Old 03-23-2006, 11:11 PM   #1 (permalink)
My Photos: (6)
Trans Fluid Question
Folks,
I went to buy some trans fluid the other day and it seems Mobil I has changed. The last I bought was Dexron III/Mercon rated. The closest now includes Mercon V along with the other two. Since the current wisdom is that this is not an acceptable fluid, I'm in a quandry. What other synthetic with the correct rating have you had good luck with?
Thanks,
John
'97 PSD F-250 SC/LB E4OD 4:10 4WD
BD DOWNPIPE , BILSTEINS , SKYJACKER ADD-A-LEAFS , CAT DELETE OPTION W/ STAINLESS FLEX , TDE1 CODE, OPEN ELEMENT, HX CROSSOVER, 4" EXHAUST
6.0 TRANS. COOLER (click below for install pics)
http://photos.thedieselstop.com/show...at=500&thumb=1
Rocket J is offline
Old 03-23-2006, 11:36 PM   #2 (permalink)
My Photos: (5)
Re: Trans Fluid Question
specialty formulations, will be going in mine once I pull and redo the unit.
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
Old 03-24-2006, 02:06 PM   #3 (permalink)
im runnin amsoil in mine and have had great luck with it the other day i had a truck with amsoil in it and the trans was startin to slip so i changed fluid in it to get it by and i found out that the amsoil in it that was a lil burnt is better than the cheap stuff i tried in it....the trans is worse now than it was b4 [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Joey
97 F-350,XLT, 4-dr, auto, 270xxx mi, Geolander A/T's, 4"exhaust, no ebpv, 203* t-stat, electric fans, lunar gauges, amsoil nose to tail, custom weight bracket and hitch for pullin, diy intake/air filter, hpx hose, LED cab lights, extra fuse panels, kenwood stereo system, pedestal from Rick, 4r100 out of an '01, trans mods from Jon, custom big fuel system, arb's front and rear, and 6.0 i/c, custom big oil
pics
"...the smoke rolled out and the day turned BLACK!"
stage II's
D66
THANKS BEAN!
awesome tuning
THANKS TONY!
'06 M7 153" Let it Snow!
joeyslushr is offline
Old 03-26-2006, 03:17 PM   #5 (permalink)
Even Motorcraft Merc V meets Dex 3/Mercon standards. My understanding from a Motorcraft distributor is Merc V is a synthetic or semi synthetic fluid. I've run Merc V in mine with no problems. A friend of mine that owns a tranny shop puts Merc V in all Ford rebuilds. You'll be fine with the Mobile 1.
'96 F-350 Crew Cab Dually XLT, E4OD w/sonnex & tricume springs, 4:10 gears, Western diesel down pipe & HX hose. B&M Hi-Tek trans cooler w/fan. DP Tuners F5. Tymar intake & 4" exhaust.
blever is offline
Old 03-26-2006, 05:05 PM   #6 (permalink)
My Photos: (5)
not to bring out the meron vs mercon V debate but to a stock e4 4r it is not to be used. It is a long term deal where the problems can occur, but again fords postion is not to use it in these paticular trannsmissions. Why take a chance when the proper stuff can be found and used? I would not put it in mine....its your choice [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1999.5 cc dually
Old 03-26-2006, 07:00 PM   #7 (permalink)
hheynow's Avatar
Redline synthetic ATF is Mercon rated. I use it.
Which ATF for a specific Ford transmission?
1997 F-350 PSD XLT RC 4x4 E4OD
303K miles and still running very strong
Using WVO and biodiesel since May 2006
hheynow is offline
