tymar intake question - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 02-12-2010, 09:54 AM   #1 (permalink)
rc-junky007's Avatar
ok so i have a 1997 f350 and wanted to do the diy intake mod but i have a question. what do you do with the sensor that plugs into the side of the stock airbox?
rc-junky007 is offline
Old 02-12-2010, 10:02 AM   #2 (permalink)
Just lay it between the filter and the battery. Also, after running around and trying to find all the right parts, you will find it easier to just call Dale and get all the right stuff first shot. He can also sell you replacement filters pretty cheap.
Dave
1997 F-250HD XL 4x4 regular cab, toreador red with matching cap. Tymar intake ,HPX and coolant filter, B+M trans pan and a lost kitty. 3" ss downpipe. Stancor, 4:10 gears Amsoil in engine. 182K, E40D auto. Cruise control mod. DB starter. AIC.
2011 F350 CrewCab, Black, 6.7, Rhino Lined, Delta Pro Crossbed toolbox and a whole bunch of other crap.
bluefin is offline
Old 02-12-2010, 10:43 AM   #3 (permalink)
edieedie's Avatar
try Powerstroke Intake System Option #3
1997 F 350 4X4, idm mod, wide open performance GQSSB turbo, stage 2` s by bean` s, intercooler, 4" no muffler, stack, trans from brians truck shop rear, disk brakes, and a stecher stage 1 hpop 6 position chip with bean` s programs crane valae springs, air dog lift pump and electric fuel pump and regulatorand water methonal injection
edieedie is offline
Old 02-12-2010, 11:16 AM   #4 (permalink)
jacksonbend's Avatar
I just tied mine off under the filter. Got the 5" heavy duty clamp at Napa w/my filter and picked up a 3" chunk of 4" exhaust pipe at a shop for free. Done and works great.
'03 F350 CCSB 27k
6spd,4x4floor
285/75/16 +2"front
RCD EGR Delete,AEM Intake
Sold:
'06 F350 CCSB 87K
6spd 4x4manual hubs
6"Fabtech w/35"s
'01 Stroke CCSB 112k 6spd
5" lift, 35" tires 4" straight
NAPA 6637 Intake, Wicked Wheel
TS T6 Pyro/Boost Gauges
AIH/EBPV Delete
2005 6.0, 2001 7.3, 2-'99 7.3, '97,'95,'92IDI, 3-Cummins
jacksonbend is offline
Old 02-12-2010, 12:45 PM   #5 (permalink)
Feedback Score: 3 reviews
That link to to a outfit that uses the Tymar name to sell it without any agrement with Dale...their is a name for that. Also over priced.
cary
Cary
caryt is offline
Old 02-12-2010, 02:19 PM   #6 (permalink)
thankyou for your help guys
Old 03-17-2010, 05:57 AM   #7 (permalink)
How does the Tymar compare to aFe? Besides price.
97 F250 PSD 5sp 4x4 Crew, Stock so far.
Best rig I've ever owned.
ak.frank is offline
Old 03-17-2010, 02:14 PM   #8 (permalink)
Nothing will out flow and out clean a Tymar-Donaldson kit.
Cary
caryt is offline
Old 03-17-2010, 02:30 PM   #9 (permalink)
I installed DIY tymar on 02 and now when I tow around 45 mph it has a whooshing noise is this normal. It also will do it but not as loud when not towing until in OD and road speed. Thanks for any input.
slatjoe69 is offline
Old 03-18-2010, 12:57 AM   #10 (permalink)
normal noise, wastegate. you just can here it now with the open air intake setup. It is the sound of Free flowing air! you have done an excellent upgrade. you may also notice "turbo surge" now if you're chipped, as I did. I did the "wicked wheel" conversion to fix that.
'03 F350 CCSB 27k
6spd,4x4floor
285/75/16 +2"front
Sold:
'06 F350 CCSB 87K
6spd 4x4manual hubs
6"Fabtech w/35"s
AIH/EBPV Delete
Old 03-19-2010, 04:42 PM   #11 (permalink)
'97 and older PSD's don't have a wastegate.
The "wicked wheel" is the impeller that the 94-97's already have, stock.
Snowtow is offline
Old 04-03-2010, 06:27 PM   #12 (permalink)
MAILMANWV's Avatar
tymar intake question-chuck-norris-medium-.jpgTHATS RIGHT....
1997 F250 PSD
GOLDENFUEL SYSTEMS WVO CONVERSION
ATS 5 STAR TORQUE CONV
TONY WILDMAN
BOOST, PYRO, TRANS GUAGES
FPR SHIM
TYMAR INTAKE
CURTIS 7.5 FT SNOW PLOW
PUSH'S SUUT, ROALIN COAL!!
137,XXX MILES
MAILMANWV is offline
Old 04-04-2010, 10:47 AM   #13 (permalink)
Feedback Score: 2 reviews
Dave
Everyone swears its cheaper to get the intake from the dale guy but if you have a napa or big truck shop its a pretty simple job to do......literally took about 10 min and under half the cost of one from tymar
woot woot
brencoracing09 is offline
Old 04-04-2010, 12:01 PM   #14 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
Nobody is saying you can't do it cheaper than the TYMAR (chunk of exhaust pipe and filter), but if you go out and purchase the same parts (including clamps, filter, elbow, hose, standoff clamp, etc.) that make up the TYMAR, it's easier to just get it all from Dale. That's what I'll be doing when I finally get one for the 97 (been there done that on 94). Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 04-05-2010, 03:57 PM   #15 (permalink)
Plus a Napa isn't the correct filter and costs more than the Donaldson!
Cary
caryt is offline
