TYMAR - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 01-11-2006, 06:30 PM Thread Starter
welder79's Avatar
My Photos: (13)
TYMAR
How much for the TYMAR setup?
1989 F250 single cab 2WD
7.3 IDI with 200,000 miles
Single Straight Exhaust with 4" Chrome Tip
No Soupbowl
E40D
LT 265/75/16 Hankook ATM's on 16x7 Eagle Wheels
Gooseneck hitch
Homade rear pipe bumper with built in utility-lights and D-rings
Diamond Plate Aluminum Toolbox
Tinted Windows
Roof Markers
1997 F250 Extended cab 4x4 112,000
PowerStroke Diesel, E40D, Manual Hubs
Tymar Intake - No Cat, 18" Glasspack
2000 Excursion
200K
Removed
welder79 is offline
post #2 of 16 (permalink) Old 01-11-2006, 06:47 PM
Re: TYMAR
$42.99 at NAPA, part #6637, that's for the HUGE conical filter. I cut the tube out of the stock air box lid for an adapter. I could tell right away my engine was breathing better.
Randy
2005 F-250 King Ranch * 4X4 * 4" exhaust / 5" tip * Let the mods begin......
1994 F-250 Super Cab * 4x4 * ZF-5 * 3:55 * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
post #3 of 16 (permalink) Old 01-11-2006, 06:48 PM
Re: TYMAR
Call Dale @ Tymarperformance dot com and ask.......It was aroundd 120 bucks a couple years ago.
1994 F-250 PSD ext cab 5spd 4x4 Gutted ebpv ,Valeo smf and clutch,3 pos Tony Wildman chip!, 3-4" Dp, 4" exhaust,Tymar intake, shimmed fpr, HPX crossover, 1.0 A/R exhaust housing, vdo gauges, 279,000k
1996 F-250 PSD CC SB 4x4, 5spd, 4:10's SMF clutch, 3" dp, gauges, 6oh intercooler(GTS Kit), Tymar intake, HPX, .84a/r housing, 203* stat, 4pos Wildman chip!
ltfox is offline
post #4 of 16 (permalink) Old 01-11-2006, 09:01 PM
Re: TYMAR
I paid $126.10 with shipping in September 2005. Sounds like a lot of guys build their own but it was worth the money for me.
Brandon [img]/ubbthreads/images/graemlins/smile.gif[/img]
1996 F-250 Supercab long box, auto, mostly stock except the Tymar intake, 133,000 miles.
Bentz is offline
post #5 of 16 (permalink) Old 01-13-2006, 12:27 PM
Re: TYMAR
Get the TYMAR setup. Just give Dale a call....He'll fix you up in a heart beat.
97 F-250ext/LB 4x4, E40D, Catless/stock muffler, Tuff Country 3" Lift, Tymar Air, 285/75R16, Custom 5ver gate, Warn Hubs,Lined Bed, Sylvana Superstar Bulbs, Stainless Bed Caps, Super Chips Tuner, 4.10LS, Kenwood Dual Band, Fumoto valve, shimmed,Tru Cool 4590,Tymar HPX mod, coolant filter & coolant eye,4R100 pan, AC Mod,XM Radio,Door Chime & keyless entry bypass mod, GlowPlug bypass,FORD AIC,Sonnax valve&Tricumulator springs,Commando EZ-2500 Remote Starter & Keyless entry,157K Miles. Ranch Hand Type Bumper. Trying to sell first born to raise money for more Mods.
W7BYU is offline
post #6 of 16 (permalink) Old 01-15-2006, 09:34 AM
Quadzilla's Avatar
Re: TYMAR
To get the real TYMAR, you need to contact Dale Isley. NAPA sells air filters and you can fabricate something yourself that works better than the stock airbox, but it ain't a TYMAR. To get the real TYMAR, you need to contact Dale Isley.
"Life is too short to drive an ugly truck."
Steve Baslow
2013 F250 Platinum 6.7 CC SB 4X4
I'm not affilitated with the vendor "Quadzilla" in any way.
Quadzilla is offline
post #7 of 16 (permalink) Old 01-15-2006, 12:36 PM
Re: TYMAR
Dales filter is much cheaper than the auto parts stores filter. Even though its the same filter.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by
, Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
TimMiller is offline
post #8 of 16 (permalink) Old 01-18-2006, 11:11 PM
Re: TYMAR
I just ordered mine this week and it came to $127 and some change. It is a little cheaper than that if you don't get the powder coated tube. I can't wait to get it and install. I have heard nothing but rave reviews about the TYMAR since I have been reading and posting here.
96 PSD, Crew Cab, 146K miles, 4x4, 3" Downpipe, Pillar guages (Boost, Pyro, Tranny temp), Superchips Microtuner, Tymar Intake
jmpinega is offline
post #9 of 16 (permalink) Old 01-19-2006, 02:31 AM
Powerstroke2000's Avatar
My Photos: (17)
Re: TYMAR
You won't be sorry....all quality parts! I've had mine on since their inception, and it works as good today as it did the first day I installed it! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Be ready to hear your turbo!
Dale
2009 F450 4X4 Superduty King Ranch
6.4 Diesel, 4.30's.
Powerstroke2000 is offline
post #10 of 16 (permalink) Old 01-19-2006, 08:11 AM
My Photos: (21)
Re: TYMAR
I gotta fever, and the only prescription is more turbo!!!
I love my Tymar, got mine Black powder coated... worth the extra few dollars.
-1997 F350 XLT crew cab 4x4 with big steel Gage RanchHand bumpers, Tymar intake ( 1-2 mpg improvement ) , 3" to 4" DP 4" exhaust exiting in front of rear wheel w/5" SS downtip. DIY AIC control ( AIC on Ebay now ), Premium Warn Manual hubs just installed, and Alpine 6 1/2 - 6x8 component speaker system. TW 6 pos chipset.
-1979 F250 4x4 with 33", gas 302. All farm truck, more rust than truck, more spunk than Chevy.
-1970 Ford 3400 tractor, 3cyl diesel with a cracked loader ( no longer cracked, I learned how to weld, yeeeaahhh! )
-1983 White/Herc 6cyl deisel 65kw genset that provides 180A to the house PRN.
Equineguy is offline
post #11 of 16 (permalink) Old 01-19-2006, 02:14 PM
Re: TYMAR
send a pm to brad52 he's got one of those tractor cleaners [img]/ubbthreads/images/graemlins/warmsmile.gif[/img] in his garage [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2006 GMC DURAMAX/6 SPEED ALLISION/CREW CAB
4" TUFF COUNTRY KIT,12.50-33-18 TOYO OPEN COUNTRY ON POLISHED MHT WHEELS,MBRP DUALS,COBALT GAUGES,EDGE EVO.TUNER,AFE INTAKE & MORE.
OTHER RIG 97 F350 Literally "SMOKED" by swamps
warrenrh is offline
post #12 of 16 (permalink) Old 01-19-2006, 04:11 PM
Re: TYMAR
Dale
How much louder is it then the K/N filter? I got a nice high pitch just putting the K/N and down pipe on.
1997 F-350 XLT PSD 4-WD WHITE
__________________________________________________
1969 MACH1 Blown-468
blown428 is offline
post #13 of 16 (permalink) Old 01-20-2006, 06:47 PM Thread Starter
welder79's Avatar
My Photos: (13)
Re: TYMAR
I have always been told that using hot air under the hood was bad for an engine. However I have also been told good things about a tymar intake. Could someone tell me why the tymar is good if it is using hot air as the intake source?
No Soupbowl
E40D
Gooseneck hitch
Tinted Windows
Roof Markers
2000 Excursion
200K
Removed
welder79 is offline
post #14 of 16 (permalink) Old 01-20-2006, 07:13 PM
Re: TYMAR
This info is directly from Tymar:
"Ingesting warm “under hood” air: Concerns with ingesting warm "under hood" air are unfounded. Intake air temp rise over outside ambient temperature is only 10°F to 20°F higher when moving faster than 25 mph. The largest temperature difference occurred while pulling the gross vehicle weight rate up a steep incline and was only 45°F over outside ambient.
Air density: Although it is true that warm air is less dense, thermodynamic calculations show that the drop in restriction that leads to a gain in overall boost more than makes up for any loss in air density. In fact, you would need to ingest air heated well above 100°F over the ambient temperature to lose power due to the loss of air density."
Hope this helps.
Later,
Darrell
1999 F250 4X4 with Tony Wildman Chip, Intake and 7" Aussie Stacks
1997 F350 2wd with DPP/PHP Chip, Intake, Ehaust and 8" Tip
95psdF250 is offline
post #15 of 16 (permalink) Old 01-20-2006, 10:42 PM
Re: TYMAR
Anyboby?
blown428 is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
