Old 10-29-2007, 04:31 PM   #1 (permalink)
banjodog's Avatar
What else do I need for RSK w/SD springs
I just scored a set of leafs for a case of Coors Light! [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img] He said some cold Coors, I figured I should make it a case...
Sometimes I love being in the car(& truck) business, sometimes I hate it.
Here's what I gather I need to complete the job. Please let me know anything else I might need!
<ul>[*]Case of Coors Light[*]Sky RSK kit[*]Bilsteins (getting 5125's from Cary)[*]Drop pitman arm (Procomp was suggested)[*]Pipe to extend swaybar struts (What size do I need? How much?)[/list]
Any suggestions on remounting trackbar, extending swaybar struts, size drill needed for mounting RSK?
Do I need different U-bolts?
Thanks for any and all help
Max
'97 CC F350 PSD. 4x4. Auto. Black. Wildman 6pos Chip! BB in FPR. KCM HPX from ITP. 3"DP. AFE intake. 3.55's. BFG MT KM2 315/75/16's. Reunel Front and Rear Bumpers. Ford AIC module. Warn HD manual hubs. AutoMeter Z-series gauges on the pilar. <span style="color: red">((Sky RSK w/SD springs and bilsteins waiting in the living room))</span> MY TRUCK PICS!
banjodog is offline
Old 10-29-2007, 09:33 PM   #2 (permalink)
banjodog's Avatar
Re: What else do I need for RSK w/SD springs
Also:
Okay, just found the instructions on their website. 1/2" holes to be drilled.
think I'll need brake lines? (I'm only doing 3" not 5").
banjodog is offline
Old 10-29-2007, 10:32 PM   #3 (permalink)
DIESELDUTTON's Avatar
I will get you all of the info, drill bit size, spring bolts, pipe for sway bar links, etc. I replaced my rubber brake lines with stock rubber lines (I was in a jam and couldnt wait) I am getting by with them because my shocks are stopping the over extension, with 5125's you might have a problem. I will be ordering braided lines and a set of 5125's with proper valving from Cary soon. If you are planning on angling the RSK so you dont have to shim the bumper you will need a porta band or a decent sawz-all, grinder and torches helped me alot with the old spring bolts. You will need to shim the track bar bracket back, when I did mine I didnt think the sway bar would hit, but it did, so I spaced it back about 3\4 with washers for now. I will post again once I get all the info. If you plan on a intercooler install, have SKY lower the cross member as low as posible, I bought mine from a member that sold his truck before he installed it, so I just cut it out and rewelded it.
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 10-30-2007, 03:19 AM   #4 (permalink)
Get yourself four 3/4"x5.5" grade eight bolts and a good 3/4 bit for the springs and shackles. It will save you some time if you drill out the springs before you get them under the truck. The SD springs are metric (like 18mm).
I did my cutting of the SKY bracket with a 4" grinder with a cuttting wheel.
Good luck. Keep us poted on the project.
1996 F350 XLT CC LB 4x4 120K, E40D
Tymar Intake, Magnaflow 4" SS Exaust, Edge Evo, FPR Shim, SKY RSK w/SD vcodes, Bilsteins, Velvet Ride Shackles
TRUCK PICS
2004 Outlander Max 400HO (mine)
2004 Rally 200 (hers)
2004 Grizzly 80 (sons)
fitzgood is offline
Old 10-30-2007, 03:33 AM   #5 (permalink)
banjodog's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Tom_Again</div><div class="ubbcode-body">Get yourself four 3/4"x5.5" grade eight bolts and a good 3/4 bit for the springs and shackles. It will save you some time if you drill out the springs before you get them under the truck. The SD springs are metric (like 18mm).
</div></div>
drill out springs???
banjodog is offline
Old 10-30-2007, 09:59 AM   #6 (permalink)
Yeah, I believe I drilled the front spring bushing out to 3\4 and I believe in the rear I used 5\8, so I only had to drill the front, I will check tonight.
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
Old 10-30-2007, 08:38 PM   #7 (permalink)
Keep a good log and post it up so when I do mine it will make it easier for me please.
Todd
AKA Toad
1995 Ford F250 7.3L, auto stock 390,000mi, filler neck Mod, 3" DP with test pipe (no cat!), Fumoto oil drain valve, BDP Stage I Injectors, Tymar Intake, DB Electrical High Torque Starter
1965 Ford Mustang Fastback 289 4bbl 75,000mi
1988 Honda CRX Si 1.6L stock
1988 Honda CRX 1.5L stock
1990 Honda CRX 1.5L stock
1991 Honda CRX 1.5L stock
1998 Kawasaki Vulcan 1500 Classic
1981 Honda GL500
1995 F350 7.3L Parts Truck
stang65fst is offline
Old 10-31-2007, 01:02 AM   #8 (permalink)
banjodog's Avatar
will do!
I'm going to pick up the springs in the morning. How will I know what code they are? I won't be able to see the truck they came off of. I am getting them from the shop that did the lift on the donor SD.
About the drilling... are the bolts that come with the RSk not for that? Are they too small? Are the bolts on the Super Duty too small/weak?
banjodog is offline
Old 10-31-2007, 01:50 AM   #9 (permalink)
I found this list in another RSK thread. I found my vcodes from a lift shop too. I never saw the donor truck. My vcodes had 2C34-ADB stamped into the bottom of the lower leaf at the end.
Front Springs — F-Series
B — F81A-5310-EA
C — F81A-5310-EA
D — F81A-5310-EA
E — F81A-5310-EA
F — F81A-5310-FA
G — F81A-5310-GA
H — F81A-5310-HA
I — F81A-5310-RA
J — F81A-5310-JA
K — F81A-5310-KA
R — 2C34-5310-AAB, 3,600 lb.
S — 2C34-5310-AAB, 4,000 lb.
T — 2C34-5310-ABB, 4,400 lb.
U — 2C34-5310-ACB, 4,800 lb.
V — 2C34-5310-ADB, 5,200 lb.
W — 2C34-5310-AEA, 5,600 lb.
X — 2C34-5310-AFA, 6,000 lb.
Y — 2C34-5310-VA
Z — 2C34-5310-WA
Look at Cowboy_Dan's post in this link...more links and tons more info.
http://forums.thedieselstop.com/foru...068171&fpart=3
Good Luck
TRUCK PICS
fitzgood is offline
Old 10-31-2007, 03:26 PM   #10 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: banjodog</div><div class="ubbcode-body">will do!
About the drilling... are the bolts that come with the RSk not for that? Are they too small? Are the bolts on the Super Duty too small/weak? </div></div>
The bolts that came with the kit are for bolting it up. You need to either get SD spring bolts$$$ or get 3/4" ones, you must drill out everything either way.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 10-31-2007, 03:31 PM   #11 (permalink)
banjodog's Avatar
OK got the springs.
Front: F81A AFD
RPN 1039
Rear: RPN 1069
F81A BE
edit: Would it matter what year the truck was? I assumed '99 from what the lift shop told me. Mike (my parts guy) said the fronts should be V-code and the rears he thinks are B-code but he had to go up to 2003 to find the rears (probably just that 99's rears are obsolete part #).
banjodog is offline
Old 10-31-2007, 10:30 PM   #12 (permalink)
MJLankford's Avatar
Ok assuming the Dana 60 came with nothing is this a pretty accurate list of what I would need to complete the RSK with superduty springs and a D60 swap.
Sky RSK
Superduty V-Codes
D60 Track Bar
Steering Linkage
Shocks
Blocks for rear
(4) 3/4"x5.5" Gr. 8 Bolts
3/4" Drill bit for springs and shackles
U-bolts for springs
1996 F250 XLT, CC, SB, 4x4, 231,000 miles, 4.10 gears, E4OD, Tony Wildman 4 Pos. Chip, Custom modded Valvebody by Richter69, GAW Downpipe and 4" exhaust to a 5" bent tip, new interstate batteries, Pioneer Headunit, Alpine Components/Amps, Infinity Sub, Front brush guard w/ Hella drive lights, Camo seat covers, 1997 F350 Dana 60 Axle swap with 3" RSK and 2001 F350 Superduty Springs "V codes", and 5.5" non-tapered rear blocks, New Mickey Thompson Classic II's 16x8 drilled rims and LT315/75R16 Nitto Terra Grapplers with McGard Lug Nuts.
Truck Pics
MJLankford is offline
Old 11-01-2007, 01:19 AM   #13 (permalink)
I was told that 99-03 f250 or 350 would be vcodes in the front if it was a PSD. I don't know about the rear leafs.
Mtt...Consider adding these to you list:
Drop pitman arm
New brake lines (longer)
New shocks for 2-4" lift
I installed mine without all these and I am now going back under it to add them.
TRUCK PICS
fitzgood is offline
Old 11-01-2007, 02:25 AM   #14 (permalink)
banjodog's Avatar
Do I need different U bolts? Any advice on the sway bar struts?
banjodog is offline
Old 11-01-2007, 09:04 AM   #15 (permalink)
Cut and sleeve to extend the sway bar links with 1/8" or thicker tubing.
New U bolts is recommended but so far I never have had a problem reusing any.
You MUST get a adjustable track bar..either cut yours in half and thread and use a tie-rod adjuster sleeve or just buy one.
Drop pitman arm is a good idea, longer SS brake lines are a great upgrade nice but not necessary for a RS kit.
Cary
2006 Yamaha FJR1300
caryt is offline
