Tony Wildman Chip Problem - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 06-01-2012, 12:45 PM Thread Starter
1995 F350 7.3 Power stroke Diesel Engine Problem - YouTube
I have installed a Tony Wildman Chip in this truck. The Truck is a 1995 F350 7.3 Power Stroke with a 5 speed standard. The Truck has 310,000 Km and is in fantastic condition. When the chip is not installed the engine runs great with no problems at all. However, once I plug the chip in, the truck romps as per the attached video. If I rotate the clicker on the switch to the High Idle position hence increasing the engine RPM the engine will stop romping and will settle down to its proper idle rpm once I return switch position to any other position other than high idle. My other alternative to stop the engine romping is to push the throttle down to increase rpm for approx 1 or 2 seconds and then let my foot off the accelerator and the engine will settle down and the romping will stop. Once I have the truck idling properly which takes all of a couple seconds the truck will drive proper with no further problems. If however, I shut it off and then immediately re-start the engine the truck will romp and I have to go through the same sequence to get it to settle down again. I have swapped out the Fuel Control Unit but the truck continues to romp immediately after the start. We have just installed a new fuel pump but the truck continues to romp. Does any one have a fix or suggestion for this problem. Thanks for your comments.
grummen goose guy is offline
post #2 of 14 (permalink) Old 06-01-2012, 02:28 PM
BadDogPSD's Avatar
Have you called Tony?
2013 F350 CC LB Lariat 4x4
BadDogPSD is offline
post #3 of 14 (permalink) Old 06-01-2012, 04:43 PM
Sounds like your chip is in the "extreme" position. Try it on another setting. Why injectors do you have?
1997 F250 Crew Cab Short Bed 4x4 Auto 4" skyjacker lift 130K Dana 60 Front 4" Straight pipe lost kitty 5" Silverline tip Factory Alcoas on 315/75/16 All Terrains
Got4wd is offline
post #4 of 14 (permalink) Old 06-03-2012, 03:12 PM Thread Starter
They are stock injectors. The truck romps on every chip setting ... except for the high idle ppsition. A mechanic friend of mine says it needs more fuel ... to turn up the idle ... can I do this with a 95 7.3. Can i turn up the idle?
post #5 of 14 (permalink) Old 06-04-2012, 02:13 PM
BadDogPSD's Avatar
No, you can't turn up the idle, but Tony and change the idle rpm by adjusting the chips programming. Pretty much the only adjustment you can do is the fuel pressure. Check the pressure at the schraeder valve on the drivers side of the fuel bowl. You want it to be 55-60 lbs. If it's less, you can pull the regulator and shim the spring using a BB (or something similar).
post #6 of 14 (permalink) Old 06-08-2012, 05:45 PM
dieselcamino's Avatar
Just got my new Wildman chip in the mail as well, it too romps at idle in every setting at start up for a few seconds, now my truck wont run at all with the chip installed
1996 f-250 PSD xlt single cab longbed
Tymar intake/Tymar Hpx line
custom 4 inch turbo back side pipe
swamps injectors
wildman 6 pos. chip
87' king pin d60
35" bfg mtr km2 on american racing rims
-Bio-diesel ready-
dieselcamino is offline
post #7 of 14 (permalink) Old 06-08-2012, 06:13 PM
1dieselman's Avatar
My Photos: (12)
Are you positive that you got both sides of the pcm connector perfectly clean before plugging in the chip?
Jack
97 F250 XLT CCSB 4x4, Dana 60 swap, custom built E4od, Baby swamps, 1.0 turbo housing, deleted ebpv, 203* t-stat, high pressure X line, Diy 140v Idm, 6.0 fan, Diy 6637, tunes by Dp tuners, Isspro Ev gauges, Diy intercooled, 3" downpipe 4" exhaust, 6" lift, 4:10 gears, 35" tires, 315,000 miles
1dieselman is offline
post #8 of 14 (permalink) Old 06-22-2012, 06:34 PM Thread Starter
I sent the chip back for a reflash. Anxiously await it's return.
post #9 of 14 (permalink) Old 08-20-2012, 11:36 PM Thread Starter
I got my chip back today with the reflash and the truck has stopped its engine romping problem. So ... Here is my conclusion . You cannot install a chip tuned for an automatic transmission into a Manual truck of the same year without a reflash to change its computer tune. It took 2 months for the chip to return with the reflash. It was a long wait but I am happy for the new tune.
post #10 of 14 (permalink) Old 08-22-2012, 07:46 PM
BadDogPSD's Avatar
That's correct, the tuning is different for auto's & manual transmissions.
Glad you got it worked out!
post #11 of 14 (permalink) Old 08-31-2012, 10:09 PM
DavidD's Avatar
Atleast your problem was resolved I installed 1 of tony's 6 position chips last oct left 3 messages never got a return call. My issue is in any chip position my glow plugs do not come on anymore.
93 F-250 7.3L XLT Extended cab 2wd 235K Auto.
95 F-250 PSD XLT 4X4 E4OD Tony wildman 6pos chip, Custom intake,pillar Gauges
89 F-350 7.5L 5spd Dump
96 F-350 PSD 5 spd Dump
99 F-350 PSD 5 Spd Dump
96 IH 4700 DT466 7Spd Dump
2002 Isuzu NQR Dump was a box until I solved that problem.
DavidD is offline
post #12 of 14 (permalink) Old 09-01-2012, 12:19 AM
Just so you know and it's not an excuse,Tony's daughter is ill and he is buried.
Rusty
1997 F250 CC, SB 4x4, 220,000 miles, 7.3 PSD, E4OD, 3.73 gears, Kingpin Dana 60, 10.5 rear, True-trac, Sky 3" RSK, D-code spring in front, B-codes in back, F250 blocks
rusty1161 is offline
post #13 of 14 (permalink) Old 09-01-2012, 02:36 AM Thread Starter
That's an interesting comment because my glow plugs don't seem to be working properly either. I just thought I needed new ones. This new problem has begun immediately after installing my re flashed trip. Will it correct itself if I pull the chip out?
post #14 of 14 (permalink) Old 09-01-2012, 10:21 AM
DavidD's Avatar
If I pull the chip out they work like they always did before.
DavidD is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
