This is a '97 F350 4 door 4x4, 38" tires, chip, intercooler creates 20lbs of boost. We keep breaking the trans adapter. Any suggestions or aftermarket items that would be a solution to this problem? We have tried the more modern adapter and broke that too.
JayMM
The one between the engine and trans or the one between the trans and transfer case?
Diesel Mechanic 28 yrs
When is it breaking? Coming off of being airborne or ? In other words is it breaking from torque or impact? Tell us a little about how you use the truck.
There is a steel replacement for that part. I know Bryan at BTS puts one on all his 4wd transmissions. I seem to remember something about there being a limited supply of them [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Travis
1997 F-250 HD 4x4/OR SC LB XLT PSD E4OD 3.55LS, TDE1, Baby Swamps (150/146/A), BTS Trans, BTS programming, Front and Rear Replacements, Gooseneck, Autometer Pyro, Trans Temp and Boost in Rockin' S Pod, Cab/Clearance Lights installed, Tymar style intake, 6.0 Intercooler, Tru-Cool Max tranny cooler, Warn Premium Hubs, Shimmed FPR, Gutted EBPV, Super Duty 3" DP, 4" Exhaust, 175,000 mi., 7400 lbs., 310 HP 559 TQ
We have a feeling that the yoke doesn't have enough slip in it so we are impacting into the u-joints, plus we have no clearance between our driveshaft and cross member, there is only 1/16" or less. This is all the front driveshaft, not the rear. We just were driving into a 2' deep ditch the first time or possibly doing a burnout in the rain with the 39" tires, so it possibly could have been torque that time. Plus we have detroit lockers front and rear. The second time we broke the adaptor was going through a 4' deep ditch. The first time it broke, we just had a shop fix it for us and didn't realize the clearances.
Are you breaking the cast iron one or the alum. one? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
97 F-250 H/D 4 door 4X4 6'bed.Broke block building new engine! Oh well it ran14.96 at 89mph at Baytown!
Kenworth T-600 aerodyne 3406c CAT, with 18* "B" modle injection pump(was a freakin peak yuk),10 over trans,4.10 rears,Dual 150 gal. fuel tanks,Budwieser inspired custom hot rod flames.Going to work real soon Leasing to Landstar yeah!
89 mustang coupe single turbo 302 ,built c-4,running little rubber.
I hate Dodges, straight piped common rail cummings sound like crap!
They were standard 4r100. Driveshaft, i think your right. Fix that anyway. May save you from twisting shaft splines.
__________________ TheRacer XBuilt E4OD THAT CAN Video. 1997 F-350 7.3 Twin Turboed Power Stroke Diesel. Fueled with 473 + cc's of Dieseland nitrous!
Family owned & sponsored by : FloridaNorth
