Would like opinions good and bad on intake systems. I have heard Tymar, but like the idea of a heat shield like AFE. My kick against AFE, is it is made of steel instead of alum or stainless. Being next to the battery and acid, it's a rust prone area. Thanks for input.
The AFEs are nice intakes. They are all powdercoated for a durable finish. If you have a leaking battery you should probably replace it anyway. The shield is near the battery but doesn't go up against it at all anywhere sothought it is possible it's highly unlikely that the acid will be an issue.
I love my Tymar intake also. Oil analysis has shown very clean for me also.
97 F-350 cc srw 4x4,White,cab hi Leer,E4OD,4.10's,Hypermax H2E,Banks intercooler,BDP stage 1 injectors and fuel system,BTS tranny,BTS twin hpop,4 postion chip programmed by Cale,Skyjacker 4" system,35" BFG's W/Welds,Rear air bags,Hayden 26,000 trans cooler,4" exhaust,Tymar intake&hx mod,Amsoil dual bypass filter w/Amsoil syn. oil, and diff. lube, Ford aic, Joe Servo idm.
353 HP 677 TQ on BTS's dyno at 0 correction
