Turn up Fuel Pump/Injectors - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 10-07-2009, 01:30 AM   #1 (permalink)
Chafalls7.3Powerstroke's Avatar
My Photos: (6)
Does anyone know how to turn the fuel pumps and injectors up on a 1996 F350.
Thanks, Matt
Matt
1996 F-350 XLT. 7.3L Powerstroke. Regular Cab, Long Bed, TS Performance 6 Position Chip (Stock, Hi Idol, 50HP, 75HP, 100HP, and 140HP) 300,000 mile club. Currently 302,000. 4 Inch Lift, 37" Goodyear Wrangler MT. 4 inch strait pipe with down pipe off turbo.
1999.5 F-350. 7.3L. Automatic, Crew Cab, Long Bed, Dually, Lariat. 4" Turbo back MBRP exhaust. K&N Cold air intake. TS Performance 6 pos Chip(Stock, High Idol, 50HP,75HP,100HP,140HP)
Chafalls7.3Powerstroke is offline
Old 10-07-2009, 07:31 AM   #2 (permalink)
Pump is a 2 stage mechanical one it can't be turned up. You can shim the fuel pressure regulator to increase pressure. Just do a search on this forum Fuel Pressure Shim. Good luck.
97 F250 Ext Cab E4OD,224K Miles.Mods.10K,Shimmed Fuel Pressure,6637 Air Filter,140Volt IDM, 3" DownPipe.
Jeep1947 is offline
Old 10-07-2009, 11:10 AM   #3 (permalink)
blageurt's Avatar
You put a BB between the spring and the inside of the plunger and re-assemble the FPR, being careful not to kink the spring. As far as Injectors go you need Stage 1's since you already have a chip and a free flowing exhaust .Have you considered an Intercooler ?
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 10-07-2009, 12:11 PM   #4 (permalink)
My Photos: (6)
Yes i have. I'm kinda lookin for one. But i dont have too much money to spend. That $1800 for the transmission did a hit on my budget.
Matt
Old 10-07-2009, 02:24 PM   #5 (permalink)
My Photos: (60)
The Power Stroke is an electronically controlled engine so there is no injection pump to turn up. The 'Stroke equivalent to turning up the pump on the older diesels is a chip or programmer to change the engine control programming.
Do you have a budget in mind?
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 10-17-2009, 11:10 AM   #6 (permalink)
kaquinn's Avatar
My Photos: (15)
To shim your FPR i would order a cali kit from your local ford dealer! You can search that too. all new parts no BB's and piece of mind! cali kit should be less than $30 mine was $22!
OBSession
  • 03' F550 4x4 6.0 CC Lariat utility body:MBPR,BD EGR bye bye,afe stg2 dry, superchip cortex
  • 97' F-250HD 4x4 7.3 CC,SB: AFE stage II, MBRP-ss 4", BD-brake, DP-tunner chip,big oil, mostlysun coast trans, auto meter C2 gauges overhead, fuel?....!
  • 97' F-250HD 4x4 7.3 EC,SB 5 speed
  • 96' F-250 Centurion 4dr bronco 4x4 7.3
  • 96' F-350 4x4 7.3 SC, LB
  • 95' F-350 4x4 7.5 460 CC,LB
  • 94' F350 4x4 7.3 N/A under cont./ referb.
  • 94' F350 4x4 7.3 turbo, dually auto
  • 86' F350 4x4 6.9 4spd dually dump
  • 85' F350 4x4 6.9 w/banks sidewinder
  • 85' F350 2wd 6.9
  • 06' Mercury Mountineer
  • 05'Explorer XLT 4.6 V8
  • 94'Taurus SHO 3.0 5-speed
TRUCKS ARE BEAUTIFUL!
kaquinn is offline
Old 10-18-2009, 11:09 AM   #7 (permalink)
So what is the cali kit ?? Is it going to increase the fuel pressure like he was wanting it to do ? or is just a factory rebuild ?
97 F-250 HD 4x4, 4:10's, Crew Cab
Banks 3" down pipe, Magnaflow 4" exhaust, DIY Cold Air - open element, tripod Banks gauges, B&M trany cooler. DP Tuner-F5 4 position Chip, Turbo Blanket +2lbs more boost, BB Mod and CLEANED the fuel regulator screen ! IDM Mod - yes it works
87 Mustang Drag Radial Car - F1R - 1200HP !
302man is offline
Old 10-18-2009, 11:23 AM   #8 (permalink)
Excavator's Avatar
My Photos: (11)
In your sig you show a TS 6 pos chip.
With STOCK injectors you are not getting much over 60 horse over stock.
If you go with performance injectors with the chip it will wake up that engine but you have to have a strong tranny to hold up.
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Excavator is offline
Old 11-11-2009, 01:48 AM   #9 (permalink)
hey sorry to threadjack, but my setup is similar:
97 f350
stock 97 injectors
17degree HPOP
6.0L FMIC w/ 2.5" charge pipes
wicked wheel turbo w/ 1.00 a/r
no ebpv, 3" exh
DP tuner
my question is if i only want 60hp over stock, is there any downside to the stock injectors?
Full-Race Geoff is offline
Old 11-13-2009, 07:38 AM   #10 (permalink)
DZLJIM's Avatar
We proved on a dyno, the MOST you will see is about 40 hp on stock injectors, stock turbo, and a chip. You won't see more without going to larger injectors, regardless of what the chip settings say.
No downside to staying with stock injectors, other than you're limiting the power you make. That's it.
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-350, 4x4, CC Short Bed.
DzlJim.com for some redneck engineered projects.
DZLJIM is offline
Old 11-15-2009, 03:11 PM   #11 (permalink)
My Photos: (6)
im lookin for injectors now. i thought that was probally the case. i got a much stronger than stock trans the guy that built it for me gave me a good deal because i happened to know some people and him. so now its just the injectors im lookin for.
Matt
Old 01-17-2010, 02:04 PM   #12 (permalink)
kaquinn's Avatar
My Photos: (15)
The cali kit will increase fuel pressure! Im told it will put the presure right where you want it with out the trial and error and exspense of a gauge as with making your own shim with a screw. Also some say id you use a BB the fuel will eat it up!? Cali kit comes with a new spring, o-ring and plug.
OBSession
  • 85' F350 2wd 6.9
kaquinn is offline
Old 01-17-2010, 02:14 PM   #13 (permalink)
edieedie's Avatar
stage 2 injectors are a hell of a power increase by their self
1997 F 350 4X4, idm mod, wide open performance GQSSB turbo, stage 2` s by bean` s, intercooler, 4" no muffler, stack, trans from brians truck shop rear, disk brakes, and a stecher stage 1 hpop 6 position chip with bean` s programs crane valae springs, air dog lift pump and electric fuel pump and regulatorand water methonal injection
edieedie is offline
Old 01-17-2010, 03:16 PM   #14 (permalink)
W/T/F? Would you please tell me where the 2 stage injection pump is on 7.3L Powerstroke? And no the HPOP is not an injection pump. It is used to actuate the injector which acts as the injection pump by pushing the fuel in the cyl under high pressure.
equipmentguy is offline
Old 01-17-2010, 04:27 PM   #15 (permalink)
There is a fuel transfer pump, right underneath the intake pipe down in the valley. It provides fuel pressure to the fuel rails/injectors. It is referred to as a '2 stage' pump because it first provides only a couple of psi to the fuel filter and then the fuel goes back to the pump and which increases the pressure from between 50-70 psi for the fuel rails. You can also upgrade to an adrenaline high pressure oil pump too and get some better performance.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline
