What would be better for pulling a load? I wanted the power of the stage II's, but if stage 1's would be better for pulling then I would rather be on the safe side.
In the future im planning on an intercooler, D66 turbo, HPOP, electric fuel system and 6pos chip to work with the injectors.
Thanks, Jared
1997 F-350 XLT, 4x4, Crew cab, Long bed, powerstroke, 6" suspension lift, 35" tires, 3" DP, 5" diamond eye straight pipe, BTS transmission, 6.0 transmission cooler, powerslot rotors and hawk brake pads, MM manual hubs, Redhead steering gearbox, 203* thermostat, DIY intake, Ranch Hand front and rear replacement bumpers, Ranch Hand toolbox, headache rack and bed rails. 3.55's, 222,000 miles. EGT, Tranny temp and boost guages.
Id have to agree, stage 1's are the way to go. Stage twos will have significantly higher EGTs you won't want to mess with when towing. The extra power will cancel out with the headaches it eventually causes you.
1997 F250HD Ext-Cab XLT w/7.3L, Freshly rebuilt E4OD (TransGo Tugger HD2, Billet Torque Converter), 103,000, 6637 Intake, Cat ran away and took the muffler with it
2001 3500 LB7 CC LS Duramax, Allison 1000, all stock, 242,000
2004 M2 Business Class 24' Box, MBE 900, 106,000
X3...you cannot tow heavy with any more HP-TQ than a stage 1 will get you.
You don't need a elect fuel system for stage 1's or a HPOP. A IC is a must!
Going to 4.10 would be best with 35" and towing with a auto.
When your ready to mod let me know will get you setup.
Cary
I agree with the others, stage 1 is the way to go. Look at my mod list and I still have to watch my gauges when towing my 7000lb trailer. Temps will get hot and I can overboost it if i get into it too much on a hill.
96' F-250 4x4 SB Crewcab, 3.55 gears, rebuilt E4od, Air bags, 2" leveler kit, 10 disc cd changer, Tymar intake, Tymar 4 pos TS chip, 4590 cooler, boost, pyro(pre-turbo) & tranny temp AutoMeter gauges mounted in pillar, Diamond eye 4" exhaust with lost kitty, Tymar 3x4" downpipe, Warn hubs, Prodigy brake controller, Hypermax intercooler, CCV mod,17* HPOP, stage 1 injectors, fpr. Rebuilt tranny with pump and valve body mods, 3 disc torque convertor. Diesel mechanic 20+ years
i have been running stage 2` s for ever and no problem, been pulling a 10 ton trailer all over the u s and no problem and as aeyone will tell you if on a long mountian grade if you keep your foot in it even one with out mods will have high egt temps
__________________ 1997 F 350 4X4, idm mod, wide open performance GQSSB turbo, stage 2` s by bean` s, intercooler, 4" no muffler, stack, trans from brians truck shop rear, disk brakes, and a stecher stage 1 hpop 6 position chip with bean` s programs crane valae springs, air dog lift pump and electric fuel pump and regulatorand water methonal injection
