I want to get all the parts together before I tear the truck apart.
Does anyone have the specs for the 4 Front axle U-bolts?
And I'll need specs for the 4 rears with F-350 3" blocks.
Otherwise, I'll need to take mine off and run out to get them made.
Thanks.
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-250, 4x4, CC SB DzlJim.com for some redneck engineered projects.
www.racerxautomotive.com for your upgraded E4OD/4R100 needs.
You can't measure the existing rear ubolts and add 3" without taking them off?
All you need to know is the axletube diameter, length of the legs of the existing ubolts, and the diamter of the bolt itself. There's no need to remove them for those three specs.
Jim ,the front ones are the same as the D50 ones, I have some extras I think.....
Diesel Mechanic 28 yrs
My rear u bolts are 13 1/2 and that is with 4" 350 blocks and they have plenty of threads left below to use 3" blocks and I reused my D-50 front u bolts. Good Luck
Frank
__________________ http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: caryt</div><div class="ubbcode-body"> You should be able to reuse your stockers...I know not what your supposed to do ..but I have done this many times to no ill effect.</div></div>
Me too! [img]/forums/images/%%GRAEMLIN_URL%%/blush.gif[/img]
Me too!, but if you want them made you need 3" square bolts with whichevr leg length you wanted then jsut cut them down.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
Maybe I'll just re-use the front bolts, then.
Thanks for all the info!
