10-31-2007, 09:52 PM
#1 (permalink )
superduty mirrors on obs
i want to put the superduty telescoping mirrors on my 94 f350, i thought i saw a post a while back about this. has anyone done this ? any advise is appreciated!
10-31-2007, 11:04 PM
#2 (permalink )
Re: superduty mirrors on obs
I know it has been done. I believe they took out the vent window and welded in to fill it and then mounted the mirrors.
97 F-250 Crewcab,4X4, 4.10 gears, coolant filter, 203 deg. thermostat, coolant eye, Bilsteins, 255/85R16s.
00 Ural BC-65.
97 Honda Foreman.
"A little rebellion, now and then, is a good thing." Thomas Jefferson
10-31-2007, 11:15 PM
#3 (permalink )
I have seen two in person, they take the place of the wing windows....Only problem I would be concerned with is it looks like it creates a heck of a blind spot...
1997 F-250HD SuperCab ●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
10-31-2007, 11:27 PM
#4 (permalink )
I remember the posts on it (as described above). The resulting "look" is not for everybody. Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch,
Baldwin Filter ,
Tymar HPX Hose , DPPI DP, Bilsteins,
$12 AIC ,
Coolant Filter , Stancor GPR,
Explorer Overhead Console ,
A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) ,
Relocated Block Heater Plug ,
Modified Pedestal , Gutted EBPV.
11-01-2007, 09:58 PM
#6 (permalink )
thanks for the links. your right imnot sure i like the look. any other ideas for a better rear view while towing
11-01-2007, 10:16 PM
#7 (permalink )
The RV style mirrors should get you out at least that far, if not further. Plus you keep your wing windows and maintain that OBS look!
Like these!
Kurt
SOLD!!
1997 F350 XL PowerStroke 4WD, ZF-5 w/ South Bend Con OFE Clutch
Regular Cab, Long Bed, SRW, 3L55's, Bilstein shocks, Warn premium hubs
3-inch downpipe/4 inch exhaust w/ Magnaflow muffler and cat
Tymar intake
International Water Pump with integrated filter
Wildman Four-Position Chip; Baby Swamps; D66 turbo with 1.00 housing; SD HPOP
Isspro EV Boost and Pyrometer gauges
285/75R16 E-Rated BFG All Terrain KO's
Rear Disc Brakes from Blackbirds Custom Trucks
Pictures of it all...
11-01-2007, 10:29 PM
#8 (permalink )
If you go with the RV mirrors just be carfull. If you hit them on anything it can total the door.
BTW - I am looking for a good driver side door. [img]/forums/images/%%GRAEMLIN_URL%%/blush.gif[/img]
1996 F350 XLT CC LB 4x4 120K, E40D
Tymar Intake, Magnaflow 4" SS Exaust, Edge Evo, FPR Shim, SKY RSK w/SD vcodes, Bilsteins, Velvet Ride Shackles
TRUCK PICS
2004 Outlander Max 400HO (mine)
2004 Rally 200 (hers)
2004 Grizzly 80 (sons)
11-02-2007, 02:06 AM
#9 (permalink )
What about the ones that slide over the paddle style mirrors, not sure who makes them, but they work good I hear
97 F-250 PSD, Extended Cab, 4x4, Automatic, 3.55's, 102,000 miles, Dead Kitty, 3" Down Pipe, 4" Exuast, No Muffler, Tymar Intake, 3 Guage Pillar Pod, Issopro Guages, Tony Wildman 4 Postion Chip, RDS Stage 1's, EBPV delete, Shimmed FPR, SD Intercooler, Warn Lock Outs, 08' Diff Cover, Flip Up Gooseneck, 40,000 lb GVW Trans Cooler, BTS Trans!!
Next project: Install my D60 and F-350 suspension
305 HP/ 610TQ on 1/19/08
TRUCK PICS @
http://www.myspace.com/captinsmiley70
Dyno Video @
http://www.youtube.com/watch?v=vhj2noJTN_g
11-04-2007, 09:03 PM
#10 (permalink )
JC carries them, I have em they help quite a bit as the paddles arent very good but vibration is really annoying and they shake pretty good
Kevin
94.5, PSD, F-250, 4x4, Handshaker,
Couple Do-Dads
05-02-2008, 12:39 AM
#11 (permalink )
ok so it wont let me view the the pics of the sd mirrors on that guys truck anybosy got pics of it id like to see it before i do it.
05-02-2008, 12:40 AM
#12 (permalink )
ok so it wont let me view the the pics of the sd mirrors on that guys truck anybody got pics of it id like to see it before i do it.
05-02-2008, 12:25 PM
#13 (permalink )
they are in the TDS gallery, probably just search "mirror conversion" or something like that.
edit: actually that was pretty easy it came up right away,
Front view of door - TheDieselStop.Com Photo Hosting
Reason: added link
05-02-2008, 12:36 PM
#14 (permalink )
That makes quite a blind spot. I'd rather be able to see what's in front of me than what's behind me.
1987 F-350 CC 4x4 - 7.3 idi, Banks Turbo, C6, 6" lift & 35's
2006 Dodge 3500 Mega Cab 4x4 - Cummins 6 speed
05-02-2008, 01:14 PM
#15 (permalink )
wow that is a blind spot im not sure if id wanna do it, still thats really different
Linear Mode
» Site Navigation
» Other Sites
