Those with XL model trucks........ - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 04-01-2007, 01:12 AM   #16 (permalink)
Re: Those with XL model trucks........
As far as i know the buttons are on the wheel, not the pad due to the airbag i suppose. Someone correct me if I'm wrong!
...John...
1994.5 powerstroke F-350 Reg. Cab. 5 Speed 2WD DRW 4.10, Oxford White, Cab and Chassis converted to electric over hydraulic dump bed. Diy Aic, switched 10k mod, Diy exhaust brake, Autometer Boost and Pyro gauges. DIY tymar. 3" downpipe. No exhaust after downpipe Dp-tuner F5, No Start, Stock, 40 Tow, 80 Eco
1997 F-350, 2WD, 4.10, White, ZF5, CC, XLT, Downpipe, DP Tuner, No start, stock, 40 Tow, 80 Eco, 120 Race
2003 F-550, XLT CC 4wd, 4r100, Tuscany Automotive Starhauler Conversion. DP Tuner F5. 6.0 Trans cooler. DiPricol Optix Boost, EGT, Trans
lawnboy1988 is offline
Old 04-04-2007, 04:47 AM   #17 (permalink)
Ford offers or at least offered in 2000 a cruise control install kit for the 2000 model trucks. Assume it fits other years. My friends 2000 accidentally got ordered with no cruise when the order was bumped from a '99 to a '00. The kit included steering wheel, buttons and some other stuff. It's more difficult and pricey than the horn pad install on the '94-'97. Pictures were taken and I thought I posted them. Might be buried in the archives or my memory may be bad. If you are interested PM me and I can try and track down the info. Only problem was we never could get the buttons to light up like on the XLTs with factory cruise.
'94 F350 4x4 PowerStroke, 5-speed, 4.10 gears, crew cab, XLT, Luk Clutch, ZF-47, Hydroboost, AIC, Max A/C Assist, 95.5 radiator and degas bottle 315,000 miles
'96 F350 4x4 PowerStroke, auto, 4.10 gears, crew cab, XLT, DRW conversion, AIC, 451,000 miles
'02 F350 4x4 PowerStroke, 6-speed, 3.73 gears, crew cab, XLT, DRW, AIC, 180,000 miles
Diesel_Aggie is offline
Old 04-04-2007, 04:20 PM   #18 (permalink)
SlopeTruck's Avatar
My Photos: (29)
The models before and after the OSB/OBS all have the buttons mounted off to the side of the horn pad (if on the steering wheel...) Ours are the only ones with it mounted on the horn pad.
[color:"blue"]WEBSHOTS[/color]
'00 F350 CC 4X4 longbed, wht, Lariet pkg. She's pretty! Open element intake, 4" exhaust, A-pillar pod w/ Isspro gauges, TW 4 pos. chip, leveling kit, 315-70-17 BFG AT's on black alloy rims, and...
SOLD '95 F350 CC 4X4 (ex-slope truck) flatbed. Open element intake, 3-4" dp, 4" straight pipe through bumper, shimmed FPR, IDM mod, TW 4 pos. chip, DIY RSK/shackle flip, 315-70-17 BFG AT's, H2 rims, 4.10's, rebuilt E40D, 3 guage a-piller pod w/ Isspro guages, DIY rear disks, SD front bumper, Warn 8000# winch, Explorer power buckets, Dodge center console/seat...
Play/plow truck '81 F250 on 40X17's. Bored 351W, S/C bobbed 3', 4 wheel discs, solid axles, Detroit, 2 winches, lots of DIY stuff.
Commute Vehicle: '07 American Lifan LF200GY, 1 cylinder, 16 hp, street legal enduro bike of Chinese origin. Top speed= maybe 70 mph but gets 80 mpg
SlopeTruck is offline
Old 04-04-2007, 05:03 PM   #19 (permalink)
Racer_X's Avatar
Most likely factory. The only way to get cruise from the facotry was with tilt steering. Ordered 2 XLs that way.
I can confirm CC was a factory option on XL trucks. Never looked for the tilt. I Have a parts truck and the options are cruise, 4X4 and radio. It belonged to Ga Pac and was used to inspect tree farms. Thats why a 4X4 and cruise. Hwy miles 90% off road 10%.
The Racer X Built E4OD THAT CAN Video. 1997 F-350 7.3 Twin Turboed Power Stroke Diesel. Fueled with 473 + cc's of Diesel and nitrous!
Family owned & sponsored by : FloridaNorth
For Fuel - D.J. @ DIY-injectors.com
"AMERICAN INGENUITY " Half of AMERICAN is I CAN."
Racer_X is offline
Old 04-04-2007, 09:14 PM   #20 (permalink)
I didnt mean to start anything by the subject title "Those with XL model trucks..." I assumed all Xl's came w/o cruise unless ordered. My bad. Maybe the mods will let me revise the title so that it'll be correct and rename it in such a manner that a search will hit on it.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 04-08-2007, 08:03 PM   #21 (permalink)
I was able to track down the 10 page instruction manual from when we did the factory accessory cruise install on a friends 2000 F-350 Stroke, 6-speed, 4x4, XL. The 2 part numbers below are what is on the instruction sheet. I believe the top number will be for the kit.
XC3Z-9A818-AA
SKXC3J-9A818-AAW
Contents:
Steering wheel w/buttons
Clockspring harness
philips head screw
2 butt splice
1 wire harness/connector
Old 04-09-2007, 11:15 PM   #22 (permalink)
Jeremy's Avatar
My Photos: (13)
For the 99-07 7.3 and 6.0 PSD's, you can buy the kit or just build your own. A couple of resistors and two switches from radio shack, and your in business.
11 F350 CC King Ranch Auto 4x4 stock for now
07 F350 CC King Ranch Auto 4x4 PHP FICM, PHP Gryphon Custom Tuner
06 F250 SC XLT Auto 4x4 LWB 3.55 gears, PHP FICM, CTS Juice(with PHP custom tunes), studs, EGR Delete.
05 Excursion Eddie Bauer Auto 4x4 PHP FICM, CTS Juice(with PHP custom tunes), Studs, EGR Delete, ctperformanceinc's XF suspension mods
00 F350 CC Lariat PSD 4x4 PHP Gryphon Custom Tuner 6 speed, US Gear OD(dead looking for parts),
94 F-Superduty PSD 5 Speed 12' flatbed
93 F-Superduty 7.3 IDI N/A 5 speed 12' Dump box 60,000 org. miles
Thanks to:
Power Hungry Performance
and
CTperformanceinc
My photos
Jeremy is offline
Old 07-19-2007, 12:07 AM   #23 (permalink)
Bringing back an old thread.... [img]/ubbthreads/images/graemlins/smile.gif[/img]
I just got the clock spring/Steering wheel installed on my truck. Does anyone here know where the splices and such are supposed to go? It does not yet work. Also what kind of splices are needed? I didn't get the kit, just the steering wheel and the clockspring.
Thank you
Ryan
99 F250 XL PSD 6Speed Supercab Longbed 4x4 DIY Air Intake
rpenner54 is offline
Old 07-23-2007, 01:35 PM   #24 (permalink)
All you should need is the horn pad with the cruise buttons, and to jump the harness under the hood?
I just FINALLY got around to making mine work. The horn pad I bought for some reason had a different non-OEM connector, so I had to do some splicing magic to get it working with the extra wire in the old connector. A true OEM horn pad shouldn't have this problem, I think mine was a cheap knockoff or something, I got it new on ebay.
Works great though, I am sooo glad to finally have cruise control!
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
ryanPSD is offline
Old 07-23-2007, 07:44 PM   #25 (permalink)
Ryan, I think rpenner54(also Ryan) is talking about his '99, a different set-up. Glad you now have cruise though. Easiest mod I've ever done.
Randy
Old 07-24-2007, 04:32 AM   #26 (permalink)
Oops.... didn't notice that. [img]/ubbthreads/images/graemlins/blush.gif[/img]
- Ryan
285HP
ryanPSD is offline
Old 11-08-2008, 05:22 PM   #27 (permalink)
KB3MMX's Avatar
Any way to wire cruise on a XL without using a factory steering wheel pad?
I was thinking about mounting a on/off Arming switch and a momentary contact "set" switch if possible??
Is there any pics of the wiring and which wire controls what ??
THANKS !!!
PS> I have a 95' XL truck without the Tilt steering wheel.
I have no idea what wires I would need to find under the dash to hook up the cruise...
---Si Vis Pacem Parabellum---
KB3MMX is offline
Old 11-08-2008, 05:45 PM   #28 (permalink)
bugman's Avatar
My Photos: (18)
Just go to the junk yard and find a cruse horn pad and you are good to go.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 11-08-2008, 11:07 PM   #29 (permalink)
KB3MMX's Avatar
Jim
Awesome !!
Thanks!
KB3MMX is offline
Old 11-10-2008, 04:57 PM   #30 (permalink)
Which two wires?
My three wire colors are as follows:
Black
Green with yellow tracer
orange with green tracer
The order listed is while plugged into the dummy plug on the master cylender starting with black towards the front of the truck and orange w/ green an the futhermost rear of the plug.
Which two do I connect with my jumperharness?
Thanks,
John
Calf_roper_John is offline
