Old 08-25-2008, 11:42 PM   #1 (permalink)
Stacks with a cap.
Here's a thought I've been having for a while now. I'm wondering if this is possible. I've got a cap on my truck and want to put a set of stacks on it. My wife uses my truck frequently hauling stuff back and forth to craft shows so heat would be a big issue here. I want to bring the stacks up through the bed and up through the top of the cap. Now here's where it gets iffy. If I wrap the stacks with a heat shield kind of like the firefighter suits are made out of and then make fiberglass tubes to cover the stacks all the way down to the deck and then put say some bullhaulers on or straight tips with rain covers on them. I'm wondering if the heatshield would hold up to long road trips and if the heat would build up inside the cap. Just a thought.
1997 Ford F250 Crew Cab 4x2 with 7.3L. Tymar Intake, Bores bumper guides, J.C. Whitney chrome cab lights, Steel Horse Stainless Steel grab handles, Hornblasters 3 chime chrome train horns, 3" to 4" downpipe/5" exhaust into a Walker BTM/6" polished Stainless Steel tip. ISSPRO boost/pyro/tranny A-pillar gauges. Pioneer AM/FM/CD player, Polk speakers, kicker amp and 12 inch sub behind the back seat. DP tuner F-5 chip with stock,80hp tow,80hp econo,100hp, and smoke programs. Sonnax/Tricumulator valve and springs transmission shift enhancement kit.
My truck pics
SkidRowe38 is offline
Old 08-26-2008, 12:02 AM   #2 (permalink)
Squid63's Avatar
Send a message via AIM to Squid63
I had a friend do it on a truck once. It never looked quite right (looked fine with stacks and no cap), and heat was an issue. I would say either one or the other, but not both.
94 F250 Supercab 4x4, 7.3 IDI Turbo, NV4500 5 speed, 4.10s
95 F350 Crew Cab 4x2, 7.3 DI, ZF 5 speed, 3.55s
Squid63 is online now
Old 08-26-2008, 10:24 AM   #3 (permalink)
My Photos: (6)
How about get a shorter cap so you can remove it without pulling the stacks. And fill the space between the stacks with diamond plate?
97 F-250HD Super Cab 4X4
Jasper E4OD, 3.55 gears
Auto Meter Dash Mounted: Trans temp, Boost, EGT, Oil Temp, Oil Pressure.Water temp. Gauges. http://photos.thedieselstop.com/show...t=1&thecat=500
Homemade Open Air Filter, 3 in SS DP, SD, 03 Intercooler. GTS kit. Modified Pedestal, ITP SS HX, CCV Mod, BABY SWAMPS & SWAMPS 6 POS Chip, 17 Deg HPOP, Gutted EPBV, Jasper Stage 1
250,000 Miles, and still going Strong.
TSM Disk Rear Brakes
Cratos is offline
Old 08-26-2008, 11:22 AM   #4 (permalink)
Fordpowrstroke73's Avatar
My Photos: (6)
Send a message via AIM to Fordpowrstroke73
I've seen a Dodge with a cap and stacks but I don't know how he did it. He was dragging the truck so it probably got pretty hot. If I were you I would just save my $$$ for something else.
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
Fordpowrstroke73 is offline
Old 08-26-2008, 04:55 PM   #5 (permalink)
Here's what I think. Just do the stacks inside the cap, and crack the back window. You'll have to cut a small hole in the bed floor and attach a chain to the driveshaft, hooked to a roterissie. Then, buy a hog and while driving you can smoke your own meat.
Seriously, it's a bad idea. You'll never get it to work properly and probably ruin a good cap.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
Old 08-26-2008, 05:25 PM   #6 (permalink)
Yeah. Just trying to make two people happy instead of just me. Thanks for the input fellas
My truck pics
Old 08-26-2008, 05:32 PM   #7 (permalink)
You haven't been married long have you?
1996 Town Car
Old 08-26-2008, 05:33 PM   #8 (permalink)
Not unless you count 20 years as not long.
My truck pics
Old 08-26-2008, 05:52 PM   #9 (permalink)
fireguywtc's Avatar
The firefighter suit material will [i]not[i] work as a heat shield. The heat can still transfer, and believe it or not, the shell can even burn if heated enough. Most of the thermal insullation comes from a thick liner inside the suit. There are other type of heat wraps I have heard of but not sure how they would work for this application.
07 F-350 xlt 6.0 PSD LB CC SRW 4x4, black on tan, A/T, 5" exhaust 4" downpipe, SCT livewire, S&B CAI, the rest is good from
fireguywtc is offline
Old 08-26-2008, 06:24 PM   #10 (permalink)
A guy who used to be on this site (Kainers) had such a setup a few years ago. You might try to find him on one of the other Powerstroke sites (he always uses the same username) and ask him about pros and cons. I think he finally pulled the cap (canopy) off when he bought a gooseneck trailer, but he ran it for a while.
Regards,
Michael Pliska
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 255k miles (Ford rebuilt E4OD at 226k)
ISSPRO Prototype Performax gauges, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Edge Evolution on "Tow", Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
1998 S&S 9.5' slide-in camper
33' enclosed tag trailer with 2 doorslammer drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
NRA member and certified firearms instructor
GOA member
IDPA member
MJPliska is offline
Old 08-26-2008, 08:36 PM   #11 (permalink)
PSDfreak's Avatar
I think that is a picture of Kainers truck...I took it a couple of years ago up at a sled pull in Tule Lake, CA
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 08-27-2008, 12:02 AM   #12 (permalink)
What I have thought of but never seen done is to mount the stack outside the bed like a Peterbuilt using chrome heat sheilds. I think it might look pretty cool on a dually, and no holes in the bed. Not sure on a srw truck but it is an idea. I agree it could be done but not worht it through the shell. If you insist on doing that use a pipe in a pipe with airspace between and the ability for air to flow through the gap.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 08-27-2008, 09:43 AM   #13 (permalink)
I'm just being a smartass anyway. Ignore me please.
I've been married just over four years and it was the best thing I ever did. We have a three year old, a one year old, and a baby. My life would be really empty without the four girls in my life.
1996 Town Car
Old 08-27-2008, 10:09 AM   #14 (permalink)
Yup, that's his truck! I'm pretty sure he still has that canopy, but he bought a big 5th wheel horse trailer with living quarters, so off came the canopy. He also changed to a single stack at some point IIRC.
He'll definitely be at the NHRDA Nationals in Medford Sept 6-7, that's a good reason to make that race
There is a maroon late model Dodge which runs the midwest pulling circuit (and is also show quality) which has its stacks molded into the side of the bed. I'll see if I can find any photos.
Regards,
Michael Pliska
GOA member
IDPA member
MJPliska is offline
Old 09-03-2008, 11:19 PM   #15 (permalink)
I was gonna ask if it was a dually, mine is and I want to run 8 ft straights up the side of the bed, does anyone know what parts work the best or are we on our own?? I have a fuel tank in my bed and think the outside stacks will look better and more like the big truck look and not funny like those short 36" stacks.
96 F-350 SuperCrew Dually,Hypertech programer, BD Performance Exhaust Brake, Taylor Wing, Stainless Trim and Running Boards, Trans Flow Systems Aluminum Diamond Plate 100 Gallon Auxillary Fuel Tank, Jasper Transmission, Billet 1800 stall converter running 2 trans coolers with 3/8 braided cooler/trans lines.
jcarter8968 is offline
