i just installed it tin my truck stage 2 i was wondering what settings i should have it at and how i should have it bec right now its cools down a little and gives a bit more power but it seems like it should be more than what it is?
any tips on your water methanol installs?
05 F 250 XLT extented cab PSD, guages, exterior stuff, recon stuff, SCT Xcal 3 innovative X street tune, silver line cool duals, mtx thunderform encolsure with two 10's, alpine deck.
96 F250XLT heavy duty, ext cab, PSD 5-speed, 4:10's/limited slip-so far homemade tymar intake with big filter ,diy stage 1's, ts 6 pos chip, 4 inch turbo back to 5 inch slash cut stacks, pyro and boost guage.reverse glow guages, replaced clutch with a LUK replacement,garmin street pilot, sirius sat radio, Alpine Cd player, Alpine Type R 12" sub, sony xplode amp in custom center console, diamond plate trim and side steps, Visor, bug sheild,
i beleive i put it start at around 12 but it the light comes on around 15 and max at 24 on dial....the biggest nozzle i was using two but i took one out bec of i messed up and driled one of the holes to close to fuelk filter housing so and i needed something for the boost going to the controller.....and had to plug th eother hole with a pipe plug for now
you'll need the second nozzle to get a good hit. I run 2 625 nozzles at the 220psi max on at 10 max at 20. what are you using as fluid, washer fluid, water only or name brand snow 50/50
T off your map sensor line for the controller
where is your nozzle mounted?
97 Black CC F250 4X4 BDP stage 2's D66 5"exhaust Snow H2o/meth shimmed FPR modded pedistal 17*HPOP tymar intake black bird rear disks HPX BTS Tranny 10/4/07
i am running washer fluid right now...and the controller is getting its boost from manifold could i t of map line for the controler and the boost guage? so you think i should run two nozzles i have stage ones but only stock mech fuel pump....
