Old 01-31-2007, 02:56 PM   #1 (permalink)
My Photos: (10)
Turbo ped mod
I know this has been asked alot before but i coulnd't get the search too work.
Ive got three trucks that are leaking from the pedistals, ones a 94, 96, and my 97. im gonna do the 94 first, the guy is not in a big hurry so it can be toar apart for a while.
what have you guys done with the ped just gutt the stuff inside and seal it up or grind the hump off and get it sealed?
TPhanks Ben
97 F-350, Red with white stripe, reg cab, xlt, 4x4, 5spd. 4:10s, Tymar intake, HPX, 3x4" downpipe, 5" exhaust, autometer gauges, 6.0 intercooler, beans stage 1s, Tony Wildman chip. 210k miles
341/785- 5/19/07
sold..97 F-350, red, reg cab, xlt, 4x4, 5spd, 3:55's, tymar intake, autometer gauges, south bend OFE, Tymar intake, 3x4" downpipe, 5" exhaust, HPX, gutted EPBV, Tony Wildman chip, 180cc injectors. 176k when sold
http://photos.thedieselstop.com/show...hp?photo=29440
sold..96 F-250, midnight blue, reg cab, xlt, 4x4, 5spd 4:10's. hypermax dp, gutted EPBV, 4" straight exhaust, tymar intake. 189k when sold
Copenhagen...S'nuff said
bigjohnson is offline
Old 01-31-2007, 03:04 PM   #2 (permalink)
tjbeggs's Avatar
Re: Turbo ped mod
cut the hump and weld up the holes. there are three of them I believe. just need to find someone to weld aluminum for you.
1997 F-350 CC LB 4x4 Auto, AD's, Chip, IC, 4Wh. Disk Brakes, and other stuff
Truck Pics
tjbeggs is offline
Old 01-31-2007, 03:40 PM   #3 (permalink)
Re: Turbo ped mod
Sawzall with a combination wood/metal blade will slice the old cyl off, 30 minutes at the welding shop and you are good to go.
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 01-31-2007, 05:18 PM   #4 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78
Re: Turbo ped mod
I just took the pushrod out cut off short enough, then used a 1/4" NPT tap on the hole and plugged it, put all the guts back in how they came out. No leaks here.
Just make sure you unplug or remove the solenoid so it doesn't try to actuate the EBPV
-Michael
Michael Paul
1995 F250: Regular cab, 7.3L PSD, 5-Speed, 4x4, 4.10 LSD, gauges, 2L chip, injectors, turbo, 4" downpipe - 6" tip, clutch, fuel system, Medium oil, Headstuds, Valvesprings, Cab lights, Dana 60 - New Look Soon!
1995 F250: Regular cab, 7.3L PSD, 5-speed, 4x2, 3.55 open, Intake, Downpipe, 4" exhaust, clutch, 2L chip, short throw shifter - To do list!
My Webshots
Dieselfever78 is offline
Old 01-31-2007, 09:45 PM   #5 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Re: Turbo ped mod
I think member Rick96F250 will send you one modified and you send your stock one back. You have no down time other than swapping it out.
Changed the name and added a link.
Soaggydogg is offline
Old 01-31-2007, 09:53 PM   #6 (permalink)
Re: Turbo ped mod
-Michael
[/ QUOTE ]x2
97 F-250 H/D 4 door 4X4 6'bed.Broke block building new engine! Oh well it ran14.96 at 89mph at Baytown!
Kenworth T-600 aerodyne 3406c CAT, with 18* "B" modle injection pump(was a freakin peak yuk),10 over trans,4.10 rears,Dual 150 gal. fuel tanks,Budwieser inspired custom hot rod flames.Going to work real soon Leasing to Landstar yeah!
89 mustang coupe single turbo 302 ,built c-4,running little rubber.
I hate Dodges, straight piped common rail cummings sound like crap!
Aljay is offline
Old 01-31-2007, 11:06 PM   #7 (permalink)
Re: Turbo ped mod
I gutted the piston assembly, disconnected the solenoid and used a 1/4"NPT pipe plug to seal the shaft hole. Ran it that way for 80K miles with no apparent oiling problems or leaks and the turbo was in great shape. After R&amp;Ring the turbo 4 times in four months, finally got tired of the turbo R&amp;R hassle and sawzalled and ground off the piston assembly, had the piston oil slots welded up and plugged the solenoid oil return passage with a locktited 1/8"NPT plug. Its now very easy to R&amp;R the turbo. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Dave Murakami 97 F-250 XLT Supercab PSD OffRoad, Bilsteins, Warn manuals, Rhinoliner, Bridgestone 285's, molded steps, smittybilt grille guard w/frame braces, Cibie driving lights, power rear window, Sony CD changer w/infinitys+basslink subwoofer, Tekonsha Prodigy, Snugtop, Reunel stainless steel rear bumper w/Warn HS9500 winch/PIAA backup lights, TFI, 7500lbs, 14.508 1/4, 408 rwhp/#2only, banks powerpack, gutted ebpv, 4" duals, map pressure regulator, JSidm, BTS, maddog stage II ABs, Bean's fuel system, Terminator, dieselpower tri-chip, tymared, black intake, non-fluttering Isspro EVs, almost stock!
masami is offline
Old 02-01-2007, 12:03 AM   #8 (permalink)
Re: Turbo ped mod
I think member ricksf250 will send you one modified and you send your stock one back. You have no down time other than swapping it out.
PM me or post if I have the wrong member.
Our pedistal mod man is rick96f250. Dangit Ben you should know that, he has a red number.
Old 02-01-2007, 01:07 PM   #9 (permalink)
My Photos: (10)
Re: Turbo ped mod
Thanks for all the input guys
so i can cut the hump off and have it welded up thats option one. or i could just take all the stuff out and put a plug in the hole where the rod would come out..
Ben
341/785- 5/19/07
Old 02-01-2007, 06:34 PM   #10 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
Re: Turbo ped mod
Either one. You'll need to leave the solenoid in (and electrically disconnected) on option 2. Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 02-01-2007, 07:17 PM   #11 (permalink)
Banned
Re: Turbo ped mod
Ben
on #2 you just pull the rod out tap the rod hole put in a plug then put the cap and clip back on un plug the plug and its done.i ran my truck like that for 3 years and the wifes for a year.then when i did the D66 on her truck i cut the barrel of and welded it up.works great.their is some pics of it in my webshot go to the wifes truck
tubzz is offline
Old 02-01-2007, 08:13 PM   #12 (permalink)
Jcart's Avatar
Re: Turbo ped mod
Another option,
Assuming they are leaking throught the EBPV rod hole, I did this as I wanted to continue to use the EBPV for an engine brake. Pulled the turbo and pedistal. Undid the snapring pulled out the cap, pulled out the plunger assembly. When looking at the piston end of the plunger you will see the sealing piston plunger has a grooved U-shaped (cross sectional view) sealing nylon type gasket with a Stainless accordian spring material inside the "U" of the gasket to keep it pressed against the cylinder. What I did was force a small O-ring inside the Stainless accordian spring material to put more pressure on the gasket and inturn move it out against the cylinder walls (use a small flat srew driver to press in the O-ring). Upon install of the plunger assembly is should still slide with reasonable hand pressure back and forth. On the rod end of the assembly I made a new small gasket (from thin gasket material) and placed it between the washer and stock gasket so as to limit leakage past the rod.
Didn't have a digital camera then (couple of years ago now) sorry no pix. I will say have been leak proof for (guessing) 100,000 plus Kms, and I use the EBPV "brake" everyday I drive....
One last thought as I recall if you intend on just gutting and sealing the rod hole with a Pipe plug you MUST LEAVE PISTON assembly (and cut rod short) inside for proper turbo lubricaton.
jrc
96 XLT F350 CC ZF-5 355's 16x8 aluminum rims 285/75R 16 Dick Cepek F-C IIs. T Wildman programs, Map regulator, DIY CCV & HX mod, TDS exhaust brake, BD gauges, downpipe 4" exhaust, custom SS resonator, LUK, SD I/C, Custom Shackle Reversal, Custom Moose Bar and Velvet rides, RS 9000x shocks, Custom Aluminum Drybox/fuel tank, Swamp's Baby Injectors, SD Hpop, DIY Oil by pass filtration, DIY electric fans, DIY E-Fuel system, Lighting by VisionX, LightForce and PIAA and other stuff.
http://community.webshots.com/user/jcart44
Jcart is offline
Old 02-02-2007, 08:55 AM   #13 (permalink)
johndeerebones's Avatar
Re: Turbo ped mod
jrc
As long as you disconnect the solenoid where the ebpv doesn't activate it doesn't hurt a thing to take it out, I did that about 50k ago, no if you let the solenoid activate the oil has an unrestricted path back to the pan, so obviously it'll go there instead of to the bearings.
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 02-02-2007, 01:20 PM   #14 (permalink)
Jcart's Avatar
Re: Turbo ped mod
johndeerebones,
I stand corrected, my oppologies for any mis-information to all [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img], Perhaps I was ill-advised (by a turbo rebuild shop) or more then likely I misunderstood..... [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img]. They had shown me there is a drain hole in the back of the EBP cast cylinder where any oil that leaks passed the piston, plunger assembly will drain back to the engine. I was lead to believe that if you removed the piston/plunger assembly, (as in totally remove and plug rod hole) oil pressure and volume is not be enough (as it would drain though formentioned drain hole) to lubricate the turbo. This shop had advised me NOT to remove the plunger assembly , just shorten rod and plug hole????
Mute point for me as I continue to use EBPV as Brake.....
Good point about unplugging the EBPV Solenoid, obviously missed that point and makes sense to me know......
Thanks for the clarification... [img]/ubbthreads/images/graemlins/smile.gif[/img]
jrc
Jcart is offline
Old 02-02-2007, 09:26 PM   #15 (permalink)
Re: Turbo ped mod
My turbo has lasted for 80K miles with the piston rod plugged, the guts removed and the solenoid leads cut off. It has almost zero endplay. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
masami is offline
