Transfer Case - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 07-10-2007, 01:09 PM Thread Starter
stang65fst's Avatar
Transfer Case
I need to buy a new/used transfer case for my truck. I have been searching around and keep coming up with a Warner 1356 or Warner 4407. Can someone help to as to which one is used for our trucks. I also want it to be a manual transfer case, not electric.
Or any good suggestions of alternative transfer cases or where to purchase. This is just a tow vehicle no off roading will be done.
Todd
AKA Toad
1997 Ford F350 7.3L 4x4 automatic, Warn manual hubs, DP Tuner 6pos chip
1994 Ford FSuperduty 7.3L 5sp Rollback, 3"-4" DP, non EBVP pedestal, 4.30 Gear, Detroit TruTrac Limited slip
1989 Ford FSuperduty 7.3L 5sp Wrecker Facet electric fuel pump
stang65fst is offline
post #2 of 13 (permalink) Old 07-10-2007, 01:39 PM
STurbo90's Avatar
My Photos: (9)
Re: Transfer Case
94-95 used 1356, 96-97 used 4407.
is you have a slip joint it should be 1356, if you have a flange output it should be 4407
PSD,CC,LB,E4OD,4WDw4:10LS
STurbo90 is offline
post #3 of 13 (permalink) Old 07-10-2007, 01:45 PM Thread Starter
stang65fst's Avatar
Re: Transfer Case
Considering a transmission is going to be replace also is there a better combo over the other? Or is one transfer case stronger?
Any E4OD trans has same bolt pattern to the motor correct?
Todd
AKA Toad
post #4 of 13 (permalink) Old 07-10-2007, 01:47 PM
Re: Transfer Case
I'm curious as to the functional differences too. My understanding is the 4407 uses some type of viscous clutch?
'94 F350 4x4 PowerStroke, 5-speed, 4.10 gears, crew cab, XLT, Luk Clutch, ZF-47, Hydroboost, AIC, Max A/C Assist, 95.5 radiator and degas bottle 318,000 miles
'96 F350 4x4 PowerStroke, auto, 4.10 gears, crew cab, XLT, DRW conversion, AIC, 502,000 miles
'02 F350 4x4 PowerStroke, 6-speed, 3.73 gears, crew cab, XLT, DRW, AIC, 223,000 miles
Diesel_Aggie is offline
post #5 of 13 (permalink) Old 07-10-2007, 03:11 PM Thread Starter
stang65fst's Avatar
Re: Transfer Case
Are our transfer cases, gear driven or chain driven?
Todd
AKA Toad
post #6 of 13 (permalink) Old 07-10-2007, 04:58 PM
Re: Transfer Case
Todd,
Since your truck is a 1995, you've most likely got the BW 1356 T-case. The transfer-cases are all chain driven since the end of the cast-iron NP 205, which I believe occured around the very late 70s/early 80s. The Borg-Warner 1356 has proven to be a good transfer-case, however, be careful to use a torque wrench to install the drain and fill plugs as the magnesium case will crack if the plugs are over-torqued. Also, I prefer to run synthetic ATF in the T-case as it is more tolerant of the conditions the T-case will see, compared to regular ATF.
Hope it helps,
K.N.
3/94' F-250XL 4x4,PowerStroke Diesel power, DP-tuner flashed to MLE1, H.D ZF 5-Spd. w/SBC Con-O clutch, Std. cab, 3.55, Mobil 1 syn. in T-case, Castrol TranSynd in tranny, Chevron's DELO 400 & Fleetrite Anti-Foam Additive, Valvoline's Durablend 85w-140 in rear, LT265-75R-16 Mickey Thompson Baja ATZs, 373,000 miles, Tymar Intake, TS 6-pos chip, Banks 3" 409 Stainless Downpipe, S.D. 409 Stainless Cat Delete, Hidden Hitch, Stock
K.N.94PSD is offline
post #7 of 13 (permalink) Old 07-10-2007, 06:20 PM Thread Starter
stang65fst's Avatar
Re: Transfer Case 4wd Conversion
Todd,
Hope it helps,
K.N.
Indeed it does help!!!! Thank you very much. Just trying to soak all the info up that I can. Don't want to get the wrong thing and waste money.
Even though I am only towing I wanted to make sure there wasn't an upgrade that was close in price and easy bolt on like that NP205. I just want to make sure it is a proven piece.
I have been a bit deceptive in my questions. I am converting my truck to 4wd. It is not an option for me to sell and buy another, and I am attached to the old girl. And every thread I have read someone jumps in and yells sell and buy one with 4wd. So I beat around the bush to find my answers.
From my understandings I can swap in basically a F350 axle, steering components and suspension a to get the straight axle like I want. I want a D60 for obvious reasons.
Am I correct in my thinking? I know there is some welding and cutting that must occur but I do not want the IFS.
Again any knowledge on this subject is appreciated.
Todd
AKA Toad
post #8 of 13 (permalink) Old 07-10-2007, 08:39 PM
Briansshop's Avatar
Yea a little welding and drilling holes,no big deal.A shackle rev kit will save you alot of fab work up front.When I did mine I picked up a new 1356 from National Drivetrain.
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,up on 38s, Baumann TCS controlled E4OD.
Just getting broken in, 50,000 miles!
Briansshop is offline
post #9 of 13 (permalink) Old 07-10-2007, 10:06 PM Thread Starter
stang65fst's Avatar
Shakle Rev Kit? more info please!!! :-)
Todd
AKA Toad
post #10 of 13 (permalink) Old 07-10-2007, 10:14 PM
Go study brianshop's photos (link in his sig) and look at CaryT's photos, then search Cary's recent posts, then do a search on RSK, then come back and talk to us in a couple days.........
Don't mean to be an a$$ but all of this stuf has been talked about literally daily for the last couple of years.
Diesel Mechanic 34 yrs Maintenece Manager 23 yrs
Garbage_Mechanic is offline
post #11 of 13 (permalink) Old 07-11-2007, 09:18 AM Thread Starter
stang65fst's Avatar
Oh I know it has been covered and I have been searching it all down I just want to make sure I am understanding what I am reading.
You can read posts for hours but if you can't put it together in your head you will likely end up with waste time, money and a busted truck.
Not trying to bust your balls but that is why I started my thread the way I did so I could get some help.
I also search all the above as you said and didn't really find anything specific to conversion. Maybe I need spoon fed a little here but help a brother out.
Todd
AKA Toad
post #12 of 13 (permalink) Old 07-16-2007, 01:12 AM
UNLIMITED_DIESEL's Avatar
does anyone know what the gear ratio is for a 4407 t-case? I am trying to figure out our final drive ratio. thanks.
81/94 FORD F250 PULLING TRUCK 7.3 POWERSTROKE,
525cc HYBRIDS, TWIN S400's, FULL FUEL SYSTEM, GEN3 HPOP, ROLLER ROCKERS, SOLID LIFTERS, UDP CAMSHAFT, AND MORE........
1995 FORD F-250 REGULAR CAB/SHORT BED- FRESH ENGINE, 530 HYBRIDS/EH NOZZLES, GEN3 BIG OIL W/ SWAMPS 20* PUMP, "BIG" TURBO, COMETIC HEAD GASKETS, ARP HEAD AND MAIN STUDS, AEROMOTIVE FUEL SYSTEM, SOUTH BEND DUAL DISC, AFE STAGE 2 AIR FILTER, TANK, FS2500, AND LOTS MORE...........
UNLIMITED_DIESEL is offline
post #13 of 13 (permalink) Old 07-17-2007, 03:19 AM
Racer_X's Avatar
Re: Transfer Case
No, the transmission must be from a diesel. The older it is the weaker the design is. Exception is one that has been updated, but you will need the diesel case.
POWERFLOW BY RACER X - 1997 F-350 Twin Turbo charged 7.3 Power Stroke Diesel fueled with 473 cc's of diesel plus nitrous, equipped with a Custom
Racer X E4OD transmission making 800 r.w.h.p. on video! The first successfully Twin Turbo Charged 7.3 PSD!
Owned & sponsored by :
Racer_X is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
