Old 01-30-2007, 06:42 PM   #1 (permalink)
Spray Vs. Propane
My truck is in my sig and I was thinking about putting in something to give me a bit of an edge, I will most likely be running stage 1s soon enough also. What are the tips/tricks about installing either of these, and also how do these systems run in out trucks? What about methane injection also?
1997 F-250 Heavy Duty PSD
101K Mi, 4X4, Supercab, 3.55's, E40D, Shimmed FPR, 10K Mod, DPP 3" Downpipe, DPP Cat Delete pipe, Open air element Intake, TS Six Position Chip, PSDan's Modified IDM. 2 New Everstart Maxx Batteries (10/23/06) Replacing original motorcraft batteries!! (10 Years)
Foxtrot Uniform Charlie Kilo
Webshots
Matthew311p is offline
Old 01-30-2007, 07:27 PM   #2 (permalink)
Re: Spray Vs. Propane
better build that tranny if it aint already before anything. then i would do the injectors first. more edge for alot less money if you go diy. i have been thinking about water injection also though
1996 f-250:115000miles,h2e,6.0 ic,3" intakes,studs,beefed-up e4od,4.10ls,add-a-leaf,straight pipe to one 5" stack,guages,diy intake,ccv mod,17*hpop,315/75r16 buckshots,170cc stage 2 diy injectors,wildman 4 pos. chip,timbrens
1969 mach 1 mustang
1965 Ford 4000 tractor:cone filter, 3.5" stack, mack truck nozzles(220cc), pump turned up
Sophmore at Bridgewater College
CURSURI SUMMUS NUDI!! latin for we're going streakin!!
http://community.webshots.com/user/machdriver69
jasonlambert is offline
Old 01-30-2007, 08:07 PM   #3 (permalink)
If I were you I would try out some bigger injectors and some custom tuning first. That may change your mind about wanting NOS or propane.
Also like previously stated if your have your tranny built right it will also give you a huge performance gain
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
bosefes is offline
Old 01-30-2007, 08:46 PM   #4 (permalink)
Way before going to gas...to much risk IMHO, get normal HP mods. What edge are ya looking for? What are you trying to beat?
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 01-30-2007, 08:50 PM   #5 (permalink)
I've driven trucks with bigger jectors and i still feel like the truck lacks power in the mid range and on the highway, I'm just looking for something to pick it up in that range
Webshots
Old 01-30-2007, 08:55 PM   #6 (permalink)
Simple fix for that...Stealth [img]/ubbthreads/images/graemlins/blush.gif[/img], really get some 2's and and ya won't complain.
Cary
2006 Yamaha FJR1300
caryt is offline
Old 01-30-2007, 08:59 PM   #7 (permalink)
i need a reliable truck all the time, thats why i was thinking spray or propane so i could just have the power when i needed it, and I have heard that past stage 1's and you start having to worry about reliabilty but i assume i could probably just use a multi chip and change the program when i need the extra power
Webshots
Old 01-30-2007, 09:18 PM   #8 (permalink)
I have never heard of a relibility problem with the engine....auto and stick cluches, well hell yes !! [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Cary
2006 Yamaha FJR1300
caryt is offline
Old 01-30-2007, 09:28 PM   #9 (permalink)
doesn't 2's mean buying a fuel system and oil pump and head studs and lots of other fun stuff
Webshots
Old 01-30-2007, 10:56 PM   #10 (permalink)
tjbeggs's Avatar
improperly used drugs means buying a whole lot more than a fuel system, big oil and studs! Long blocks aren't cheap!
1997 F-350 CC LB 4x4 Auto, AD's, Chip, IC, 4Wh. Disk Brakes, and other stuff
Truck Pics
tjbeggs is offline
Old 01-31-2007, 12:06 AM   #11 (permalink)
Nit
hell suck it up and buy some hybrids, the extra money is offset by beign able to use stock everythign else, plus after a chip , you will toss any gas system you installed before. Powerstroke2000 layed down 390hp at BD's dyno with stock fuel ,oil, and turbo.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 01-31-2007, 12:12 AM   #12 (permalink)
Need to get these guys fooling with reverse hybrids to expound on there findings. I have stage 1s I did not have a trans. I did injectors and a pretty agressive tune I now have a 4r100 and a P.I. stallion converter.I will be getting oil soon,If you do end up with some hotter inj. consider an intercooler. I will tell you this my truck is now reliable and a real kick in the butt to drive. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
97 F-250 H/D 4 door 4X4 6'bed.Broke block building new engine! Oh well it ran14.96 at 89mph at Baytown!
Kenworth T-600 aerodyne 3406c CAT, with 18* "B" modle injection pump(was a freakin peak yuk),10 over trans,4.10 rears,Dual 150 gal. fuel tanks,Budwieser inspired custom hot rod flames.Going to work real soon Leasing to Landstar yeah!
89 mustang coupe single turbo 302 ,built c-4,running little rubber.
I hate Dodges, straight piped common rail cummings sound like crap!
Aljay is offline
Old 01-31-2007, 10:50 AM   #13 (permalink)
You dont want to use spray all the time, it will get very expensive. I pay 4.25-4.50 per pound and use somewhere around 1.5 lbs per 1/4 mile run with a small/med single stage system. Maybe go with some stage 1 or 2 injectors, beans bolt on turbo and like mentioned above tranny mods. If you go any larger than 2's you will most likely need to upgrade fuel system and add headstuds.
ford pinto with spinner hubcaps from walmart- big pimpin
Thunder_struck is offline
