Old 02-28-2007, 11:17 PM   #1 (permalink)
Stacks or No Stacks
I was thinking of putting some 5 inch miter cut smoke stacks on my truck but now I'm not to sure. I have a 4 inch MBRP exhaust and love it but the stacks would look awsome. I have a tool box on the bed and don't know wether it'd be worth shortening the bed for some look rather than functionality. Not to mention that smoke stacks are just that... SMOKE stacks. And with this new Ultra Low Sulfur fuel I haven't been able to get her to smoke as much as she used to.
7.3L, Performance Chip, MBRP 4" straight exhaust, K&N intake, 33" tires
jimc50cop is offline
Old 02-28-2007, 11:43 PM   #2 (permalink)
Re: Stacks or No Stacks
Stacks are cool and get some bigger injectors...then you'll blow some smoke, just don't be excessive [img]/ubbthreads/images/graemlins/grin.gif[/img]
1997 F250 Regular cab 4x4, '97 12V, 911 pump, 4KGSK, L/C DV's, studs, o-rings, 435's, HTT Pro Street 66/71/13SS, Cool Twist 6L I/C, 7" Aussie stack
Next up: Home built trans!
My Stuff
BigWhite96 is offline
Old 03-01-2007, 12:05 AM   #3 (permalink)
brahamfireman's Avatar
yes, do it, you wont be disapointed.
I have ALOT of pics of both trucks, here
check em out, and what do you have for a chip I can still get mine to smoke with the chip adn ULSF.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
Old 03-01-2007, 12:21 AM   #4 (permalink)
I, for two, want stacks but my problem is the noise, not so much as the loss of bed space. I went for a ride in a buddy's Dodge, he had 5" mitres and that Cummins talked. His cab noise was minimal, but I'm sure the newer trucks have better sound dampening as opposed to our trucks. I'll give it some more time, if I still want them after a year or so, I'll go for it.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 4:10 * cc/lwb * RSD Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP 1.0 exhaust housing * Hypermax 3x4" dp * Authentic Tymar intake * gutted ebpv * 4" exhaust & 5" tip * AlumaCraft diamond plate toolbox * custom antenna mount (108" whip) * Uniden cb * diamond plate bed rail caps * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25 * ccv mod * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * poly bushings (front) * Rancho RS9000 shocks * dual steering stabalizer * 60,279 on rebuilt engine (myself) as of 1/08
To do list:IDM mod
94strokerace is offline
Old 03-01-2007, 12:46 AM   #5 (permalink)
I plan on getting a set from http://www.blackclouddiesel.com/. If your worried about noise they offer muffler inserts.
Mike
96 extended cab short bed. 4x4 manual trans. Home made tymar intake. Straight exhaust. No other mods. Would like to get some stacks, air horns and a chip.
captmike13 is offline
Old 03-01-2007, 01:04 AM   #6 (permalink)
Ya i say do the stacks i just went from a four inch exhuast to stack and i love it. I to was worried about the noise in the cab one of my friends has a 91 cummins with a stack in it and you cant talk to each other in the cab cause it was so noisy but mine with the windows rolled up sounds just as quite as it did with my other exuast on, but with the windows down it sound a hell of alot meaner. I love the way it sounds that and i just plain love blowin two big streams of smoke straight up in the air. I to have pics of my stacks in my webshots
96F-250 4x4 Red Ext Cab
DP Tuner F-5 6 pos chip
Autometer 3 Pillar guages
Industrial Injection Hybrids
City Diesel custom 6.0 intercooler
AFE Stage2 magnum force intake
Garrett GT38r ball bearing turbo
Custom Fuel System
CCV Mod
HX Oil Mod
4.10 rear end
Built E4OD
Custom 5" exhuast w/stacks
4" lift
35x12.50x16 BF Goodrich All Terrains
close to 500hp gunning for 600hp
http://community.webshots.com/user/robs96stroker
robs96stroker is offline
Old 03-01-2007, 01:31 AM   #7 (permalink)
I had the same concern a while back. I posted about it and recieved some good info/suggestions. Click on my user name and look back through my posts (some time ago) and enjoy. I had plans on turning my box around, clipping the corners off, rebuild and install inbetween the stacks. No loss of space, but the disadvantages are obvious. Like you, that void where the stacks are would drive me up the wall.
Randy
To do list:IDM mod
Old 03-01-2007, 03:38 AM   #8 (permalink)
AlaskaRedneK's Avatar
YES, do it.
Stacks on OBS' look great [img]/ubbthreads/images/graemlins/cool.gif[/img]
Smoke
Stacks
-Matt
'97 F-350 CC/LB 7.3L PSD 4x4 4.10's, ~111K miles/ 3-4" Down Pipe hooked to 5" Turnout Stacks, Isspro EV Guages, Tymar, 6 pos. Northern Diesel Performance TS Chip, 7.3 IC, gutted stock fan- w/ single electric fan, Stage 3 DIY Hybrids
In the garage: RacerX Tranny kit, headstuds, 910s, pushrods
Next: New TW tunes!
AlaskaRedneK is offline
Old 03-01-2007, 06:58 AM   #9 (permalink)
Diesel Rod
I have a Diablo Flip Chip that I keep on Performance all the time, it's like 100hp gain. But when and if I get the stacks how do the people at the emissions test check it then. I laughed before when they were having a hard time putting the sniffer on the MBRP 5inch tip. And I also see a lot of guys with the miter cut without rain caps, what happens when it is pouring rain and I don't drive for awhile?
Old 03-01-2007, 09:28 AM   #10 (permalink)
Drill a small hole at the lowest point of the exhaust system.
Randy
To do list:IDM mod
Old 03-01-2007, 10:37 AM   #11 (permalink)
loss of bed space is great. personally i love the gap. i always reach back through the sliding back glass and throw trash in the open space. plus comes in handy when i dont have the tailgate on because gas jugs fit right in the gap and wont go anywhere.
1996 f-250:115000miles,h2e,6.0 ic,3" intakes,studs,beefed-up e4od,4.10ls,add-a-leaf,straight pipe to one 5" stack,guages,diy intake,ccv mod,17*hpop,315/75r16 buckshots,170cc stage 2 diy injectors,wildman 4 pos. chip,timbrens
1969 mach 1 mustang
1965 Ford 4000 tractor:cone filter, 3.5" stack, mack truck nozzles(220cc), pump turned up
Sophmore at Bridgewater College
CURSURI SUMMUS NUDI!! latin for we're going streakin!!
http://community.webshots.com/user/machdriver69
jasonlambert is offline
Old 03-01-2007, 05:38 PM   #12 (permalink)
ya'll make good points, But don't you find it a sin to cut and throw off a perfectly good 500 some dollar MBRP exhaust? I just don't know if I can justify the money right now. Maybe instead I was thinking about putting on a nice moonvisor and a lighted ford emblem (if anyone knows where to find one PLEASE let me know) I search all over the internet, it seems that they were discontinued because of ford not renewing their licence with the company that made them.
Old 03-01-2007, 09:15 PM   #13 (permalink)
sell the exhaust here in the for sale adds someone will buy it, or sell it local.
as for rain I dont have any holes drilled in mine and I prolly should, I always get black spots on the '96 since its white.
the COOLEST thing is snow in the box and your driving, we got 10" today at work and all the way home they were steaming from the snow hitting them [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Diesel Rod
Old 03-01-2007, 09:54 PM   #14 (permalink)
stacks are aweome, my buddy has some from black could and they are great, he took em off the white 97 im running now and put them on his 02 . the noise diff IN cab was monumental. you can hear em alot more in the cab on the 97 than on the 02. im still putting some back on when i get a few bucks. i prefer turnouts to miters tho , if for nothing else than the water reason, i dont like the look so much but thats just me. and you COULD drill a hole to fit a 1/4 npt pet**** on a hole on the lower part of the exhaust, and open it when it rains, but you'd have to get fancy to make a handle to open it from the side of the truck unless you crawled under. hehe
97 F-350, 3" 2 piece downpipe, open air intake, 6 pos. chip from black cloud diesel.com, 4 in. straightpipe exhuast.
NOW WITH 2'nd rebuilt tranny in 3000 miles.
+new vac pump both at 245'000 new starter at 249'000
have since crossed the 250'000 mark , 253 and still gettin up.
Since killed by a red light running durango.
weponhead is offline
Old 03-01-2007, 11:41 PM   #15 (permalink)
Rtxcoon's Avatar
get some stacks
1997 F350 CC 4x4 Auto
a little over 400 at the rear wheels
thanks to Wildman, Bean, Cass, Luke and Visa
www.northtexaspowerstrokes.com
Truck Pictures
Truck Movies
Rtxcoon is offline
