Old 09-27-2007, 02:06 PM   #1 (permalink)
Shackel Reversal
Has anyone ever done the RSK shackel reversal on a F250 using the stock axel with drop down brackets, dose is smooth out the ride just as much.
chillmastr is offline
Old 09-27-2007, 03:31 PM   #2 (permalink)
PSDfreak's Avatar
Re: Shackel Reversal
what smooths out the ride is the use of SD springs...unfortuneatly on the stock F-250 front axle (D50 TTB) they require a stiffer spring pack so I dont think the SD springs would work...Just a shackle reversal without a D60 monobeam swap/SD springs; you will gain lift but not smooth the ride IMO.
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 09-27-2007, 05:48 PM   #3 (permalink)
STurbo90's Avatar
My Photos: (9)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">Do you have to have the RSK to use SD springs? I did a dana 60 conversion and rides so rough now.</div></div>
I don't remember anybody doing it that way, but if you boxed the front of the frame to move the shackle forward, I don't see why you couldn't do it.
Did you also swap to the springs when you did the swap? The ttb springs are a lot stiffer then the monobeam axle springs.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 09-28-2007, 12:47 AM   #4 (permalink)
I have Super Duty springs but no D60 are you sure SD leaf springs wont work with the TTB Axel
Old 09-28-2007, 01:19 AM   #5 (permalink)
STurbo90's Avatar
My Photos: (9)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: chillmastr</div><div class="ubbcode-body">I have Super Duty springs but no D60 are you sure SD leaf springs wont work with the TTB Axel </div></div>
which question are you repling too?
the TTB springs are stiffer then the monobeam axle springs, so everybody says that they would be too soft.
I do not have the TTB so I can't say for sure.
Going back to your op, yes it has been done, you can put the rs kit on a ttb, you would need to also use or make ttb center drop down brackets in addition to the rs kit.
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 09-28-2007, 12:33 PM   #6 (permalink)
Sorry for the confusion, I think you have already ansewered my question. I was wounderin if you could use SD springs and a rs kit with the ttb axel and drop down brackets.
Old 09-28-2007, 12:44 PM   #7 (permalink)
From what I was told when I was going to do the same thing the RSK allows for the SD springs. And you can use it on the TTB as long as you use drop brackets to adjust the offset of the lift.
And from what I hear the ride is alot smother not sure if it's because the shackles now on the rear of the front spring or because the f-250 springs in general.
BTW sorry for hijacking your thread earlier, It's kinda the same question I was going to ask but for the Dana 60 instead.
1997 F-250 CC 4x4. DIY Hybrid 530's, HPX, 5" stack, 7.3 intercooler, tymar intake, headstuds, 17* HPOP, H2E Turbo, TS 6 position chip. 4" lift 35's on 18's. Dana 60 4.11 LS. built E40D tranny. DI Fass fuel system. Motor rebuilt 02/07
http://community.webshots.com/user/Phatbulldog
phatbulldog is offline
Old 09-28-2007, 01:46 PM   #8 (permalink)
What makes the ride better is the SD springs..they are longer and the axel is almost centered on the spring. The shackel relocation without SD springs is a little improvement over stock.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 09-28-2007, 06:28 PM   #9 (permalink)
Mr. Cary not to highjack his thread again but I can use SD without the RSK correct? I'm almost thinking about getting another truck because it's riding so rough now after the dana 60 conversion. Was hoping all I had to do was get a 6" lift SD springs but will they be any better?
Old 09-28-2007, 06:44 PM   #10 (permalink)
No problem highjacking its kinda cool im learning two things at once. I think i m going to try to do the RSK with SD springs and the TTB axel. If it dosent work ill just put the stock springs back on. I know i will have to ajust for the length of the springs. It seem no one knows for sure if it will work so ill give it a try and let every onr know how it turns out.
Old 09-28-2007, 07:25 PM   #11 (permalink)
I did it to mine. Stock springs with leveling kit, 6" drop down brackets and the rsk. Worked out great and rides nice. Tom
tmtrev is offline
Old 09-28-2007, 09:11 PM   #12 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: phatbulldog</div><div class="ubbcode-body">Mr. Cary not to highjack his thread again but I can use SD without the RSK correct? I'm almost thinking about getting another truck because it's riding so rough now after the dana 60 conversion. Was hoping all I had to do was get a 6" lift SD springs but will they be any better? </div></div>
"MR" [img]/forums/images/%%GRAEMLIN_URL%%/cry.gif[/img] I must be getting old [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img].
You need to install a RS kit for 2 reasons..1 is to get the shackels in the correct spot. 2nd is since you must move the front shackel forward 4"aprox to install SD springs ya just as well do it correct...see #1
A few choices...A RS kit and SD X code springs will ride better than even Donahoe 6" springs but you would have to use a 4"+ RS kit. Best ride is with V code SD springs with a 5'+ RS kit.
Next best would be a Shannon RS mod with Donahoe 6" springs. Both will require properly valved Bilsteins...not the valving that Bilstein or Donahoe recommends but correct anyway IMO.
Cary
2006 Yamaha FJR1300
caryt is offline
Old 09-28-2007, 09:41 PM   #13 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> Both will require properly valved Bilsteins...not the valving that Bilstein or Donahoe recommends but correct anyway IMO.
</div></div> I've been paying attention to what you have to say for a while, but I must have missed this detail. Is this where you mention getting Excursion shocks?
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 09-28-2007, 09:50 PM   #14 (permalink)
BadDogPSD's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: garbage_mechanic</div><div class="ubbcode-body"> <div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> Both will require properly valved Bilsteins...not the valving that Bilstein or Donahoe recommends but correct anyway IMO.
</div></div> I've been paying attention to what you have to say for a while, but I must have missed this detail. Is this where you mention getting Excursion shocks? </div></div>
I was wondering the same thing. I've noticed the way Cary has worded this lately... properly valved Bilsteins. Cary????
1997 F250 4x4 Crew Cab PSD; Dana 60; Sky RSK w/SuperDuty springs.
BadDogPSD is offline
Old 09-29-2007, 12:41 PM   #15 (permalink)
I have been doing extensive testing with valving of Bilstein front shocks and IMO what Bilstein and Donahoe recommends is incorrect for a OBS or a SD.
Useing shocks valved for Excursions didn't pan out and they require the same valving as pickups
Please PM me for info...forum rules.
Cary
2006 Yamaha FJR1300
caryt is offline
