Some direction Please - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 02-21-2008, 06:17 PM   #1 (permalink)
metrojd's Avatar
Talking Some direction Please
I am in the process of putting a 96 PSD in my CC in my sig.
Can anyone give me any advice on what would be suggested to do meaning up grade maintence or?? before I install it.
As in which down pipe to get,And mods that would be easer to do with engine out.
I appricate any advise.
John
93 F350 CC 4X4 7.3,ZF,Gearvendors
metrojd is offline
Old 02-21-2008, 07:20 PM   #2 (permalink)
Feedback Score: 3 reviews
John
there is a lot you can do, depends on how much $$$ ya want to spend.
defianatly do the up pipe, pull the exhaust manifolds and replace bolts and add gaskets.
replace the HPO rail plugs in the rear of the heads, reoring the injectors, replace glow plugs/check harnesses, rebuild oi;l cooler, replace low pressure oil pump, put a SD tensioner and serp belt on, replace water pump, replace fuel pump and lines, .
as for the Down pipe, its easy to modify the fire wall with the engine out.
Dads ride 2002 Dodge 24v, dual exhaust, edge comp hot box. tst 40 hp injectors,Piers B-1 turbo dipricol white face a pillar gauges, Suncoast triple disc and valve body occasionally he lets me drive it. 393 rwhp, 807 ftlbs
1996 F-350 CC swr, long bed , 4x4 PSD zf-5, 260k.Swamped, 5" black stacks, dipricol gauges, 30+PSI boost, DP tuner chip, 349rwhp.
95 PSD project fixes it up and then sold it
03 7.3 4R100 4x2(for now) 240k stock cept for duals 20th aniversary edition.
early 99 CC Dually,
finallygotanIDI is offline
Old 02-21-2008, 08:03 PM   #3 (permalink)
metrojd's Avatar
Talking Thanks
Nick,
thanks for the response.
Are these oil cooler pretty easy to rebuild??
Were is the low pressure oil pump Is that the one in the pan??
Is ther a special SD pulley to use??
What kinda fuel pump should I get ??
The up pie thing is that the gaskets or a differant pipe?
John
metrojd is offline
Old 02-21-2008, 09:57 PM   #4 (permalink)
-LP oil pump is on the front cover, behind the harmonic damper.
-SD tensioner number is F8UZ-6B209-CA, (don't remember the belt number at the moment. Mounting does require minor modification to the pass. side acc. bracket. Just search for the 'dual tensioner mod')
-Oil cooler isn't too tough to do. It helps to have a pipe clamp to push the end caps back on, though.
I would also add that now would be a great time to make sure the oil pan is completely rust free. Maybe give it a couple of coats of POR15 (or your rust proofer of choice.)
-RD
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
webshots
RD97 is offline
Old 02-22-2008, 01:34 AM   #5 (permalink)
metrojd's Avatar
Talking Thanks
RD,
John
metrojd is offline
