Old 02-27-2007, 11:05 PM   #1 (permalink)
brahamfireman's Avatar
Sonix valve shifts too hard.
put a Sonix valve and Tri springs from Tymar in my buddies truck about a year ago and he is sick of the hard shifts, and I mean hard, full throttle will almost break the seat back, pulling the 6 place sled trailer we thought we were gunna snap something.
Is there any way to soften the shifts slightly, it doesn't seem to matter if the chip is in the truck or not there still hard shifts.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
Old 02-27-2007, 11:13 PM   #2 (permalink)
Fordpowrstroke73's Avatar
My Photos: (6)
Send a message via AIM to Fordpowrstroke73
Re: Sonix valve shifts too hard.
I've allways been told that if it shifts hard then there's less clutches slipping so reduced wear in the transmission. I wish my truck would shift that hard! But I think also that it could be a bad thing to an extent. I would say that you could put a softer spring in to soften it up.
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
Fordpowrstroke73 is offline
Old 02-27-2007, 11:19 PM   #3 (permalink)
Old_Machinist's Avatar
Give Jon (Richter69) a PM. He has played with enought of those units to quote chapter and verse on what it takes to make it shift the way you want.
96 Ford Powerstroke, Centarus Converson CC, 4.10, Long bed DRW, 4 pos TWildman chip, SD HPOP, 6.0 Intercooler, 3.0 downpipe and Bully Dog 4.0 exhaust, AFE intake system, pyro (pre turbo),trans gage (located in test port), Custom Fabion Motosports Torque Converter, pump mods, Tugger trans kit, Torqueshift tranny cooler, Firestone air bags, Rancho RX 9000 adjustable shocks, and baby SWAMPS!!
Pulling a 2000 American Star, 34RLCK bedroom and living room slides, w/d stack ,12,640 lbs.
Total weight 19,300. New addition 20ft VIP Bowrider boat towed behind 5th wheel, total length 74 ft, 24,000 lbs!
Old_Machinist is offline
Old 02-28-2007, 01:43 AM   #4 (permalink)
So you are saying that it has shifted that way since you put the kit in, were there any springs already in there of similar size to what you put in? I have heard that on some trucks you remove some springs when you put the tricums in? [img]/ubbthreads/images/graemlins/confused.gif[/img]
I wish mine shifted that hard..........
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD Powered By 2L Motorsports and SWAMPS.
Mods: AM Ultra-Lites, DiPricol HPOP gauge,TS/2L Moto Chip, 4" Straight-Piped, Poor boy's intake, Swamps II's, BTS, 285 BFG A/T's on factory Alcoas. Lots more to install, see below!
On the bench: AirFlo S400, Swamps 275's, Studs Rods and Springs for the top end, and some other stuff.
My Pictures
DD- SILVER 11/97 F350HD XLT RCLB Auto 3.55LS 4x4 OFFROAD
Mods: Redneck straight-pipe, TS/2L Moto chip.
smokyred is offline
Old 02-28-2007, 02:11 AM   #5 (permalink)
Nit
it should shift fast, not so much as hard, sounds liek it is too hard for any good, bet a spring was missed or not removed, better go over it again.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 02-28-2007, 10:15 PM   #6 (permalink)
there was soemthing in the instructions about certain '97 models having one spring and some have two [img]/ubbthreads/images/graemlins/shrug.gif[/img], this one had one spring so we just replaced the springs like so.
its like this in all gears, and I know we didnt miss a spring.
light to normal throttle is fine, he is kinda wussified and doesn't like the hard shift all that much, but full throttle is just too much.
Diesel Rod
Old 02-28-2007, 10:40 PM   #7 (permalink)
My Photos: (5)
put the stock .372 line mod valve back in, or take the tri springs out and leave the sonnax valve. Which size valve did you use? it should have been a .427, if it was the .500 put the stocker in. Honestly those springs are too damn stiff, if the stock ones alone are too soft get a transgo hd2 kit and use the springs from it alone with the plate provided and start on the small side with the holes and enlarge them if its too soft. You will need to pull the line mod out anyway to drill 2 small exhaust holes in the casting. Or one could get another vb done [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
Old 02-28-2007, 10:46 PM   #8 (permalink)
it was the .427 valve, I believe that is what comes in the Tymar kit. I have never seen a Tymar Kit say to drill the exhaust hole. I put one in a buddies truck from Bully dog and there's said to drill two exhaust holes, so we did and his truck never shifted right after that, it eventualy grenaded. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
I'll see if we still have the stock valve and try that, thanks
Diesel Rod
Old 02-28-2007, 11:27 PM   #9 (permalink)
My Photos: (5)
the hole drilling is for the transgo stuff only. If its got the .427 the smaller valve will be a minimal effort, you might remove the tri springs but then it may be too soft, you could cut the tri springs down, say in half.
1999.5 cc dually
Old 02-28-2007, 11:41 PM   #10 (permalink)
I had thought about shortening the springs too, you think that will be the best bet to shorten the springs??
Diesle Rod
