Old 11-02-2007, 11:12 PM   #1 (permalink)
DIESELDUTTON's Avatar
Slight Wheel Wobble Sometimes ?
After installing my 35's I notice when I hit a bump I will get a slight wobble, it doesnt get bad and goes away, I do have a stock steering stabilizer. Is a dual stabilizer or a heavy duty stabilizer a must, or is something else wrong? I know back in the day I had a good old Chevy with 33's on it and the first time it happened I thought the whole front of the truck broke off and I ran it over [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img] the only way to get it to stop was to pull over, come to a complete stop, then take off again, I added a stabilizer and never had a problem again. I tried both stabilizers that I have, the one thats on it now came off of my D-50 it was about 6 months old. I dont see any play in the steering system, but I dont like the angle that the stabilizer is on, its not parallel to the tie bar, if I get it parallel the bracket hits the cover on the diff if I'm hard over to the left. Any idea's ? Thanks Guys
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 11-02-2007, 11:41 PM   #2 (permalink)
Re: Slight Wheel Wobble Sometimes ?
before i put my stabilizers on my truck used to act just like your chevy did. it was so bad i almost traded it for a SD. after i put it on the truck feels 100% better. with my kit i had to flip it so the shocks ran behind the steering linkages. this is because of the skidplate. the angles on mine were not really flat so i got out the angle grinder and cut out a notch in the crossmember. also i figure once the bushings wear in i can readjust it to where its centered again. i am not sure if this will work with your truck as its 4x4, but i thought i'd share it. i just uploaded pics so go ahead and take a look
My F-250 HD
1997 PSD F-250 HD 2wd ex-cab longbed prerunner. 4.10 LS rear. Edge Evolution. BDP electric fuel system. 3'' downpipe to 4'' out. 0.84 Turbo Housing. HPX mod. Gutted EBPV. Tymar intake. 3rd E4OD. B&M deep transmission pan. 4'' Fabtech lift on 35s. Bedcage toolmounts. Prerunner bumper with skidplate. SS brake lines. Flipped steering stabilizers
thegreg92 is offline
Old 11-02-2007, 11:54 PM   #3 (permalink)
Thanks, My stock stabilizer is small compared to yours. I'm gonna look into a dual stabilizer, I have not seen a dual setup like the Super Duties run, the ones that I have seen on the SD have one on each side, instead of stacking them on top of each other. Thanks again
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
Old 11-03-2007, 01:19 AM   #4 (permalink)
Believe it or not, the air pressure in the tires can contribute to the wobble.
1995 F-350 XLT DRW
212,000+ miles
3" down Pipe
4" AFE Exhaust
No muffler
DIY TYMAR
DIY IDM mod
DIY Injectors
DIY Water Injection
DIY HPX
BB mod
Tony Wildman Chip
17* HPOP
6.0 IC
HID headlights
Gauges: Pyro, Boost, Trans
John Wood Trans with a 6.4 T/C
Truck Pics
Wish List:
DIY Stealth
DIY Fuel System
D66 Turbo
Rudolf_Diesel is offline
Old 11-03-2007, 10:04 AM   #5 (permalink)
Thanks, I will double check the pressure.
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
