Old 01-02-2006, 06:02 PM   #1 (permalink)
Start Solenoid Wiring--Did He Get it Right?
Need someone to go check the wiring on the start solenoid (passenger side wheelwell). I picked up a new one yesterday and asked my son to put it in today. Now the truck turns over real slow.
Here is what I have looking down at the solenoid from the passenger fender.
Top (small red wire with boot that fits over screw)
Left Lug (small red wire on spade connector)
Right Lug ( all other wires...4 white, 2 green, 1 heavy red)
kp
97 F250, 4X4, CC, DP, 4" Magna-Flow exhaust, Tymar Intake, BTS 4 Position Chip; BTS Tranny; Baby Swamps,Tru-Cool Max,Autometer 3 gauge A-Pillar,HX,Hot water mod, Centramatic balancers;Correct-Trak;Rhino-liner, SKY-FI, Prodigy Brake Controller, Bilsteins all around, Royal Purple in the Diff, Pro-Tech Headache Rack, N-Fab Nerf Bars, Heated Seats..aaahh. Auto-Dimming Mirror with Temp/Compass; Polk Audio with SONY Head Unit. GOS Headlight Harness with Diode Mod.
bobtaildog is offline
Old 01-02-2006, 06:04 PM   #2 (permalink)
tallfarmboy's Avatar
My Photos: (11)
Re: Start Solenoid Wiring--Did He Get it Right?
I don't think you can get it wrong as long as you have the small wires on the small posts and the big wires on the big posts...
Someone else will chime in here in a bit...Might be time to get your batteries load tested at a parts house...
TFB
Sold: 1997 F-350 CC 4x4
"New Rig" 2003 F-250 Lariat CC 6.0L EDGE w/Attitude Monitor, Automatic, 4" Exhaust
Truck Pictures Show Me DJ Service
tallfarmboy is offline
Old 01-02-2006, 06:18 PM   #3 (permalink)
I don't have an OBS solenoid in truck to look at, but the "small" wire on top is the wire that energizes the solenoid. The "large" wires are the ones that carry the actual load that the solenoid is switching. I would venture a guess that if you've got a rather large wire on one side, and really not much of anything on the other, that it's wrong, otherwise, why would ford run such a large amp wire, with a small wire either running from it or feeding it? One side should go directly to the battery positive, and the other should go to the starter. If there are more wires present, they are probably just using the solenoid post that the battery positive is connected to for a piggyback hot lead. A solenoid is just a fancy toggle switch that can switch a large load. The two "large" posts are the actual "high load" posts, and the "small" post is the "switch" that when energized with power, closes the circuit and "turns on" the starter. As long as a battery hot lead comes in on one, and the starter wire leaves on the other large post, and the wires are of adequate size, it will work. Do the OBS trucks have a solenoid on the starter as well? If so, the solenoid you are referring to could just be switching the power to the other solenoid that actually has the large starter wire on it.
Charlie
CharlieII is offline
Old 01-02-2006, 06:38 PM   #4 (permalink)
Did you check to make sure there is a good clean ground?
Dave
'95 PSD 4x4 ext.cab stock but not for long cooper discovery st's 215 on the ticker and counting daily
'00 PSD CC DRW 4x4 76k My favorite,but she's a slugg
djwc is offline
Old 01-02-2006, 10:48 PM   #5 (permalink)
brahamfireman's Avatar
YES. they do.
might have a corroded conection. I had one on the starter and the truck turned real slow, after a good cleaning it whips right over.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
» Sponsor Links
»Garage Storage and Cabinets
