Item must be returned in good working condition, installation of the module is fine as long as no physical damage is done, so that unit can be refurbished for resale. Please contact me prior to returning for an RMA #. Your satisfaction is very important with me and I will work with anyone who has any questions during or after the install.
he does not return emails and he does not cair about "satisfaction". he is satified with the money not with you.... jsut a warning
1997 Ford F350 2WD SRW White Crew cab 260,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, diesel site 6 pos chip. B & W turn over, coolant bypass filter.
1997 F-250 Supercab shorty 4x4 with 1996 Cummins 5.9 12V,3GSK,#10 plate,5600 sixer with short shift kit,Dana 60 and 80,205 TC,and a few goodies under the hood,lifted/tires etc,etc.2002 Mustang G.T.Mineral gray.
I think that everybody on this site has been laughing at that item ever since he first started placing them on Ebay. Too bad it sounds like you got burned on it.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
don't feel bad, I bought one about three years ago. It worked well except i would throw a CEL in the two highest settings. i no longer need it. Thanks Tony, you are the man
'97 red PSD short box ext cab, 5 spd, 330,000 km, Wildman 4-position chip,DIY stage 1's, EBV brake, 4" lift, timbrens, DIY open air filter, Gooseneck in box, 3" DP, 5" turn-out stack
Volunteer FireFighter for 7 years
Farmer my whole life
Hers: 01 F-350 PSD, Reg cab, dark green, 2" front leveling kit, Wildman chip, Open intake, pyro and boost gauge, rolling on 315/75-16 BFG All Terrains
Fisher MM2 8'
FIL: 03 Excursion Limited, 6.0, 260 000kms, Banks monster exhaust, pyro and boost gauges. New head gaskets at 200,000kms, Arnott Air Bags
Other Toys: 2001 Mustang Bullitt Highland Green
2007 Mustang Cobra GT500 Red w/ white stripes
So are you saying we shouldn't buy anything from EBAY because you made a mistake?
Ebay has been good to me...a barely used GTP-38R for $505. A Cummins N14 ECM for $407...Heavy duty junk yards wanted $1250-$1500 and Cummins wants $2700 for a Reman.
I could name some other good deals...but those two show the potential Ebay has to saving real money. I've only been burnt once...for $15. There are ways to protect yourself from bad sellers.
I had bought one of his controllers also. It made my truck run like crap. As I turned it to the higher performance levels the worse it ran. I emailed him and he said that my truck was probably to wore out at 165k miles or I didn't install it right. I unhooked it and used the superchips controller and the truck runs great. He doesn't give refunds. At least it was only a $85 life lesson, Oh well.
Personally, I appreciate the warnings about bad ebay sellers. There are too many options when it comes to buying items off of the internet that anytime we can rule one of them out it makes it all that much easier....so thanks for the tip. I won't buy anything from someone who doesn't have the decency to stand behind their products.
96 F250 4X2 CrewCab PSD 4" Fabtech, Authentic Tymar Intake, Dales 4 postiion chip, 3-4" DP, Side exit open exhaust. http://community.webshots.com/user/pjabdel
SOLD--99 F250 4X4 CrewCab PSD 6" Full Traction Suspension, Banks Power Pack, Pyro, ISSPRO TTM, Boost gauge, Rancho 9000s, Custom rear bumper w/ lights,Warn 15,000-that's right 15,000, BFG MT/KO's 37 X 12.5R17's, full custom dash panel
I think its best to buy from the sponsers and local shops (if they are good and trustworthy). Sponsers make this site possible, and you never know when you may get into a bind and need some help from your local shop.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
