97 F-250 H/D 4 door 4X4 6'bed.Broke block building new engine! Oh well it ran14.96 at 89mph at Baytown!
Kenworth T-600 aerodyne 3406c CAT, with 18* "B" modle injection pump(was a freakin peak yuk),10 over trans,4.10 rears,Dual 150 gal. fuel tanks,Budwieser inspired custom hot rod flames.Going to work real soon Leasing to Landstar yeah!
89 mustang coupe single turbo 302 ,built c-4,running little rubber.
I hate Dodges, straight piped common rail cummings sound like crap!
Transgo Tugger 2. A BTS valve body is OK but with out doing the pump mods it can only do so much.
1997 F250 HD started life with a 351 gas motor, now has a PSD from a 1996 Ambulance. 4'' Magnaflow SS exhaust, 3'' SS downpipe, TW chip, Stage 1 DIY injectors, IDM mod, BB mod, Tymar intake, Gutted ebpv. Soon to have dana 60 up front with 05 radius arms and air suspension.
I just did the TC lockup mod, and I really like it. Makes me feel a little better when I know the TC is lockedup manually instead of the computer doin it. Also it sure bangs the shifts in there now instead of being all fluffy. But I worry that the hard shifts is gonna break somthing one of these days.
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
I'm assuming a pump mod means pulling the tranny. If so, I will proabably wait. The valve body is a good suggestion as I can do it with the tranny in the truck at the next service interval. I thought about the TC lockup but thought it might be best to do the valve body first. What do you guys think? It would be nice to be able to change the timing of the lockup and shifts without having to manually switch it. Any product suggestions? Thanks a bunch!
Pump mod? What's this, what does it gain me/you & how to do it?
Firmer TCC lockup on E4OD. Pressure reg spring cal boosts line and bumps the amount of lube oil.
__________________ TheRacer XBuilt E4OD THAT CAN Video. 1997 F-350 7.3 Twin Turboed Power Stroke Diesel. Fueled with 473 + cc's of Dieseland nitrous!
Family owned & sponsored by : FloridaNorth
Yes the tranny and pump come out. A VB will direct atf but not change lockup or pressure. Shift points will change. The VB is half of a full shift kit. The VB changes shift feel as well. You could put the VB parts in from a shift kit and the rest later. Transgo is the full shift kit. If you want a single "power valve" There are a few and maybe Bully dog. Looks like BD is on clearance now, might be discontined so I'd avoid it for now.
the vb (accumulator)will shorten the duration and firm the shift. The transgo tugger or hd2 will contain the parts to do this, however i would also replace the other 2 accumulator valves as the kit only supplies one. There are other things I like to do with the accumulator you do not get with the kit. You can do this by only dropping the pan, the little springs can be fun to deal with. Honestly a pre modded vb is the way to roll and the install is much simpler and the little stuff is already done for you.
"Honestly a pre modded vb is the way to roll and the install is much simpler and the little stuff is already done for you."
Does an upgraded VB help the trans to last longer? I've owned
my truck for a few years and have no idea what the trans is. I tow
a 12.5K boat trailer and wonder if there's something not too expensive I can do to help it last longer besides a larger
trans cooler which I already have. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed.
Velvet rides installed. Joe Servo IDM mod installed. Rear air lift springs.
So where does one get the parts & directions to do this? I'm planning on the BTS VB, but not opposed to pulling the trans for extra perma-grin or reliability.
