Old 09-10-2007, 05:49 PM   #1 (permalink)
stage three ?
i plan to do stage three sticks soon but i do not have a fuel system just using stock will it run ok w/ the stock system or will i not get much out of it. i plan to get one soon but i can only do one at a time. thanks
1996 f-250:115000miles,h2e,6.0 ic,3" intakes,studs,beefed-up e4od,4.10ls,add-a-leaf,straight pipe to one 5" stack,guages,diy intake,ccv mod,17*hpop,315/75r16 buckshots,170cc stage 2 diy injectors,wildman 4 pos. chip,timbrens
1969 mach 1 mustang
1965 Ford 4000 tractor:cone filter, 3.5" stack, mack truck nozzles(220cc), pump turned up
Sophmore at Bridgewater College
CURSURI SUMMUS NUDI!! latin for we're going streakin!!
http://community.webshots.com/user/machdriver69
jasonlambert is offline
Old 09-11-2007, 11:49 AM   #2 (permalink)
Re: stage three ?
You should have power but it will plane off quickly with out enough oil. Stage III's are big and require alot of HP oil. What type of oils system do you plan to do? My suggestion do the oil first then the injectors. Then again if you are like me you get greedy and can't wait.
97 F250 7.3PSD,X-Cab,SWB,4X4,5spd,4.10gears,1Owner
3.5” DP,4” Exh.,No Cat,6637 Intake,FPR mod,60 gal bed tank,5th whl & gsneck
BDP 140v IDM Mod
CCV mod
'08 diff
Hewitt Gauges
HPX Mod
6 pos TW chip
Modded H2e
Rosewood stage II's
Valair clutch
'00 Excursion 7.3PSD 4X4, Bone stock...(wife's truck)
6637 intake
drill/slot rotors
Neal97250 is offline
Old 09-11-2007, 12:11 PM   #3 (permalink)
DZLJIM's Avatar
Re: stage three ?
Stage-3 injectors do not require any more oil than an AD code injector. A Super Duty HPOpump will run them jsut fine. I ran Tony's most wildest burn he sent me with a single SD pump and 230cc Hybrids and never set a CEL...
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-250, 4x4, CC SB
DzlJim.com for some redneck engineered projects.
www.racerxautomotive.com for your upgraded E4OD/4R100 needs.
DZLJIM is offline
Old 09-11-2007, 12:23 PM   #4 (permalink)
Re: stage three ?
Thanx dzljim That is good info to know. I shouldn't have a problem with II's then
BDP 140v IDM Mod
CCV mod
'08 diff
Hewitt Gauges
HPX Mod
6 pos TW chip
Modded H2e
Rosewood stage II's
Valair clutch
6637 intake
drill/slot rotors
Old 09-11-2007, 12:29 PM   #5 (permalink)
DZLJIM's Avatar
Re: stage three ?
Actually you might. Depends on how many cc's and nozzle size.
230cc Hybrids are about equal in oil requirements to a 160cc w/ the same size nozzle.
If you have Stage-2's that are 175cc or 180cc, I'll bet you might run low on oil, depending on the program...
DZLJIM is offline
Old 09-11-2007, 01:58 PM   #6 (permalink)
Re: stage three ?
I could set a cel at will with my 2's but it also had a old '95 HPOP, Stealth cured that!
cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 09-11-2007, 02:20 PM   #7 (permalink)
Re: stage three ?
Thanx. I just bought a SD pump about 10 mins ago. Now for the II's.
BDP 140v IDM Mod
CCV mod
'08 diff
Hewitt Gauges
HPX Mod
6 pos TW chip
Modded H2e
Rosewood stage II's
Valair clutch
6637 intake
drill/slot rotors
Old 09-11-2007, 06:59 PM   #8 (permalink)
SVT
Re: stage three ?
Run my II's with SD oil no CEL
97 Black CC F250 4X4 BDP stage 2's D66 5"exhaust Snow H2o/meth shimmed FPR modded pedistal 17*HPOP tymar intake black bird rear disks HPX BTS Tranny 10/4/07
http://community.webshots.com/user/sootstorm
SVT is offline
Old 09-11-2007, 11:38 PM   #9 (permalink)
Re: stage three ?
yea i have no cel prob now just do not know which would yield the best gain a fuel system or hybrids
1969 mach 1 mustang
Old 09-12-2007, 12:02 AM   #10 (permalink)
Re: stage three ?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Neal97250</div><div class="ubbcode-body">You should have power but it will plane off quickly with out enough oil. Stage III's are big and require alot of HP oil. What type of oils system do you plan to do? My suggestion do the oil first then the injectors. Then again if you are like me you get greedy and can't wait. </div></div>
Stage 3 hybrids dont require a dual hpop. Ive made 550 rwhp with hybrid injectors on stock hpop with no cel....
edit- didnt read jims post
ford pinto with spinner hubcaps from walmart- big pimpin
Thunder_struck is offline
Old 09-12-2007, 12:14 AM   #11 (permalink)
Re: stage three ?
now what all fuel and turbo wise did you have to get that 550?
1969 mach 1 mustang
Old 09-12-2007, 11:28 AM   #12 (permalink)
Re: stage three ?
beans modded h2, beans hybrids with .010 edm nozzles, stock hpop, TW tuning and dual superduty fuel pumps. Dynoed 545-558 depending on the dyno and would run 13.1's@ 103-104 mph 7300#'s all day long on fuel. Oh and only a couple hundred miles of that combo was too much for the stock rods, i now have billet rods thanks to that setup [img]/forums/images/%%GRAEMLIN_URL%%/shocked.gif[/img] [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
Old 09-12-2007, 07:32 PM   #13 (permalink)
Re: stage three ?
ok so a stock h2e and a fuel system w/ one pump would be safe? lol maybe?
1969 mach 1 mustang
Old 09-12-2007, 08:25 PM   #14 (permalink)
Re: stage three ?
ya i would say so.
Old 09-12-2007, 09:19 PM   #15 (permalink)
Fordpowrstroke73's Avatar
My Photos: (6)
Send a message via AIM to Fordpowrstroke73
Re: stage three ?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Thunder_struck</div><div class="ubbcode-body">beans modded h2, beans hybrids with .010 edm nozzles, stock hpop, TW tuning and dual superduty fuel pumps. Dynoed 545-558 depending on the dyno and would run 13.1's@ 103-104 mph 7300#'s all day long on fuel. Oh and only a couple hundred miles of that combo was too much for the stock rods, i now have billet rods thanks to that setup [img]/forums/images/%%GRAEMLIN_URL%%/shocked.gif[/img] [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img] </div></div>
Very nice!! [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
Fordpowrstroke73 is offline
