Old 10-17-2006, 12:19 PM   #1 (permalink)
BardOrBrad's Avatar
Steering Collum Gauge Pod
I remember someone making a single gauge pod for a steering collum and can't find them now. Does anyone out there have any ideas? Thanks for any & all replys.
97 350 XLT SRW CrewCab, 4X4, 4:10's, Gauges, Tymar OAE, HX hose, 6p chip, no EBPV, ORU RSK, Evans Coolant with inline filter, PLM tranny and diff covers, 203 T-stat, Spin-on in-line trans filter & true cool cooler, 5" exhaust, IDM mod, AC mod, Banks IC, hada PULSE HPOP but a 17 willdue4now, DIY Stage I's, Dieselsite CPR OBS electric fuel system, Gregg Evan's Monster in a BOX!
BardOrBrad is offline
Old 10-17-2006, 01:27 PM   #2 (permalink)
My Photos: (9)
Re: Steering Collum Gauge Pod
I have one of the pods in my truck I got it from tubbz, but Rick (ricksf250) is who was making them. At one time he wasn't sure he was going to make them anymore, you will just have to send him a pm.
Chris
97 F-350 cc srw 4x4,White,cab hi Leer,E4OD,4.10's,Hypermax H2E,Banks intercooler,BDP stage 1 injectors and fuel system,BTS tranny,BTS twin hpop,4 postion chip programmed by Cale,Skyjacker 4" system,35" BFG's W/Welds,Rear air bags,Hayden 26,000 trans cooler,4" exhaust,Tymar intake&hx mod,Amsoil dual bypass filter w/Amsoil syn. oil, and diff. lube, Ford aic, Joe Servo idm.
353 HP 677 TQ on BTS's dyno at 0 correction
SLAPS Treasurer
Member of FOKISD
<font color="red"> #5 </font>
Truck pics at http://community.webshots.com/user/ytee1100
ytee is offline
Old 10-17-2006, 01:47 PM   #3 (permalink)
BardOrBrad's Avatar
YT, I can't find him as "ricksf250" Is there another name? Thanks for the reply!
Brad
Old 10-17-2006, 01:54 PM   #4 (permalink)
kfjensen's Avatar
Brad,
Here is his profile deal...
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 10-17-2006, 02:06 PM   #5 (permalink)
Bean had them on his site at one time.......
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 10-17-2006, 05:06 PM   #6 (permalink)
Im here, just missed this post. I kind of gave up because of the labor it took to hand produce each one, 7+ hour. then sought having a mold made to reproduce them, but once I got that quote and got up off the floor, I just kind of shelfed the project.
I have the proto-type if someone is interested in persuing it. They tell me overseas tooling is way cheaper than US... thats too bad.
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
Old 10-17-2006, 05:08 PM   #7 (permalink)
Rick, was that yours that Bean had on his site a while back?
Old 10-17-2006, 05:22 PM   #8 (permalink)
I made one from a F-150 pod that turned out pretty good. Took some die grinding. It looks pretty good. I'll try to figure out how to post some pictures.
Clete
Thanks Clete
1997 F250 XLT PSD,CC,4wd,E4OD,4.10L,Hypermax 3" DP,Beans Stage I's, Tymar intake, 5" exhaust w/muffler rear exit, Intercooled, pedal mod, HPX cross over, 4 Position chip with some badazz burns, FPR shimmed, modded IDM, Isspro EV trans.temp in collum pod, and pyro guage and boost set in "A" pillar, tranny cooler ,remote trans filter, Fuel heater in the scrap iron, Precision Industries Stallion TC, Mag Hy-tech transmission pan.
Galaxy 959 peaked and tuned ,DM452 mic, Predator 10K
Pulling 30' Jayco 5th wheel
#12
http://good-times.webshots.com/photo...99722885MOkzUQ
Clete is offline
Old 10-17-2006, 06:06 PM   #9 (permalink)
kfjensen's Avatar
Clete
Just set up a webshots.com and its easy to link it from there or any of the other free sites like it
Kevin
kfjensen is offline
Old 10-17-2006, 06:45 PM   #10 (permalink)
My Photos: (9)
Sorry [img]/ubbthreads/images/graemlins/shrug.gif[/img]I was a little off on his username.
Chris
SLAPS Treasurer
Member of FOKISD
ytee is offline
Old 10-17-2006, 07:19 PM   #11 (permalink)
Yes it was. They are hand laid fiberglass and hand finished. I was hoping to have a die made and then could pop them out of ABS plastic, but it is just outragouse what it cost to have a die made &gt; 20k.
When you really dig into the custom fiberglass world, it is amazing what some people have built. Complete dashes and interiors, 100's and 100's to even 1,000's of hours of hand work.
Anyway, if someone is interested in carrying on, you could check overseas they say it is about 1/8th the cost for a mold made in the us.
Rick H...
HIS
HERS
Old 10-17-2006, 07:52 PM   #12 (permalink)
I was looking at my Dad's SD column the other day and it looked exactly like my column, so I pulled off the top piece of plastic on my column and compared it to his.
As far as I can see, they are exactly the same, except ours has an extra screw on the right side connecting the top and bottom plastic pieces.
I say buy the column pod for the Super Duties, as far as I can tell it should fit our trucks perfect. I may get one in a few weeks just to make sure it actually fits, they are like $30 I think.
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD Powered By 2L Motorsports and SWAMPS.
Mods: AM Ultra-Lites, DiPricol HPOP gauge,TS/2L Moto Chip, 4" Straight-Piped, Poor boy's intake, Swamps II's, BTS, 285 BFG A/T's on factory Alcoas. Lots more to install, see below!
On the bench: AirFlo S400, Swamps 275's, Studs Rods and Springs for the top end, and some other stuff.
My Pictures
DD- SILVER 11/97 F350HD XLT RCLB Auto 3.55LS 4x4 OFFROAD
Mods: Redneck straight-pipe, TS/2L Moto chip.
smokyred is offline
Old 10-17-2006, 08:06 PM   #13 (permalink)
Wow that would be cool!
Old 10-17-2006, 08:11 PM   #14 (permalink)
Boy I'd sure like to have a steering column pod too.... wonder if DPPI has a Super Duty version in stock? I'd like to try!
'94 F250 supercab 4x4, original owner, 4.10LS, shimmed FPR, Tymar air intake, DP Tuners 80 Econo burn, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
nashvillebill is offline
Old 10-17-2006, 09:01 PM   #15 (permalink)
kfjensen's Avatar
[img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
Kevin
kfjensen is offline
