That is what I did. I used a overhead console out of an explorer, cut the head liner, trimmed the console to fit, hooked up the wires and installed the unit. There are a ton of them For Sale on eBay.
Griz
95 F250, 4X4, E4OD, 4.10, Hypermax DP and Tymar 4" Exhaust System, Tymar Air & Coolant Filters and HPX Kit, Tymar fuel fill mod, External Transmission Filter, Schaeffer's ATF. Add-a-leaf, Redline Differential gear oil and Redline ATF in Transfer Case. OilGuard By-pass oil filter. Schaeffer's 5W-40 in the engine. A-Pillar...Autometer Boost, Pyrometer and Trans. Temp. Gages, Under dash...Oil Pressure and Water Temperature gages, 1705 Superchip Tuner, Stancor GPR, Factory Tech Valve Body, Evans Waterless Coolant, Two 4590 Tru-Cool Transmission Cooler in series, Explorer Overhead Console, Diesel Turbo Lifesaver, Tymar Fuel Filler Mod.
