stage 1s in truck wont start..help - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 03-01-2009, 08:17 PM   #1 (permalink)
sooo i just finished my stage 1s and got the truck all back together and the truck is cranking hard (due to a new starter) but it will not fire, it seems to sound like it will fire but does not....its snowing and im freaking out....HELP
97 F350, Custom intake, 5in exhaust, HPOX,17* HPOP, Rosewood stage 1 injectors, Powerhungry chip, 18k dfuser mod, shimmed FPR, 6 in lift on 37in interco M16 radials, firestone ride right air bags, built trans, bully dog shift kit, 12,000 HID headlights, 12,000lb winch in the front and a 9,500lb in the back, custom strobe package in headlights and taillights, LED bed lights, DVD, navigation, and much much more to come.
pullinstroker is offline
Old 03-01-2009, 09:45 PM   #2 (permalink)
CVB Fireman's Avatar
spray some WD 40 in the air filter
NEW BABY- 2005 Chevy Duramax Diesel CCSB.... 8 inch fabtech lift 37 inch mickey Ts on 18inch flat black pro comp Rims. Edge Insight EFI!, straight exhaust. AFE intake and turbo inlet. EGR blocker plate Fully loaded Pioneer DVD double in deck. 2 12 inch shallow fosgates... sorry i switches guys but this thing is Bad To The Bone.
f-350 4 door long bed. 6 speed. 5 inch stacks. 9 inch lift. 40 inch Ground Hogs. custom Front and rear bumpers with 10,000 Warn WincheSSSSSS.K&N TW chip, stage 1s, IDM mod, exhaust brake. limo tint. peterbilt cab lights. dvd screen 2 shallow fosgate 12s (sick!!) and everything else you can think of. damn ive spent way to much money on this truck.- newest smartest and awesome edition is a set of custom built track bars. should have gotten these from the get go
CVB Fireman is offline
Old 03-01-2009, 10:04 PM   #3 (permalink)
i tried starting fluid and it didnt even try to kick...i also installed a hpox while doin the injectors...in moving the drivers side line could i of knocked any wires off...im in nj and its snowing like a ***** but im determined
Old 03-01-2009, 10:57 PM   #4 (permalink)
I Hope Not Regular Starting Fluid!!!!!!!!!!
Old 03-02-2009, 08:25 AM   #5 (permalink)
why not
Old 03-02-2009, 09:09 AM   #6 (permalink)
starting fluid
because your glowplugs will ignite it as the intake valve is open allowing the starting fluid in and this ignition will blow your intake apart. Flying pieces of steel arn,t very nice.
Somedays its just not worth chewing through the restraints
2011 F350 CC lariat ultimate dually with nav, line x, more mods comming
Y2K 4x4 250 PSD Xcab, auto, way too many mods to list Broken March 2011, written off due to collision
Crazy_Canuck is offline
Old 03-02-2009, 10:06 AM   #7 (permalink)
drwoodchopper's Avatar
Did you bleed all of the air out of the system? Is your HPOP full of oil?? You don't want your injectors firing on empty! I usually get in a hurry and leave some critical connector unplugged.
1997 F350 CC4X4 120K superclean truck Beans 6 pos chip! IDM mod(it works!) Pyro, Boost and Trans Autometers over mirror. 4" straight pipe! 285/65X18's Nittos. Ford V-10 trans cooler, Tymar Intake, 6 leaker intercooler. Swamps 175/146 sticks fed by Adrenaline in front of a BTS. WOP QSSB turbo! 1997 F350 XLT 4dr 125K 5" Pipe no muf and no kitty (totaled). 04/04 F350 EX Cab LWB "Leveled" Lariat FX4 Limited slip. BFG's 295/75R16. 4" pipe from back of kitty exiting in front of rear wheel. Autometer Pyro and Boost guages 65K. 422hp and 772tq (SOLD) 96 F250 powerstroke extended cab. Original E40D 132K Wood hauling machine. 10k MOD. Autometer Pyro and Boost gauges. Gutted Cat. Sold.
1966 Mustang "mostly restored" replaced by 2009 Dodge Chalenger! My Youtube vid. http://www.youtube.com/watch?v=fdXy-bV6Zks
drwoodchopper is offline
Old 03-02-2009, 10:10 AM   #8 (permalink)
Cratos's Avatar
My Photos: (15)
When I did mine I left the glow plugs out (no compression things spin faster)
And cranked it a few times in till I had good oil pressure 20-30 psi at the HPOP res ( had to crank it 10-15 sec let it set 5 min repeat in till solid pressure)
It takes a but to get the retail refilled and up to pressure then put the glow plugs a fuses back in and fired her up
97 F-250HD Super Cab 4X4 E4OD, 3.55 gears, swamps 238'/80s & SWAMPS Chip,Beans D-66 Turbo, Adrenaline HPOP & Reservoir Filter, BTS,TSM Disk Rear Brakes,DIY Electric Fuel system,DIY Air Filter,Auto Meter Dash Mounted Gauges: Trans Temp, Boost, EGT, Oil Temp, Oil Pressure.Water Temp,Fuel Pressure Gauges,3 Inch Intake plenums, 4 inch MBRP, Intercooled, CCV mod.
294,000 Miles and still going Strong.
Cratos is offline
Old 03-02-2009, 11:32 AM   #9 (permalink)
i have fuel pressue, the hpop is full, fuse 22 is ok under the hood...still no starty start
Old 03-02-2009, 12:04 PM   #10 (permalink)
Cratos's Avatar
My Photos: (15)
do you have oil pressure? no OP injector no work
Cratos is offline
Old 03-02-2009, 12:05 PM   #11 (permalink)
i took the oil line off the head and oil poured out...do i keep it off and crank
Old 03-02-2009, 12:06 PM   #12 (permalink)
the op gauge moves upon cranking
Old 03-02-2009, 04:06 PM   #13 (permalink)
because starting fluid isnt lubricated wd 40 is. regular gas isnt lubricated and diesel has a ton of oil in it if you use regular starting fluid you will fry your engine
