I have several OBS Superduties (F450's) and they are prety stout. None of them are 4x4 though. I imagine the parking brake set up on a 4x4 is custom. The wheel brakes are fine, but the parking brake set up on the 2x trucks is the pits. It is expensive, holds verly little oil in the bearing compartment and leaks easily. But it is the only wek link beyond the usual OBS issues .
Diesel Mechanic 28 yrs
