Old 12-15-2008, 12:17 PM   #1 (permalink)
Speaker Size?
I have a 97 f250 extended cab and i was looking to get some new speakers. Are they 6 1/2 in the front and 5x7 in the rears?
1997 F250, Ext Cab, Long Bed, 4x4, E4OD, 140K, AFE Stage 2 Intake, 3" DP, 4" MBRP Straight Pipe Exhaust
BMoreRvns20 is offline
Old 12-15-2008, 12:40 PM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
All 6.5 rounds are not 6.5, if you get what I mean.
The rears are not 5x7. They are some wierd size like 4x6. With a little cutting and bending you can fit a nice 6.5 in the front (which is larger then 6.5) and actual 5x7 in the rear. The rear is a little tricky to fit in there. It will look a little crappy until you put the plastic back on, but then it looks great.
Make sure you get 3 way speakers. They sound much better than the stock 2 ways.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 12-15-2008, 01:35 PM   #3 (permalink)
ChrisMartinTX's Avatar
My Photos: (6)
hmmm... crutchfield says 5x7 for rears in ext cabs, but the 6x8s for reg & crew cabs. i have installed speakers in all the configs of obs cabs & all had 6x8 rears.
that being said 6x8 is a fairly terrible sounding speaker unless you put an amp to it. it wants to think its a big speaker, but can't handle low freqs like one. i would get an adapter & a higher quality round speaker for the rears if i was doing it again... or if i could ever blow these things.
a little 10" with nice 6.5" all the way around would sound pretty good =)
97 F-250
Specs
ChrisMartinTX is offline
Old 12-15-2008, 02:23 PM   #4 (permalink)
jspd234's Avatar
my 97 standard cab has jbl 2 way 6.5" rounds in the door and and jbl 2 way 5x7"s in the rear corner panels. i have an kicker 8" sub in a wedge enclosure with a kenwood bridgeable 200 watt amp. jvc el cameleon amfmcd player. plenty of power from the head unit. sounds great! if you have the stock stereo it will not sound good. it does not have enough power for aftermarket speakers! its all about how much power you feed to the speakers.
06 F350 xlt sport fx4 srw lb cc 6.0 at afe pg7 cai & accufab polished power elbow zoodad. 4" turbo back exh -mufnkitty. readylift 2.5" leveling kit + 1"rear block on 17" atx teflon thugs 33" bfg at's. jvc cd dvd sirius head unit with 4 infinity kappa speakers 4 channel infinity amp 10" jl console sub 500 watt jl amp microvision dvd & headrest monitors 4 the kiddies in back!
01 chevy monte carlo ex-nascar southwest tour car raced in the american stockcar challenge(2007 champion!!)
02 sanger V210 black scorpion 330hp 2 fat sacks proflight tower 4 infinity 6x9's rf400 watt amp 12w7 jl sub rf 1001bd clarion amfmcdsirius head unit 4 clarion marine speakers 5 ch hifonics amp 10" bazooka sub encl firing a jl 10w3
02crf450
93jetski750sx
95waveventure760
07 international 4300 dt466 allison century 612 wrecker alcoa's
04 ford F650 xlt supercab 4dr cat C7 allison century 21 ft steel carrier alcoa's
97 ford F450 xlt sd 7.3 5 spd century 412 wrecker
jspd234 is offline
Old 12-15-2008, 03:17 PM   #5 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Nevermind what I said before........
I was thinking a 6x9 was a 5x7. Anyhow if you work at it you can get the 6x9 to fit in the rear hole.
Old 12-15-2008, 04:58 PM   #6 (permalink)
My Photos: (54)
I put 6 1/2" in the front with a little massaging of the opening for them to fit.
I did buy 6x8 (factory size) for the rear, the 6x9 looked like it would need too much modification of the hole to get in for my taste. The 6x8 Pioneers have done very well for me the last 6 years.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, 286,000 miles, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, 36" tall ARE contractor cap. With tools, full of fuel and me on board (300 lbs) GAWF 3620 GAWR 3860 GVW 7480.
Believer45 is offline
Old 12-18-2008, 01:54 AM   #7 (permalink)
CVB Fireman's Avatar
i just put new 6x9's all around the rear was easy and the front just took a little bit with a jigsaw it sounds awesome the smaller speakers just didnt do the job in the front,,,,, i would run to circuit city before the shut down and buy the POLK 6x9's they are insainly awesome
f-350 4 door long bed. 6 speed. 5 inch stacks. 9 inch lift. 40 inch Ground Hogs. custom Front and rear bumpers with 10,000 Warn WincheSSSSSS.K&N TW chip, stage 1s, IDM mod, exhaust brake. limo tint. peterbilt cab lights. dvd screen 2 shallow fosgate 12s (sick!!) and everything else you can think of. damn ive spent way to much money on this truck.
Waller
CVB Fireman is offline
Old 12-18-2008, 11:18 AM   #8 (permalink)
My Photos: (6)
polk FTW & if you don't mind throwing in an amp polk momo!
97 F-250
Specs
Old 12-18-2008, 12:53 PM   #9 (permalink)
first off thanks for everyones input. would it be worth it to try and fit 6x8 in the front or is it not worth the time and effort?
Old 12-18-2008, 01:13 PM   #10 (permalink)
My Photos: (6)
you will get better sound out of a nice pair of 6.5" over the 6x8s. 6x9 is an exceptional speaker, but for the most part round speakers out do their oval cousins.
97 F-250
Specs
