soft shifting or not at all into overdrive ! - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 03-01-2009, 09:45 PM   #1 (permalink)
mrmouse2006's Avatar
Strange problem after looking through post i have not read any thing like this .
the trans shifts well first 60 miles (not towing) once warm has difficulties shifting it to overdrive . when disengaging the overdrive you can see the rpm change aprox 200 rpm and hold engine rpm when throttle pedal is released .
when reengaging overdrive the engine rpm drops to idle when throttle pedal is released and will not engage.
when starting off and accelerating very slow it will shift fine aprox 80% on the time . I'am getting no codes and have replaced the tps and checked all connection. sometimes accelerating quick seams to help pos.pump pressure increase ?
this started doing this about six month age after overheating while towing (lost trans temp gauge while someone else was driving ) but was always triping different code primarily pressure differentl errors.
I just had the trans rebuilt. and it is still doing it without out the codes
P.S I also have a banks trans comand but its been on it for five years .
Thanks for any suggestion
1995 PSD F-350 crew cab 4x4, with 97 engine, stage 2 injs ,EBPV delete ,price racing e40d w/ precision three disc converter ,ORU Reverse Shackle kit, tms shackle flip on rear ,excursion springs , wildman 2pos chip, down pipe, 4 inch straight pipe,superduty intercooler with banks pipe kit ,superduter trans cooler ,magna flow ,boost,trans and EGT gauges, kumo A/T's 305-70's, Bilstein's, ditched the k&n filter for an open element Baldwin PA 2818, sony & polk audio sound system,2006 chey silverado seats.450+hp at the rear wheels priceless
“Political Correctness:
A doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
mrmouse2006 is offline
