit, 3.55LS, D66 turbo, Beans stage 1's inj, modded ped, IDM mod ,hx mod, DPR intercooler, 3" intakes 3" dp, 4" side out, 2piller w/boost&pyro, steering column mount w/hpop gauge, TW chip, AFE stage 1, ccv mod, DIY oil & coolant filter setups, John Deere coolant eye, ORU RSK, Black Centerline wildcats w/Hankook RT03 315-75-16 mt, One day hope to have a RockDog front bumper w/8" Hellas and a CT performance rear bumper/tire carrier, 05 SD front and rear seats.
Trying to find time to install Con O clutch, 17* HPOP Swamps fuel sys, Ford rear diff cover, Blackbird rear disc brake setup.
I have two Kids and they come first...
