Which South Bend Clutch for me? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 10-05-2008, 02:05 PM   #1 (permalink)
Well,
It is getting to be clutch time for my 94. I cant decide between the con O or the FE? I will be adding intercooler, stage 1's and a chip- however I use the truck almost exclusively for towing/ hauling and some hunting on back roads. I want smooth-not grabby. Will the the regular Con O be sufficient or should I do the next one up the line(FE).?
1994 F250, Tymar, Tuff country 2" lift
lomile94 is offline
Old 10-05-2008, 10:30 PM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
With Stage 1's and a chip (and towing with them), you might want to go for the Con-OFE. The Con-O is supposed to be good up to 350 HP, but maybe you want some wiggle room? Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 10-06-2008, 08:51 AM   #3 (permalink)
I am still a little concerned about the OFE- I back the #8000 trailer a bit. I see quite a few people have the Con O with stage 1's. Any other opinions?
lomile94 is offline
