Just arrived in the mail. Anything I should know before putting it in and hooking it up? apart from disconnecting the batteries. By the way what are you guys using to prevent battery corrosion? dielectric grease or vasoline ?
1996 F-350 psd crew duellie,declawed, demuffed,fumotoed, home-made intake, edge evo, post triple pillar auto meter gauges,line-x (10-16-05).Seat mod (11-13-05).on-board air(viair 450c) with horns (Kleinn triple train) (8-21-06).Bilsteins (11-28-06)Upgraded headlight harness.IDM MOD by Matty, SOCAPS member <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />thanks Matt!! more mods to come.
What about the batteries? I plan to disconnect the batteries to put the gpr on and I thought I would clean and "protect" the batteries. TIA Karl
We use spray cosmoline on the fleet. Comes under the name PDRP. Better than all commercial battery terminal coatings, read the mil spec salt spray test it must pass!
Diesel Mechanic 28 yrs
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: fordmedic</div><div class="ubbcode-body">What about the batteries? I plan to disconnect the batteries to put the gpr on and I thought I would clean and "protect" the batteries. TIA Karl </div></div>
I use di-electric grease on the post and within the connection. I also use the rattle can spray on corrosion preventer AFTER the clamps tight, I don't know how good it conducts elecricity.
BUT....
Vasoline and rattle can paint will work just the same. Vasoline will protect the connection and the paint will keep the terminal from corroding.
I am gonna do the stancor before next winter, just hasn't been absolutely necessary, if I let is cycle longer that the WTS light it'll fire every time, my gpr just drops a little voltage...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
I use CRC heavy duty corrosion inhibitor after I tighten the connections. We use it on just about everything on marine engines, it works great. Good Luck
Frank
__________________ http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
