i got a good deal on a used but never installed Super Chips 1705 tuner. I'm going to install on my '95 PSD. I have a Tymar intake, Hypertech DP, cat delete and stock muffler and tail pipe. I do not want to brake anything. I tow a 3 horse slant load goose neck. What do any of you that have used this tuner suggest as my every day setting? Also, forgetting teh hype, what kind of performance can I expect?
irish1,
I have that same tuner, and I would say;You are not going to break anything with it! My egt reached about 1100degrees pulling a 4k pound trailer up some little hills on the way to the coast. I had the tuner set in perf. tow. I did notice an improvement. My fuel mileage has stayed the same, maybe a little better! 17.5 to 17.7. I have it in tow safe right now and just came back from the beach and, got 327 miles out of the front tank (empty of course). I'll have to fill it up and do the math. I don't know what it will do for your automatic, because I have a 5speed, maybe somebody else will chime in with a automatic. Good luck and have fun! Al [img]/ubbthreads/images/graemlins/cool.gif[/img]
'95 F350 Red cc,zf5,157k miles,3"dp with 4" exhaust,Di Pricol egt and boost gauges,DP-Tuner F5,295/75/R16 BFG AT, SD IC, 1.0 A/R,IC pipe kit, and Stage 1's from GTS, South Bend smfw with the con O from BDP.
I used my friends super chips tuner for a while.......it's a very nice "safe" programmer, I stepped up to the edge for a little mo' power! But you'll love the superchips plus it's pretty punchy for what it is. Hope this helps.
1995 f-350 102k miles, 5in. exhaust, "Custom" edge evo, Auto meter ultralite gauges, NEW 6.1 0-60 and 17.2 1/4 mile even just rolling across the line the about 30mph, 4:10 gears, E4OD tranny (first gear is goin and almost gone)
Dana 60, New INTAKE!!!!!!!!!!!
What's it like to be 16 and love diesels...Well just ask all my friends with rice grinders that can't keep up. Oh and be able to out talk your shop teacher and basically teach the diesel part of our High School....Oh yea......
Irish1,
One more thing. If you don't have gauges, I would highly recommend them. You would probably enter the red, with your horse trailer on a long grade. Al
I second the gauges, I run my 1705 on the performance setting all the time, when I pull my enclosed car trailer she will get right to 1200, maybe 1250 depending on my foot, get a pyro on yours so you know!!!
1996 3/4 Ton, 4x4 SCSB, XLT, ZF-5, (dob) 9-95, Eng. s/n 212809, AFE Stg.II, 3"-3.5" Downpipe into 5" Stacks, dead kitty and no sound effects, ALF4 w/SuperChips programmer, Shimmed To 60psi, Generic AIC and A/C Mod, Dis. fuel heater, DIY Exhaust brake,Stancor 586-902 GPR W/Shut-Off and indicator light, South Bend Con OFE Clutch, TRL Brake Controler, Reese Class V, Add A Leaf, Diamond plate toolbox and bed rails, Auto Meter Pyro, Oil Press., Water Temp, Boost, (C5)4.10's w/285-75-16 Rubber, 194,000 paces and counting.
1992 Chevy Blazer 1500 Silverado, 156,000 laps
8ft Diamond/Meyers plow
1980 Corvette, 350 built my way, auto
1968 AMX, 390 4-spd. Car #664
1923 Model T, 350 w/671 B/M blower
i ran the high setting when empty
as for preformce,my truck with 355's and just a downpipe and open filter dynoed
stock 166.8hp/322.4tq
tow safe 182.6hp/349tq
high pref 188.7/352.3tq
