Old 09-09-2007, 11:44 AM   #1 (permalink)
turbo questions
sorry if i'm completely of base but bear w/me i'm just a newbie. i have a used switzer s3 64/14 from a cummins owner that sold his truck and swapped back his stock charger. wanted to know if i could adapt that to my 96. needed your guys opinion. this is after i get a sd hpop and some stageII injectors. but in the meantime i could be working on it.
isn't the oil feed and drain under/through the pedestal? couldn't you just tap them and use a.n. fittings/hoses? why do you need the pedestal wouldn't the piping support the turbo on it's own? how about having a support bracket for the weight, adapter for the flange, and oil feed and drain hoses?
96 obs c/c l/b suncoast billet auto DP chip afe stg 2 afe 4" stewart warner gauges sd hpop 6"lift 37" boggers clear head/tails/3rd brake/apc clear cab lights
01 s/c l/b 4x4 6spd. edge evo/ez afe stg.2 afe 4" centerforce dual friction
smokerstroker is offline
Old 09-09-2007, 04:21 PM   #2 (permalink)
STurbo90's Avatar
My Photos: (9)
Re: turbo questions
You could technically adapt any turbo to any engine but,
I don't know anything about that turbo, but since the cummins is a 5.9 vs the psds 7.3, the flow characteristics might not be what you want.
The oil feed and return does flow throught the pedastal, but you do not need to use it, you can adapt lines. I would not support the turbo off the pipes, the vibration will crack them, you need to at least support the flange as suggested.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is online now
Old 09-09-2007, 04:34 PM   #3 (permalink)
Re: turbo questions
whats the oil holes under the turbo that flow thru the pedestal?
so other than suporting the turbo what is the pedestal for? i got the s300 for next to nothing and they are very upgradable all kinds of intake wheels and housings and exhaust housing i hope there is a good combo for the stroke when i try this. i hope others will chime in with some good suggestions or point out any potential pitfalls.
Old 09-09-2007, 05:20 PM   #4 (permalink)
STurbo90's Avatar
My Photos: (9)
Re: turbo questions
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">whats the oil holes under the turbo that flow thru the pedestal?
so other than suporting the turbo what is the pedestal for? </div></div>
they are the oil feed and return passage ways for the turbo, and the epb solenoid??????
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">i got the s300 for next to nothing and they are very upgradable all kinds of intake wheels and housings and exhaust housing i hope there is a good combo for the stroke when i try this. i hope others will chime in with some good suggestions or point out any potential pitfalls. </div></div>
that makes no sense to me, every turbo can be built with different housings and wheels,
if you are going to change the compressor and turbine housings, the compressor wheel and turbine shaft, it doesn't matter if you got the turbo for free, if you have to buy all the other parts to make "a good combo",
unless you got all those other parts for free?
the only thing you will be using from the turbo is the chra, might as well just buy a turbo properly configured.
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
Old 09-10-2007, 11:37 AM   #5 (permalink)
Re: turbo questions
i think they call it the qssp or something turbo and it is just a modded s300 the thing is that the ones modded for a cummins have a rather small borg warner exhaust housing and the 7.3 needs a bigger housing other tnan that the s300 flows about the same as an h2e
1996 f-250:115000miles,h2e,6.0 ic,3" intakes,studs,beefed-up e4od,4.10ls,add-a-leaf,straight pipe to one 5" stack,guages,diy intake,ccv mod,17*hpop,315/75r16 buckshots,170cc stage 2 diy injectors,wildman 4 pos. chip,timbrens
1969 mach 1 mustang
1965 Ford 4000 tractor:cone filter, 3.5" stack, mack truck nozzles(220cc), pump turned up
Sophmore at Bridgewater College
CURSURI SUMMUS NUDI!! latin for we're going streakin!!
http://community.webshots.com/user/machdriver69
jasonlambert is offline
Old 09-10-2007, 05:53 PM   #6 (permalink)
Re: turbo questions
i'm sorry i was referencing to a QSSB that wop sells
1969 mach 1 mustang
