Old 10-18-2006, 11:56 PM   #1 (permalink)
ThreeStarJR's Avatar
update on Bean's turbo..........
looking good to having one installed for testing on the 27th, can't wait! [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]...stay tuned tomorrow for an announcement about some fun stuff pertaining to this new turbo...........
Jim
529/1220
10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Hypermax rods
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
#3
ThreeStarJR is offline
Old 10-18-2006, 11:57 PM   #2 (permalink)
kfjensen's Avatar
Re: update on Bean's turbo..........
You are teasing us... [img]/ubbthreads/images/graemlins/mad.gif[/img] [img]/ubbthreads/images/graemlins/mad.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 10-19-2006, 12:15 AM   #3 (permalink)
No way! Awesome!! Keep us posted. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
ryanPSD is offline
Old 10-19-2006, 12:25 AM   #4 (permalink)
bigrpowr's Avatar
this should be good!
2000 F350 4x4 almost fast
12.27 @112.89
12.80 @ 114.48
727.7 hp (NOS)
bigrpowr is offline
Old 10-19-2006, 12:58 AM   #5 (permalink)
Fordpowrstroke73's Avatar
My Photos: (6)
Send a message via AIM to Fordpowrstroke73
Ya, i saw somthing on beans turbo on this website. This is what it said.
BDP High Performance direct replacement turbo
Stock turbo flow is around 750 CFM. The high performance turbo upgrade will flow 1050 CFM. That is a 30% air flow increase of stock. This turbo has a 1 Year replacement warranty. That is almost 100CFM more than the Hypermax H2E turbo at less than half the price and installation time. Maximum recommended pressure is 40PSI. Expected release date is 11-15-06.
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
Fordpowrstroke73 is offline
Old 10-19-2006, 02:32 AM   #6 (permalink)
AlaskaRedneK's Avatar
So Im guessing that this is gunna run about a grand?
-Stouff
'97 F-350 CC/LB 7.3L PSD 4x4 4.10's, ~111K miles/ 5" Turnout Stacks, Isspro EV Guages, 7.3 IC, gutted stock fan- w/ single electric fan, Stage 3 DIY Hybrids, Bad Boy RacerX Tranny built by me, headstuds, 910s, pushrods, 17* pump, 3" intakes, H2E, Tunes from Tony
AlaskaRedneK is offline
Old 10-19-2006, 02:34 AM   #7 (permalink)
My Photos: (38)
Since when do you have an OBS or care about an OBS turbo Bigr.
...and no reply about me being down here needed, I work on them all the time [img]/ubbthreads/images/graemlins/smokin.gif[/img]
some stuff
14.8 @ 90
gregrob is offline
Old 10-19-2006, 02:37 AM   #8 (permalink)
1050 CFM at less than half the price and direct bolt on... sounds like a deal to me. Looks like I'll be sending mine in about Jan. or Feb. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
97' F250 CC 4x4 SB PSD 5spd 188,000 4:10's
LT265/75R16 Cooper Discoverer ATR's
Tymar Intake, HPX, 3X4 DP, 4" Street Exhaust
Custom Injectors
17deg HPOP
SD HT Starter
Shimmed FPR
Uniden Pro520XL
MaxRad Antenna
1000cca Everstarts
AIC
Autometer Gauges
Disconnected EBPV
ES bushings
Warn Premium Hubs
Rhino Liner
Custom goose neck
Chrome bed rails & body skirts
Custom wife dents
Stickers that make it faster (no really)
North West Ford Diesels Truck Club
Truck Pics
Pat_T is offline
Old 10-19-2006, 04:48 AM   #9 (permalink)
PSDfreak's Avatar
1 question...The internals may be able to "spin faster" but will the the rest of it be able to put up with the 30-40 lbs of boost (ex: the housing?)
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is online now
Old 10-19-2006, 07:44 AM   #10 (permalink)
sea97stroker's Avatar
That was kinda a cheap shot!!!
Steve
1997 F350 CC 5 Speed 4x4 , BDP Stage 2's, Wildman Chip, Isspro Gauges, 5 inch stacks, SD Turbo Setup,Banks Intercooler,Tymar Intake, SD Leather Seats. Dyno 427hp/813tq
www.BeansDieselPerformance.com
sea97stroker is offline
Old 10-19-2006, 09:50 AM   #11 (permalink)
The housing... I would think so. Being a (modified) stock turbo personally at 35-40psi I'd be worried about the original problems of the stocker, primarily wear on the thrust bearing. I wonder what is different internally to allow it to support this. I wonder if that is the "safe" limit, like the stock turbo's 23 or so psi I have read seems to be the max you could run all day long before it will cause any wear on the bearing...
- Ryan
285HP
ryanPSD is offline
Old 10-19-2006, 09:56 AM   #12 (permalink)
My Photos: (6)
At what point would you need (PSI) would you need head studs ? I would love one of these but will a 200,000 mile motor take it ?
97 F-250HD Super Cab 4X4
Jasper E4OD, 3.55 gears
Auto Meter Dash Mounted: Trans temp, Boost, EGT, Oil Temp, Oil Pressure.Water temp. Gauges. http://photos.thedieselstop.com/show...t=1&thecat=500
Homemade Open Air Filter, 3 in SS DP, SD, 03 Intercooler. GTS kit. Modified Pedestal, ITP SS HX, CCV Mod, BABY SWAMPS & SWAMPS 6 POS Chip, 17 Deg HPOP, Gutted EPBV, Jasper Stage 1
250,000 Miles, and still going Strong.
TSM Disk Rear Brakes
Cratos is offline
Old 10-19-2006, 03:03 PM   #13 (permalink)
bigrpowr's Avatar
are you a diesel mechanic now. congrats on the 6100+ posts! your getting smarter everyday. lol
do you work on every single ford diesel ever made, cuz your in every single forum on this site.
p.s. why are you going on comp diesel calling tds people jerks? oohhhh.... your awesome.
12.27 @112.89
12.80 @ 114.48
727.7 hp (NOS)
bigrpowr is offline
Old 10-19-2006, 03:04 PM   #14 (permalink)
Big K's Avatar
Send a message via ICQ to Big K
That ain't nice Greg! [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img]
Big K is offline
Old 10-19-2006, 03:10 PM   #15 (permalink)
My Photos: (38)
I thought BigR may have and OBS project or something.
Sorry, don't wanna get the thread off track.
some stuff
14.8 @ 90
gregrob is offline
