Stage 1 Injectors - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 08-23-2008, 09:11 AM   #1 (permalink)
Stage 1 Injectors
Hi everyone,
I just discovered that one of my injectors is shot, now i just replaced these injectors about 1 1/2 years ago and so far I've had to send 2 of them back to get fixed. So i have decided that i don't want to deal with them anymore, and i wanted to get bigger injectors anyway.
after searching some threads on here, i think i want to go with the Stage 1 injectors from Beans Diesel Performance. what do you guys think?
I have a Tymar Intake, 3in downpipe, 4in exhaust, some turbo work, a Tony Wildman chip, and a Pyro, Boost, and tranny temp gauge so i can monitor everything. my tranny is still the stock tranny and i was planning on running it till it goes. when that time comes i was planning on going with an ATS tranny. i have a few friends that went with ats and love it, however i have read some mixed reviews on here about them, what is the best tranny to go with?
also will my HPOP be able to keep up with these injectors? its a brand new pump, but just a stock replacement.
Thanks for any input!!
Mike
1996 F-250 PSD XLT auto extended cab long bed w/ 262,000mi 3in downpipe and a 4in exhaust, 4in lift, 35in BFGoodrich all terrains. tymar intake, turbo upgrades: banks compressor wheel A/R: compressor- 1.1; turbine-.84
moultron20 is offline
Old 08-23-2008, 12:10 PM   #2 (permalink)
Justin C.'s Avatar
You'll love 'em. I'm running Stage 2's with the stock HPOP and it keeps up. Bean is great, you won't go wrong there. You may want to have Tony reburn your chip for the larger injectors. At least give him a call and see what he says. If you've got 262k out of your stock tranny, it definitely won't be around long with the bigger sticks .
Most guys on here seem to like BTS or Suncoast or even John Wood transmissions. I'm sure ATS builds a good one too, I've just never bothered to research much cause I've got a 5-speed.
Justin
Justin
1997 F-250 Power Stroke
- 230k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, BDP live tuned
2005 F-350 Power Stroke (work truck) - 220k
ARP Studs, PHP 40 hp flash
Justin C. is online now
Old 08-23-2008, 12:15 PM   #3 (permalink)
Thanks alot Justin,
yea i actually got 288,000 on it now i havent updated my sig in a bit. i think the guy that i bought the truck off of put a rebuilt tranny in it, but its just a stock rebuild so its nothing special. i actually want to put a better tranny in it anyway to eliminate the slippage and all and utilize all of the power so when she goes it will be a perfect opportunity!
would you recommend the remain stage 1 or the new ones. im kind of leaning towards the new ones because of the luck i had with my last set of remain injectors but if its not worth the extra $$$ then ill settle for the remain ones.
Thanks again for the advice much appreciated!!
Mike
Old 08-23-2008, 12:23 PM   #4 (permalink)
oh by the way,
is there anything that i should worry about or pay attention to with these injectors? outside of the mods ive listed i havent done anything else to my truck, i know i have to pay attention to my tran temp, egt, and boost. what temps and pressures should i keep them below? ive been told some numbers before but i just want to double check! what about my head bolts should i have any problems with them with these injectors?
thanks again for the input!!
Mike
Old 08-23-2008, 12:34 PM   #5 (permalink)
Justin C.'s Avatar
I went with the remans to save money. Personally, I don't think you'd go wrong if you did decide to get remans. Ryan Casserly builds the injectors for Bean, and his specs on them coming out of his shop are tighter than what they are for brand new ones from Ford/IH. I think his have to flow within 3 cc of each other, while factory is like 7-8.
Not sure on trans temp, but you can run your exhaust temps around 1300 all day and not hurt anything, and even higher than that for short bursts. A lot of people say if you go over 25 psi on your stock turbo you're on borrowed time, but I've been doing it for several years and at 195k I still have the original turbo. I hit mid 30s now, and I've heard of people hitting 45 .
Factory head bolts are good to about 40 psi, so you won't have to worry about those.
Justin
Justin
- 230k
463 hp - 7-9-09
Old 08-23-2008, 01:27 PM   #6 (permalink)
Thanks again Justin,
You've been really helpful!! ill be ordering those real soon and cant wait to put them in my truck!
I talked to Tony yesterday about the injectors, he said that the chip will work fine with the new injectors but for max performance to send the chip back to him which is what i was planning on doing anyway!
Thanks again!!
Mike
Old 08-26-2008, 11:25 AM   #7 (permalink)
Fordpowrstroke73's Avatar
My Photos: (6)
Send a message via AIM to Fordpowrstroke73
If I were you I would go with stage 2's. And then just have them tuned down to what you like. Because if your like me, you will want more that stage 1's after a while.
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
Fordpowrstroke73 is offline
Old 08-26-2008, 12:00 PM   #8 (permalink)
Thats what i ended up doing, i got the reman stage 2 injectors. after i thought about it for a bit and Justin said that he got the reman stage 2 and they seem to be working fine i decided to go with them. now im just waiting for them to get here.
once i get them and put them in ill let you guys know how they work! im sure ill be impressed.
Justin, how long did it take for you to get them?
Thanks again guys!
Mike
Old 08-26-2008, 03:57 PM   #9 (permalink)
Justin C.'s Avatar
I'm lucky enough to live about 30 minutes from Bean, so I just took my truck to him. If I remember correctly though, once I told him I wanted them he had them in a couple of days. So you should see them pretty quick.
Justin
Justin
- 230k
463 hp - 7-9-09
Old 08-26-2008, 11:06 PM   #10 (permalink)
oh I see, i called them today just to see if they have a tracking number and she told me that normally they don't send out tracking numbers but when it does get shipped out which should be tomorrow or Thursday i can call and get the number if i want to. so i should have them by early next week probably Tuesday/ Wednesday.
Old 08-26-2008, 11:23 PM   #11 (permalink)
Rtxcoon's Avatar
your gonna have perma-grin with the new sticks....make sure and call TW and get a new set of tunes....
you might consider a retro intercooler as well.
and start saving for the tranny upgrades...
1997 F350 CC 4x4 Auto
a little over 400 at the rear wheels
thanks to Wildman, Bean, Cass, Luke and Visa
www.northtexaspowerstrokes.com
Truck Pictures
Truck Movies
Rtxcoon is offline
Old 08-27-2008, 08:46 AM   #12 (permalink)
Haha yea that's what I thought. I just cant wait to get them! I was basically planning on having to put a new tranny in it, also I did want to put the D66 in it along with a inter cooler. I did talk to Tony the other day to let him know that ill need some new tunes soon.
how much did the banks inter cooler cost? or pipes at least?
Thanks Guys
Mike
Old 09-18-2008, 09:24 AM   #13 (permalink)
Im still waiting for my Injectors to get here, they ran out of nozzles so they couldnt build them.
where do you guy buy stacks? ive found a couple of places on the web but usually someone on here knows a cheaper place. id like to get either a 4" or 5" miter cut preferably a 5"
Old 09-18-2008, 11:45 AM   #14 (permalink)
Supporting Member
bigblue's Avatar
Send a message via ICQ to bigblue Send a message via Yahoo to bigblue
All my questions answered on this thread. Wife approved injectors, so looks like Beans reman Stage 2s, D66, and a TW chip for me in the very near future! I'd like to go Stage 3 tuned down, but that would mean big oil, electric fuel and lots of mods...and lots of $$$$
Member since 11/27/1999
2006 Dodge 3500 ST DRW QC/Flatbed 5.9/6spd
bigblue is offline
Old 09-18-2008, 10:19 PM   #15 (permalink)
CVB Fireman's Avatar
where is a good place to go for injectors???? that is the next thing to do on my list
NEW BABY- 2005 Chevy Duramax Diesel CCSB.... 8 inch fabtech lift 37 inch mickey Ts on 18inch flat black pro comp Rims. Edge Insight EFI!, straight exhaust. AFE intake and turbo inlet. EGR blocker plate Fully loaded Pioneer DVD double in deck. 2 12 inch shallow fosgates... sorry i switches guys but this thing is Bad To The Bone.
f-350 4 door long bed. 6 speed. 5 inch stacks. 9 inch lift. 40 inch Ground Hogs. custom Front and rear bumpers with 10,000 Warn WincheSSSSSS.K&N TW chip, stage 1s, IDM mod, exhaust brake. limo tint. peterbilt cab lights. dvd screen 2 shallow fosgate 12s (sick!!) and everything else you can think of. damn ive spent way to much money on this truck.- newest smartest and awesome edition is a set of custom built track bars. should have gotten these from the get go
CVB Fireman is offline
