ive seen the kit on bd to use it as a exhaust brake but tony was telling me that its really easy just to wire a hot wire into it and thats all you need??? any input on how to do this?
NEW BABY- 2005 Chevy Duramax Diesel CCSB.... 8 inch fabtech lift 37 inch mickey Ts on 18inch flat black pro comp Rims. Edge Insight EFI!, straight exhaust. AFE intake and turbo inlet. EGR blocker plate Fully loaded Pioneer DVD double in deck. 2 12 inch shallow fosgates... sorry i switches guys but this thing is Bad To The Bone.
f-350 4 door long bed. 6 speed. 5 inch stacks. 9 inch lift. 40 inch Ground Hogs. custom Front and rear bumpers with 10,000 Warn WincheSSSSSS.K&N TW chip, stage 1s, IDM mod, exhaust brake. limo tint. peterbilt cab lights. dvd screen 2 shallow fosgate 12s (sick!!) and everything else you can think of. damn ive spent way to much money on this truck.- newest smartest and awesome edition is a set of custom built track bars. should have gotten these from the get go
it is possible, how to do it i dont know, i know it was easy, atleast thats what a buddy told me. i never did one myself though.
EARLY 99 F350, CREW CAB, LONG BED. 4X4 7.3L AUTOMATIC. EDGE JUICE W/ ATTITUDE. 4" EXHAUST, NO MUFFLER, 6" TIP, COLD AIR INTAKE, BD: CCV KIT (WON ONLINE, THANK YOU BD). DVD PLAYER, PS2, IN DASH TV, POWER INVERTER, 2-10" INFINITY SUBS IN PORTED BOX. CLASS 5 REESE TOW PACKAGE, FLIP UP GOSENECK HITCH. CB/PA, WITH DUAL TRUCKER WHIPS. TOW MIRRORS, AND CAB LIGHTS, RECON LED TAILGATEBAR W/ REVERSE LIGHT, BUG GUARD AND WINDOW VISORS. 05 GRILL AND HEADLIGHT SWAP, 08 TAILGATE, 285/75 BFG ALL-TERRAINS, SHACKLE LEVELING KIT, AND BILSTIEN SHOCKS. 5% TINT ALL THE WAY AROUND, AND 50% ON THE WINDSHEILD.
SOON TO COME: 08 TAIL LIGHTS, CLEAR CABLIGHTS, RECON ESCALADE STYLE 3RD BRAKE LIGHT, STROBE LIGHTS, PROJECTOR BACKUP LIGHTS, 33X12.50 BFG ALL TERRAINS ON BLACK DICK CEPEK 17" RIMS, EDGE EVOLUTION PROGRAMMER (STACKED), RAPTOR HIGH PERFORMANCE FUEL PUMP, HIGH PERFORMANCE HPOP, POSSIBLY 10" STACKS!
It is easy to do. Just unplug the valve. the plug is sorta under the cold side of the turbo drivers side. Run 12v to the plug from a switch and turn the valve off and on as you please. There are other ways to do but this is the easiest and you are in total control.
2000 F-450 auto, cc ,4x4 , auto meter guages, Tymar intake, bellowed up pipes, Riffraff ic boots & plenum boots with inserts
whmoto, can that work on the early 99 7.3? just wondering...
You're saying just unplug the valve, run a new plug up to the valve that has 12V to it hooked to a switch in the cab and that will give you control? That's simple enough...I need to do that. Mine is prone to turning on and off regardless of my trucks temp if it's cold out. But I like it for warm up and braking.
Justin
__________________ Justin
1997 F-250 Power Stroke - 230k 463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, BDP live tuned
2005 F-350 Power Stroke (work truck) - 220k
ARP Studs, PHP 40 hp flash
i just did it.. it was way to easy and it works great
I can't believe I never thought of that. All I ever saw was the write up where you can wire it into your brake and torque converter and all that other stuff I don't care about. As soon as I shake this cold I've got I'll be all over that.
Justin
Glad ya'll like the easy way. You can do a simple tc lock up switch to if you have an auto. There is nothing wrong with the other ways of doing the exhaust brake and tc lock up I just wanted a simple way. It is not that big a deal to cut a switch off and on manualy and there is less to go wrong.
I know that the other popular way to do it involved running a line to the brakes, a switch and the valve. Does anyone have the part number for a new plug if I was to just go ahead and do the straight wire to switch and over to 12v? Thanks ahead of time.
-Brendan
1997 F350 7.3l PSD 5 speed Zrf tranny with 4 inch turbo-back exhaust, tymar intake, garrett turbo and turbo thruster, 6 inch suspension lift, bf goodrich mud terrains, reese hide-a-ball gooseneck, custom steel front bumper.
just use the factory plug and cut it off, crimp on butt ends so you wont have bare wires hangin around, odds are you wont ever want to put it back to stock
1996 f-250 PSD xlt single cab longbed
Tymar intake/Tymar Hpx line
custom 4 inch turbo back side pipe
swamps injectors
wildman 6 pos. chip
87' king pin d60
35" bfg mtr km2 on american racing rims
-Bio-diesel ready-
