So far, so good. They're bias, so handling is a little off; and they're real prone to flat spotting overnight - takes 6-7 miles to smooth 'em out.
But get this - I mounted them myself (since local shops wanted $20+ to mount oversize tires) - and did a trick I read about elsewhere - I put a half pound (8 oz) of airsoft BBs in each one.
0.20 grams - 5000 in a box - 1 kG or 2.2 pounds split 4 ways.
I will never pay anyone to mount and balance big tires again.
Try it - it works - I can run 70 on the interstate, smooth as silk.
And, I think due to the big center rib, these tires are no louder than most AT tires and a lot quieter than that set of 35" BFG Mud Terrains I ran.
I too put these tires on my truck, even after the reviews from here. Just thought you would like to know that I have about 12,000 miles on mine (bought brand new). There would most likely be enough tread left to last another 3000-5000 miles, but im trying to get a new set of the 37" military radial version due to the amount of towing I do. By the way what pressure are yours at mine are 32 front 30 rear (currently)
Jon
1996 F-250 4x4 extended cab 5spd
4" lift with 37" humvee tires, RS 9000 XL 9 way shocks, 5' ladder bars
6 pos chip pyro and boost gauge, 4" turbo back exhaust, tymar intake, 17 HPOP, shimmed FPR
solid steel front bumper, in bed 90 gallon tank
car 2
1963 ford thunderbird
work in progress C-6 and mild built 390 planned
Interesting idea with the air soft BB's....I know there are products out there that do the same thing but I like the "find your own way" route...nice goin
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: cbuttre835</div><div class="ubbcode-body">
</div></div>
how exactly does this work? i also mounted my 315's a few months ago. i used the trick where you spray the inside of the wheel with ether then give yourself a trail and light it...pretty scary but it works really good!
-Dan
1996 F-250 PSD, 195k, 4x4, Supercab, LB, 3.55's, 4" lift, Built Auto with Precision converter, 150cc injectors, Autometer Z-series Pyro/Boost/Tranny/Diff guages, DIY open element intake, Sandpiper Diesel Performance 4" exhaust, TS 6pos. chip with 2L Motorsports tunes, Shimmed FPR, Modded IDM, Stainless HPX mod from ITPDIESEL.com , Baldwin Coolant Filter from Dieselsite.com , Bilstein shocks on all 4 corners, 315/75 BFG A/T's on 16x10 black Rockcrawlers, Custom front bumper, Ranch hand rear bumper, Warn manual hubs, Sparky's AIC, Full chrome grille, 318hp 643tq #24 sitting in the garage: 6.0 Intercooler
My Webshots
[URL="http://www.thedieselstop.com/forums/
psdan000 - they'll sling out and stick where they need to. I guess the tire bouncing from out of balance moves 'em around.
I had a buddy at work with 315s on a cummins that he put that Equal powder stuff in. It was $15 a tire though. I read about the Airsoft BBs on another forum in an Equal thread and decided to give it a try.
the last one - from the bottom of the stack - took FOREVER to seat. I ended up dousing the entire inside of the rim AND the inside of the tire with ether; and even then I had to stand it up. It'd just barely seat laying down and fall back off before I could get the air chuck on it.
I found that carburetor cleaner worked better; it didn't burn as long as ether and had a tad less umph. I didn't launch a single one into the air, except that last one.
radarman - they flat spot terribly. but my truck is not a daily driver no more so it ain't that big a deal
I too have the flat spots that prevent going 35-40mph at first more or less than that no problem. never happened untill 7,000 miles in when the outside center tread became a soild ring.
Jon
car 2
