I had read something about putting Super duty rear springs on our trucks. What years will work? Can we hear from someone who has done this?. The back roads and my truck are beating me to death. I would like to try the spring swap ( to get my truck off the overload springs) and install some Blisteins.....
1997 F350 XLT, CREW CAB, POWERSTROKE, AUTO,
278,000 MILES. TYMAR INTAKE SYSTEM. 3" down pipe,
4" exhaust. 14-16 mpg, RSK with SD springs, 315 Dick Cepek Mud tires on 10" rims and BULLYDOG 4 BANKS CHIP, Bilstein Shocks
I got the springs but haven't had the time... they will bolt up but you need to change bolts-hole size [img]/ubbthreads/images/graemlins/shrug.gif[/img] can't rember offhand. Relocate the overload stops to match the DS overload spring, keep 2"clearence for a softer ride.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
I am interested in this as well. Do the stock superduty rear springs ride better than our stock ones? Same cargo capacity?? Would they provide the same ride height? I have access to some stock ones I could just trade out.
1996 F350 XL, PSD, CC, LB, SRW, Green/White, 4x4, 4L10, ZF5, LUK clutch & flywheel, 295/75/16 BFG AT on 16 x 8 Centerlines, Bill's Race chip, gutted EBPV, Ceramic coated Hypermax downpipe, Tymar 4" exhaust w/Donaldson muffler, Tymar Intake, Tymar boost pop-off valve, Tymar HX hose, Tymar coolant filter, JD Coolant eye, AC & fuel tank mods, Autometer Pyrometer & Boost gauges in pillar pod, Warn Premium hubs, Powerslot rotors, Smittybilt nerfbars, add-a-leaf & poly bushings, Bilstein shocks, Drawtite front receiver, Optima red tops, 130W Stainless KC Daylighters, stainless Ventshades, Eclipse CD player, MB Quart speakers, JL sub, Phoenix Gold amps, Viper alarm, Cobra CB, 2001 Honda CR250, 400EX & ATC 70 in the bed, not much more to come...
I have a set that I will be putting in soon, but the bushing are different sizes and I need new ones, they are very heavy looking so I don't know about ride but they look stiff! as for wieght whatever you can throw at them befopre you break the truck itself.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
unfortunatly we got tied up with a stupid ol dodge tranny so the spring swap hasnt happend yet, Maybe i can get him rolling and we can do it this weekend?
Travis
SWAMP'S Extreme Powerstroke Performance
2L Motorsports
Charter Member of www.FOKISD.ORG
99 F350 ext dually 2crueL (moded somewhat)
86 F250 4x4 - C6 3.55Ls[b]
The Mule 1995 F350 CC - 4x4
95 E350 PSD 190k miles
97 F250 ext lb 160k 4x4
97 FSuperduty Plumbers Truck
93 Ranger (soon to have twinned 4bt) My Webshots
You can just drill out the sleave and the shackel's to match, use new bolts [img]/ubbthreads/images/graemlins/wink.gif[/img]
Cary
2006 Yamaha FJR1300
I erred last weekend(?) when I said Shawn had installed the 6" SD lift springs into the rear of his 95...but we are 1/2 way through the installation of them today...
These were bolt in, with the exception of having to drill the rear shackle for a larger diameter bolt.
Should be completed in an hour or two...
take care~
dave
Powering the Fastest (no drugs) Power Strokes @
Thunder in Muncie 2004
TS Performance All Diesel Challenge 2004 Indianapolis Diesel Nationals 2007
Scheid's Diesel Extravaganza 2007
Powering the top Ford pullers @ the Indianapolis Diesel Nationals 2006 Indianapolis Diesel Nationals 2007
