Those with XL model trucks........ - Page 3 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-14-2008, 08:49 AM   #31 (permalink)
Bump..... Please read the above post. None of the combinations work, I'd like to know which combination I need to run the jumperharness to so I can get the bugs worked out.
Calf_roper_John is offline
Old 11-15-2008, 12:41 PM   #32 (permalink)
KB3MMX's Avatar
John, mine only had two wires on the plug under the hood that was attached to the rear of the fuse box.
The plug shouldn't be on your master already unless it was a factory cruise truck from what I've read.
I may put a cruise control master cylinder with sensor on mine down the road when I wear out the current non-cruise one that's in my truck...
Originally Posted by Calf_roper_John View Post
My three wire colors are as follows:
Black
Green with yellow tracer
orange with green tracer
The order listed is while plugged into the dummy plug on the master cylender starting with black towards the front of the truck and orange w/ green an the futhermost rear of the plug.
Which two do I connect with my jumperharness?
Thanks,
John
---Si Vis Pacem Parabellum---
KB3MMX is offline
Old 11-15-2008, 10:13 PM   #33 (permalink)
Thanks for clearing that up. I was in the wrong plug. Thanks, John
Old 12-14-2008, 01:31 PM   #34 (permalink)
Just finished this up today! I got the pad off ebay brand new for $20 bucks. Mod only took 10 minutes to do!! If you haven't done this already, do it now.
I'm getting ready for a trip to florida from ohio and I refused to do it again without cruise. This should be the best drive yet..
1996 PSD, XL, 2wd, SRW
331,000 miles. Amsoil Synthetic, and Cat extended life coolant. Diesel Site 203* T-stat. 4 inch straight piped exhaust. Tymar intake. Leather Captains Seats. 120 gal. Heated Veggie tank in rear. Shimmed FPR. TS 6 Pos. Chip (stock, hi-idle, 50,75,100,140). DIY Stage 1 160cc injectors. Valaire Con O Clutch. Stainless 10" drop 15K hercules rear bumper. 3 gauge pillar pod: autometer digital boost, pyro, voltmeter. BFG AT's 285/75/16
Pulling a 31' 1985 Airstream Excella
1986 Hunter 23
huberjoshua is offline
Old 02-16-2010, 09:02 PM   #35 (permalink)
Got the pad today and put on. I was under the understanding that it would work with just this being done and the jumper wire was only a failsafe rig for if the brake light went out. Mine is not working by just replacing horn pad. Should It?? Also, its a gasser but I am told it dont matter. Talk to me boys...
Thanks,
MW
MightyWhitey is offline
Old 02-17-2010, 02:42 PM   #36 (permalink)
KB3MMX's Avatar
no problem John
KB3MMX is offline
Old 02-17-2010, 02:44 PM   #37 (permalink)
KB3MMX's Avatar
Exclamation
Thanks,
MW
You have to jump the plug under the hood for it to work.
KB3MMX is offline
Old 02-18-2010, 08:49 PM   #38 (permalink)
Can anyone post a pic of where this dummy two wire plug is and what it looks like? I have one that fits the bill but not sure if its the right one. The color of wires dont match and when I jumped it,,,,,,,,,,, nothing The dummy plug wiring comes out the main wiring on the Power dist box and curls around and is attached back to the outside of the power dist box. There must be another one but I am not seeing it...
Old 02-18-2010, 09:59 PM   #39 (permalink)
KB3MMX's Avatar
PIC 1
KB3MMX is offline
Old 02-18-2010, 10:02 PM   #40 (permalink)
KB3MMX's Avatar
PIC 2
KB3MMX is offline
Old 02-18-2010, 10:05 PM   #41 (permalink)
KB3MMX's Avatar
PIC 3
KB3MMX is offline
Old 02-18-2010, 10:08 PM   #42 (permalink)
KB3MMX's Avatar
Wires are:
Black W/ Green stripe
Purple w/ Orange stripe
KB3MMX is offline
Old 02-18-2010, 11:30 PM   #43 (permalink)
I think I have the right connector. I am thinking that since its a gasser it wont work. Some are telling me that I need a cruise control motor and wire... Not sure what to think... I surd do appreciate your posting up pics and help though....
Old 02-19-2010, 10:01 AM   #44 (permalink)
bugman's Avatar
My Photos: (18)
It has been a long time since I even looked at a gas motor on a truck so I could be wrong. Check and see if your gas pedal is connected to the engine compartment or engine with a cable. If it is you will need the motor and cable. On the Powerstroke the pedal is electronically controlled and there is no need for a cable.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 08-05-2011, 06:51 PM   #45 (permalink)
Hate to dig up a old thread but a couple of quick questions
I just installed this mod today but my wiring is a little different I have brown with orange chaser but my black has a yellow chaser .... Am I in the wrong plug ?
The other question I have my horn stopped working last week would my 97 f350 manual 5 speed have a clockspring ?
Ranzan is offline
