Old 10-30-2009, 09:23 AM   #1 (permalink)
stock exhaust straight answer
Ok guys I done a search and it was quite overwhelming. Heres where i'm at, I stopped by a muffler shop and was quoted a price of $425 installed for a imco, I think thats right 4" exhaust kit installed. Heres my question. I measured my tailpipe and it shows 3.5" so I would assume thats stock right? Is an extra 1/2 " gonna make that big of a diff? I just installed the smfw and I believe everything is stock, it's a 95 2wd. Will I be wasting $400 with this upgrade or is there a cheaper way out? This is a decked out horse trailer pulling rig, very classy looking not exactly tough looking, so a loud sounding beastly exhaust doesn't exactly fit the truck yet some extra mpg's and more power never hurts anything. What do you experts recommend?
woodman55 is offline
Old 10-30-2009, 10:08 AM   #2 (permalink)
edieedie's Avatar
put a 3 inch down pipe on it, and lose the muffler
not that much noise
1997 F 350 4X4, idm mod, bean` s stage 2` s and d66 turbo, intercooler, 4" no muffler and stack, fuel pressure mod and trans from brians truck shop rear disk brakes, and a stecher stage 1 hpop chip with bean` s programs crane valae springs
edieedie is online now
Old 10-30-2009, 11:35 AM   #3 (permalink)
not that much noise
So forget the imco exhaust and just go that route?
Old 10-30-2009, 12:22 PM   #4 (permalink)
BadDogPSD's Avatar
You won't gain much power with a 4" exhaust, but you will gain cooler egt's,
especially when towing heavy. If you're not having high egt's issues, now, and are happy with the way the truck sounds, you're best bet would be do swap out the down pipe (as suggested). Tymar sells one that will fit good and bolt up to your stock cat (if you still have it).
1997 F250 4x4 Crew Cab PSD; Dana 60; Sky RSK w/SuperDuty springs.
BadDogPSD is offline
Old 10-30-2009, 06:52 PM   #5 (permalink)
I just did the tymar diy filter today and the muff shop wants 150 for the downpipe and pipe to get rid of the muffler. I will haul some pretty heavy loads so i' thinking I may just replace the xhaust since the old one is pretty rough looking.
Old 10-30-2009, 07:56 PM   #6 (permalink)
edieedie's Avatar
look at my sig. i dont have egt problems and pull a 40 ft 5 th wheel all over the us
Old 10-31-2009, 08:00 PM   #7 (permalink)
brencoracing09's Avatar
Send a message via AIM to brencoracing09
if you take out the muffler and put on the tymar downpipe is there a big noticable difference in sound?
95 psd,cc,dually,long box,294k,xlt,diy open element intake,unplugged fuel bowl heater....damn that fuse 22,complete trans & tc overhaul as of 291k (first rebuild of stock trans ever)
brencoracing09 is offline
Old 11-01-2009, 09:49 AM   #8 (permalink)
I put a 3" downpipe on my truck and a Magnaflow 4 exhaust....the muffler is a straight through design. This thing has a bit of a drone now. I think its because of the 3"-4" step connection. I seen about 18lbs of boost unloaded. I added a turbo branket and it added 2lbs of boost and made it more responsive.
97 F-250 HD 4x4, 4:10's, Crew Cab
Banks 3" down pipe, Magnaflow 4" exhaust, DIY Cold Air - open element, tripod Banks gauges, B&M trany cooler. DP Tuner-F5 4 position Chip, Turbo Blanket +2lbs more boost
87 Mustang Drag Radial Car - F1R - 1200HP !
302man is offline
Old 11-01-2009, 12:13 PM   #9 (permalink)
Cratos's Avatar
My Photos: (15)
do the dp
i tested just the dp without the rest hooked up and did not notice any diffarnce so left the stock 3.5 with 3 in dp
use the $ for other stuff.
97 F-250HD Super Cab 4X4
E4OD, 3.55 gears
Auto Meter Dash Mounted: Trans Temp, Boost, EGT, Oil Temp, Oil Pressure.Water Temp.Fuel Pressure Gauges.
Beans D-66 Turbo, 3 Inch Intake plenums, DIY Fuel system, ,DIY Air Filter, 3 in SS DP, Intercooled. Modified Pedestal, ITP SS HX, CCV Mod,
BABY SWAMPS & SWAMPS 6 Way Chip,
Adrenaline HPOP & Reservoir Filter
Gutted EPBV
TSM Disk Rear Brakes
263,000 Miles and still going Strong.
Cratos is offline
Old 11-01-2009, 03:26 PM   #10 (permalink)
Originally Posted by 302man View Post
I put a 3" downpipe on my truck and a Magnaflow 4 exhaust....no cat and the muffler is a straight through design. This thing has a bit of a drone now. I think its because of the 3"-4" step connection. I seen about 18lbs of boost unloaded. I added a turbo branket and it added 2lbs of boost and made it more responsive.
Not to sound stupid but what is a droan? I hear that expression a-lot and probably don't want one.
Old 11-01-2009, 04:04 PM   #11 (permalink)
My Photos: (54)
OK folks, too many references to cat delete. Forum rules prohibit reference to tampering with, removing, disabling or modifying the emissions control system (it is a violation of federal law) in any forum other than the off road forum, and there it must reference a non-licensed off road only truck. This includes cat delete and gutting the cat. Please check the posting rules, top of every forum as a sticky. This includes signatures as well.
All prohibited references deleted, I don't want to delete the thread.
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, 286,000 miles, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, 36" tall ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 11-01-2009, 04:06 PM   #12 (permalink)
My Photos: (54)
Drone is a constant, monotonous, humming monotone kind of sound.
Old 11-01-2009, 05:01 PM   #13 (permalink)
Thanks for clearing that up. Would a 4" upgrade cause this? If this was a 4x4 with a lift the louder the better but it's more of a travel/horse trailer hauler for the family so loud isn't what I want. Yet better fuel econo and power are a plus for sure. I may get a tuner down the road but for now just better response and better turbo response. The muffler shop has done several of these imco systems and said they aren't really any louder just more of a turbo whistle, or is he just trying to sell me something?
Old 11-05-2009, 09:14 PM   #14 (permalink)
Well heres my update on the truck. I had the imco 4" installed today, did the diy yourself tymar last week and everything came together. The turbo is whistling like a jet engine, although more of a deeper grunt the truck isn't terribly loud. Heres the good part, the gearshift used to wobble pretty good in neutral and is now steady as can be. $500 well spent on upgrades and the power is extremely noticable and crisp throttle response. Glad I did it for sure!
Old 11-05-2009, 10:08 PM   #15 (permalink)
BadDogPSD's Avatar
Good deal, glad it worked out for you!
